Old Feb 07, 2012, 02:18 AM
gzmann is offline
Find More Posts by gzmann
Joined Aug 2007
Unable to get Nova OSD info on screen with 690TVL cam with
Just got my bixler and newly installed nova osd . I must say that after having flown rc airplanes for years -- i love the ability to use the PA/RTH feature . It worked amazingly well. It was a bit windy and the plane was stabilized in PA mode, and returned home nicely with RTH .The plane did seem to want to climb in both modes but I just throttled back and that solved itself. I guess that is better than going into a dive.
Problem!!
I just got a new---- 690TVL Ultra WDR Pixim SEAWOLF HD CCTV Mini Camera 3.6mm Lens OSD Menu--
The problem is that I can not see the bottom 1/6 of the osd info. When I swapped with a 380tvl camera - all the information is there????
Is there a solution to get the info up there-- or are these 700tvl cameras incompatible??
SURELY there must be someone who has a high TVL camera used with this OSD??
Any ideas what to do??
gzmann is offline Find More Posts by gzmann
Old Feb 07, 2012, 05:08 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by gzmann View Post
Just got my bixler and newly installed nova osd . I must say that after having flown rc airplanes for years -- i love the ability to use the PA?RTH feature . It worked amazingly well. It was a bit windy and the plane was stabilized in PA mode. The plane did seem to want to climb in both modes but I just throttled back and that solved itself. I guess that is better than going into a dive.
Problem!!
I figure the MAX7456 OSD chip used in this osd (as well as in many other comercially available OSDs btw.) can't cope with this number of tv lines.
Markus
markus123456 is offline Find More Posts by markus123456
Old Feb 07, 2012, 06:09 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Or perhaps the osd is set for pal and the cam for ntsc, or vice versa.
NDw is offline Find More Posts by NDw
Old Feb 07, 2012, 06:38 PM
gzmann is offline
Joined Aug 2007
Nova osd fixed with special advanced menu
Thanks for the responses
If you press on the OSD left and up at the same time-- the advanced menu appears -- go to video output -- the nova osd is default to pal and the camera's set to ntsc ==== change the camera to PAL and viola --- all the info from the OSD appears!!
Discussion nova osd with rth mark the shark FPV Equipment 2241 Nov 07, 2015 09:57 AM
Question Nova OSD RTH with AAT My Fly Dream antenna tracker Bob. Australia 1 Apr 07, 2012 09:36 AM
Discussion Anyone get to play with the < $100 690TVL pixim from security2000 sim_io FPV Talk 2 Sep 14, 2011 02:45 PM
Discussion Dragon OSD ,interference on OSD screen...? marcin.gala FPV Talk 5 May 28, 2011 04:31 AM
Help! osd pro on screen characters ausmark Eagle Tree Systems 5 Apr 19, 2011 11:48 PM
