Old Jul 03, 2012, 10:34 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by theKM View Post
the Deans based Armsafe plugs get my vote... installed as a switch for the radio system on a few of my gassers now... very happy with them, standard equipment for me now. 3DHS selling them, AMain selling them, bunch of places are picking them up.
I'm allergic to deans but I've been using the APP version for several years without issue to arm my 6S-10S electric motors. It's not going to "fall out"
I use a separate receiver pack on a switch or two as well
cmala is offline Find More Posts by cmala
Old Jul 03, 2012, 10:49 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Originally Posted by going4speed View Post
I'm going to use one of these instead of a switch
Looks like trouble to me. After reading endless pages of debates on which is better, I don't think it's possible for Deans and Powerpoles to coexist in a singular product!
G.P. is offline Find More Posts by G.P.
Old Jul 03, 2012, 10:54 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I am making my own but am strictly using this for the receiver circuit on the 70 gasser slick
Originally Posted by SteveT. View Post
I don't know what size plane/motor set up you are planning on using that on , but the pre made harnesses are usually only 14 gauge wire. If you want to use one of those, make your own and use at least twelve gauge wire.
SteveT
going4speed is offline Find More Posts by going4speed
Old Jul 03, 2012, 10:59 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Ok, I am back home from a friends house and my gensis kit is here and I would like to have it on my 47" SHP for tomarrow night.
I want my lights to be removable, I have no idea what I am doing. Where do I start? I have no BEC I guess I have to make this work with just my hacker x-55 esc. So this is my cry out for help.
skarface is offline Find More Posts by skarface
Old Jul 03, 2012, 11:19 PM
3DHS 'native'
USA, TX, Spring
Look cool! Ordered!
Old Jul 04, 2012, 02:01 AM
skarface is offline
skarface's Avatar
Joined Aug 2011
Aurora RC Lights: Genesis Kit on my 47" SHP.
I want my lights to be removable. I don't care if I have to pull all the wires out when I am not using them and I don't car if I just unplug the light part are leave the driver and main wires in there when I am not using them.
My first thought is I will have to be able to unplug my driver so I can't directly solder to my esc. I have a hacker x-55 and I don't have a BEC.
My kit came with a wire, female JST with two male JST's on the other end. I don't think I need that since that is for if you have a BEC right? So can I just cut off one of those female ends and then solder that to my ESC wires and then that is how I will unplug it from the main driver?
Also the part for the wing tips. Should I drill a hole through the end of my wing and possibly fedd the wires though my wing? or just tape them down to the bottom of the wings and make a small hole in the fuse right under the wings? I see they gave me those big white thing to I guess stick in the end of my wings, is there a better mounting peice to use?
Now the tail I am guessing a small hole right above the vertical stab in the top of the fuse?
Old Jul 04, 2012, 03:59 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
Sigh...just get a 2s small batteries and use them to power it all up!
rimaarts is offline Find More Posts by rimaarts
Old Jul 04, 2012, 04:35 AM
skarface is offline
skarface's Avatar
Joined Aug 2011
Nah to much extra weight, I am sure will post here soon once they wake up lol.
Well idk bought the weight I just don't feel like having to deal with more batteries to unplug, charge, and spend money on.
Old Jul 04, 2012, 04:47 AM
rimaarts is offline
Joined Jul 2011
Tried 2s 450 on 48 epp, made no diference...probably 2s 250-300 would do for a single flight..
Old Jul 04, 2012, 09:08 AM
FlyFisch is offline
Find More Posts by FlyFisch
Just do it.
FlyFisch's Avatar
Stroudsburg, PA
Joined Nov 2009
Can somebody possibly post a description of how they plan on using those arming plugs for rx power?
FlyFisch is offline Find More Posts by FlyFisch
Old Jul 04, 2012, 09:15 AM
3DHS 'native'
USA, TX, Spring
I'm going to use it in the following manner:
Two 12" servo extensions from the LIfe battery going to the receiver. Both of the positive wires from the extensions will be cut and soldered onto the armsafe deans. That's really about it.
Old Jul 04, 2012, 09:17 AM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
I put the arming plug right before the esc and after the batteries and bec. That way the servos come on when i plug the batteries in but the motor is not active. This is great for radio setup and for safety in the pits. For a gasser just put them right after the battery and before your bec so that nothing turns on until you insert the arming plug. I did a large post in the old addicts thread about them with pictures of mine. You can look at all my attachments to find the pictures and they will link to the post of mine. Hope that helps. One other thing, i also make my own so that i can put the arming plug connections right onto my esc to eliminate excessive connections/weak points. If anybody needs some 10ga pp arming plugs let me know and i can make some for you if you cover shipping. I have had 12ga ones heat up just a few degrees on my 1/4 scale electrics but the 10 ga holds up well without heat.
lammbn is offline Find More Posts by lammbn
Old Jul 04, 2012, 09:29 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
My first experiance with APP was a little iffy, a set came with my ignition for a DA150, I really liked how easy they are to plug and unplug, but they didn't lock up as positive as I like. I don't belive they would "fall out" but vibrations from a big gasser can do some crazy things. That is why I secure ALL connectors with either dental floss or the connector locks for the ailerons. For the deans plugs from my batteries, I use some gorilla tape strip that I just replace as it tires out.
nebwake is offline Find More Posts by nebwake
Old Jul 04, 2012, 09:47 AM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
To help with " separation anxiety" (lol) with power poles use the blok-loks or retention clips. I use the blok-loks on all my pp connections and love them and the peace of mind they give.
http://www.powerwerx.com/powerpole-a...ion-clips.html
http://www.powerwerx.com/powerpole-a...mp-2-sets.html
Old Jul 04, 2012, 09:56 AM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
those look nice
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 14992 Jul 20, 2016 12:29 AM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1162 Jul 02, 2016 09:39 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
