Old Apr 28, 2012, 07:05 PM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Question! Do xoar props...like their 15"-16" props come with the center hole drilled to the correct size or do you have to drill it out? Do any props come with the center hole drilled to the correct size? And lastly, does anyone have a really good way to drill the center hole and keep it centered, like a tool, not just going up every drill bit size?
TG43 is offline Find More Posts by TG43
Old Apr 28, 2012, 07:07 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Prop reamers work great. I have the great planes one. Its setup for a hand drill but Im lazy and just put it in my dewalt drill and go. I've drilled out CF props, aluminum back plates, APC props, and wood props and that thing is still sharp after 4 years of abuse
losifanatic is offline Find More Posts by losifanatic
Old Apr 28, 2012, 07:17 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
i think the hole in the 15-16" props is too big....a spacer is needed....unless i missed something
aronph is offline Find More Posts by aronph
Old Apr 28, 2012, 07:19 PM
Sippin the Koolaid!
Joined Oct 2007
I didn't see which motor. So you might be right. Though a prop reamer is good to have in the too box
Old Apr 28, 2012, 07:23 PM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Prop reamer....now you tell me! Yep that's what I need, didn't even know they existed! Thanks!
Old Apr 28, 2012, 08:13 PM
Sippin the Koolaid!
Joined Oct 2007
The 4315 has an 8mm prop adapter
Old Apr 28, 2012, 10:15 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by marksextra View Post
Well....if you want to use an aluminum servo arm the the 2mm bolts/ball links won't work for one thing.
I ended up having to get a 2mm to 4/40 conversion ball link to be able to use an SWB aluminum servo arm. Oh and to confirm for some....most 4/40 don't work because the ball link doesn't fit very well between the control horns.
I use Secraft or Spot-on aluminum 4-40 arms on my planes...no problems, but I make a small modification.... The inside diameter of these Dubro pull/pull crimps, are the perfect size for 2mm screws. So, I just drill the 4-40 arm to .001" undersize and push these in and cut them off flush on the bottom. Then just use the stock 2mm screw and ball...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 28, 2012, 10:22 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
And prop reamers come in both metric and fractional sizes..
SteveT
Old Apr 29, 2012, 12:01 AM
theK2 is offline
Find More Posts by theK2
3D-wanna-B
theK2's Avatar
Lynchburg, VA
Joined Dec 2008
Originally Posted by quadracer View Post
the wire bends VERY easily, and becomes a nuisance to straighten out after every landing.
Originally Posted by lammbn View Post
I have yet to need to bend my gear back at all in over 60 flights that i have on my 48.
Have to agree with lamm on this one --- I have a SLIGHT bend in my wire from my very first landing but nothing severe at all and not even worth bending back. I could definitely see how grass could bend the wire but I fly off asphalt so don't have that problem and I really think you would have to slam it down on asphalt to bend the wire all the way back to the fuse. But as has been said, do the screw LG mod and you're good to go.
theK2 is offline Find More Posts by theK2
Old Apr 29, 2012, 01:00 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
http://www.electricwingman.com/goril...l-1044401.aspx
guys as i remember there were 2 gorilla glues, 1 good, 1 not so good... was uppermentioned okey or should i go epoxy for a 71" slick?
rimaarts is offline Find More Posts by rimaarts
Old Apr 29, 2012, 01:28 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
The honey colored Gorilla glue is fine....Personally, I prefer epoxy....but that is just my "old school" way of doing things...
I used to buy Hobby Poxy that had a one hour work time....unfortunately , Hobby Poxy went out of business, and I can find any other in the U.S. You guys in the U.K. have this, one hour work time epoxy...that I found at a few different shops in the U.K.....
SteveT
Old Apr 29, 2012, 03:19 AM
rimaarts is offline
Joined Jul 2011
So basically 1h epoxy would be even better than 30min? Would soakk in the wood more? I was allways thinking that 1h and more epoxies is mostly for glassing...
Old Apr 29, 2012, 06:12 AM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
even 15 minute expoxy is fine. It all depends on how much time you need to work with it.
marksextra is offline Find More Posts by marksextra
Old Apr 29, 2012, 06:27 AM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
glassing what?....actions?
Old Apr 29, 2012, 07:05 AM
rimaarts is offline
Joined Jul 2011
I mean layer of fibreglass-epoxy, sanding, sanding, fibreglass, epoxy, sanding..
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 15106 Sep 15, 2016 04:43 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1166 Aug 09, 2016 01:19 AM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro Ready-to-Fly 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
