Old Jul 07, 2012, 01:54 PM
goflyhighrc is offline
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
Originally Posted by DaOldGuy View Post
Do a trim flight with the plane at half throttle, take a look at the elevator position after landing, this is always a quick first test assuming incidence on surfaces are all correct.
What do you mean by looking at the elevator? He has a bit of up elevator trimmed at level flight.
goflyhighrc is offline Find More Posts by goflyhighrc
Old Jul 07, 2012, 01:56 PM
Joined Nov 2006
Originally Posted by Luv3d View Post
The inverted test is only valid if the airplane has a symmetrical airfoil. Does the cessna have a symmetrical airfoil? If it does not, the test will not work properly.
Here is the plane, not his, but the same model. Does it have a symmetrical airfoil?
Giant Scale 107" ECOMRC Cessna 195 maiden AirShowRC.com (3 min 51 sec)
Old Jul 07, 2012, 02:25 PM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
According to their website, the ECOMRC 107" Cessna 195 uses a NACA 2412 airfoil which is not symmetrical.
See the graphic below.
Luv3d is online now Find More Posts by Luv3d
Old Jul 07, 2012, 02:28 PM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
Good original question, though. For an asymmetrical airfoil, how to check the CG when airborne. Other than level flight testing, I'm not sure. It should still balance statically about 1/3 the total wing chord, just like an aerobatic airframe/airfoil should, I believe.
Old Jul 07, 2012, 02:39 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
For a Cesna, it's better to err on being a tad too nose heavy.
BoneDoc is offline Find More Posts by BoneDoc
Old Jul 07, 2012, 02:49 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
yea that plane is not a 3D plane to start with, if you make it neutral to tail heavy it'll be a beast to hold on to.
nebwake is offline Find More Posts by nebwake
Old Jul 07, 2012, 03:12 PM
Joined Nov 2006
The owner has about 12 clicks of uptrim for level flight, he thinks it's tail heavy because it feels sensitive to him,doe's not make sense to me.
Old Jul 07, 2012, 03:26 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
If it's too sensitive, then it's because he's going too slow.
Old Jul 07, 2012, 03:30 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Would uptrim be nose heavy? Why do I feel stupid today?
going4speed is offline Find More Posts by going4speed
Old Jul 07, 2012, 03:43 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Yes, assuming the incidence is set correctly. But a plane that's too nose heavy will come in HOT for a landing. If the pilot is not comfortable with that speed, he will try to (ill-advisedly) slow it down, causing the plane to be in a near stall condition, and hence, making it feel "unstable".
Old Jul 07, 2012, 03:54 PM
3DHS 'native'
USA, TX, Spring
Nose heavy has better post stall recovery too right?
Old Jul 07, 2012, 04:00 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
UP trim in level flight is OK....means the plane does not need help holding the tail "up" with downtrim. This likely means he's on the noseheavy side of neutral.
Possibly...but not to forget.....planes with small surfaces (scale) can also take on a "mushy" feel when going too slow, with slow air over the controls.
The bottom line....try going more noseheavy...this will generally NOT cause anything bad to happen...if the plane feels better, leave it that way. Clearly, we're talking about fine-tuning CG on this "already-flown" plane...so it couldn't be TOO tailheavy even now.....must be pretty close or he would've had big complaints on maiden.......
Of course, you may want to look into the expo settings.....if the complaint is "sensitive" around neutral, try adding some expo.
I generally look at a high-wing non-symmetrical airframe with the way it feels on landing.....if the nose won't come down and settle into a nice glide at idle....try moving the CG forward. You should be able to make the plane take on a nice slightly nose-down glide at low throttle if the CG is right.
All this discussion about CG-testing.....has a simple answer, forget the tests....just adjust the CG so it FEELS right to you....for me, a plane needs to track well and settle in nice on landing without ballooning....this typically puts me slightly ahead of a neutral CG.
Bivens is offline Find More Posts by Bivens
Old Jul 07, 2012, 06:36 PM
Joined Nov 2006
Wing Stand
A year or so ago, someone posted a video standing in the middle of as wing of a GS 3DHS plane. Anyone have it in thier archives?
Old Jul 07, 2012, 07:29 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Was that josh price?
No, I think it was jared clark
cmala is offline Find More Posts by cmala
Old Jul 07, 2012, 07:38 PM
Joined Nov 2006
I was thinking Josh, perhaps it was Jared,trying to locate it on youtube.
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14954 Jun 27, 2016 03:25 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1157 Jun 26, 2016 09:16 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
