Old Apr 15, 2012, 12:55 PM
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by VENOMiTry View Post
did you use 1 inch pvc? looks really nice i think im gonna build one.
I used 3/4th inch PVC. I used the basic design used here http://www.rcgroups.com/forums/showthread.php?t=1157593 But I changed the measurements to my needs.
Originally Posted by 3Dplank View Post
Looks good now you have room for more planes in the guest room
So true
Park_aviator is offline Find More Posts by Park_aviator
Old Apr 15, 2012, 02:00 PM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Just gotta order a couple paraboards and my charging center will be complete!
Back behind is a pair of Lambda rack mount 20A 24V supplies designed to run in parallel. Along with my new Hyperion Super Duo , I should be able to charge all 8 of my 6s 5000mah packs simultaneously at 1c!!!
And just a note, I do charge in LiPo bags, I was just getting everything all set up in this picture.
FireyFate is offline Find More Posts by FireyFate
Old Apr 15, 2012, 02:01 PM
Irg
ol' yellow eyes is back
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
very nice
Irg is offline Find More Posts by Irg
Latest blog entry: laser repair
Old Apr 15, 2012, 02:44 PM
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
ok so i am alittle confused if i go down while up right flying and up while inverted that means my lipo needs to go back further right?
skarface is offline Find More Posts by skarface
Old Apr 15, 2012, 02:50 PM
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
basic cg (ie battery placement) instructions
1. put the pack in the middle of the tray or a bit forward.
2. fly plane, trim to fly level at 3/4-full throttle.
3. fly plane at 3/4-full throttle, pull up to a 45º upline, roll inverted
4. without touching the elevator, if the plane climbs, it's tailheavy, move the pack forward
4b. if the plane dives, it's noseheavy, move the pack back to get closer to neutral *if desired*
5. after adjusting pack, fly the plane, and trim to fly level. then conduct step 3. again.
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
No, it means that you need to trim you elevator out. If you go down will your upright you are nose heavy. If you go up while inverted, you are tail heavy. You can be both, so you need to trim you plane out.
diggity2424 is offline Find More Posts by diggity2424
Old Apr 15, 2012, 02:53 PM
skarface's Avatar
Joined Aug 2011
wow thanks i will have to do that today.
Old Apr 15, 2012, 02:55 PM
Have U Snapped A Slick Today??
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Anyone have any 19x10 Xoars they want to sell, or a Mejzlik, (if they make one in that size)?
heritageflyer is offline Find More Posts by heritageflyer
Old Apr 15, 2012, 02:57 PM
skarface's Avatar
Joined Aug 2011
ok i understand now thanks
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
sure. like diggity said, the first step is to make sure you are trimmed for straight and level upright flight. being out of trim will throw off the whole rest of the process.
there are lots of different CG preferences. I like it to sink a bit--slightly nose heavy. allows you to do all the fun 3D stuff and maintain very nice precision characteristics at higher speeds. also makes the landings very predictable.
you'll notice a lot of the greats use an ahead of neutral cg... I copy them as much as possible.
Old Apr 15, 2012, 02:59 PM
skarface's Avatar
Joined Aug 2011
ok i will have to play with it today. I had it trimmed good but then i crashed and added some thick ca and then for some reason i was really wack
Old Apr 15, 2012, 03:01 PM
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
RCdude is awesome for quick and cheap shipping on lots of xoar sizes. he even carries the rare 18x10.
Old Apr 15, 2012, 03:21 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I have done a search on this, but found no answer...What the heck is a Lambda power supply, and how does it differ from others?
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 15, 2012, 03:28 PM
Irg
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
lambda=c/mu?
Old Apr 15, 2012, 03:32 PM
SteveT.'s Avatar
San Jose, CA
lambda=c/mu?
That makes as much sense as anything I have found so far..... I.E. nothing....
SteveT
Discussion Unofficial NQD Tear Into Jet Boat Mod Thread Energy Racing Boats - Electric 3952 Today 07:07 PM
Discussion Banana Hobby Customer Support Request/Q and A Thread! banana hobby Banana Hobby 1018 Today 01:47 PM
Discussion The Official AirWare Q&A Thread AndyKunz Radios 95 Feb 14, 2013 08:36 AM
Discussion THE FIRST UNOFFICIAL Parkzone Sukhoi mods thread!!!! bluemeane Micro RTF 27 Aug 17, 2009 11:23 PM
Megatech H2O unofficial thread and first rewiew. grk65 Racing Boats - Electric 7 Mar 05, 2007 12:09 AM
