Foam Fumes (Toxic?)
So, this is something that I began looking into after completing my foam cutter:
http://www.rcgroups.com/forums/showt...3#post20664310 OutcastZeroOne has mentioned: Quote:
So I went into a little bit of a research mode: I'll just post what I had there: ------------------------------------------------- Heh, yeah. I keep the garage door opened when I use it. I also purchased http://www.harborfreight.com/p95-mai...tor-66554.html a while back. It says it can protect up to 95% of organic vapors... From my research, it's pretty much anything that contains carbon. So in theory is can protect against foam's chemical fumes. An external oxygen supply one would probably be better... but I'm sure those are very expensive. I'll do a little bit of research. Unless someone knows more on this subject matter? Source: http://en.wikipedia.org/wiki/Organic_compound EDIT: List of Organic Vapors: http://www.assaytech.com/quickck.html Another interesting thing I've read: http://en.wikipedia.org/wiki/Polystyrene Quote:
Never knew that Polystyrene was harmless, the vapor is just water and carbon dioxide (with soot, of course). We deal with all kinds of different foams, however. And the ones we usually play around with are not safe for food packaging; therefore, telling me that the chemicals they have are incredibly dangerous. I need to research more and see what kind of vapors the foams we work with produce. Quote:
EDIT: From Hot Wire Foam Factory website: http://www.hotwirefoamfactory.com/cu...ry/faqfoam.htm Quote:
Other than that... I would assume color additives in the foam (pink, blue, green, etc.) would produce harmful chemicals... it's like burning paint? But the foam itself does not appear to be as harmful as everyone makes it out to be. Unless someone has some hard data? -------------------------------------------------------------- I would think there's something toxic and harmful about burning plastics and foam, especially since they're petroleum-based products, but I would like to know exactly what we're dealing with when we choose to introduce burnt foam fumes into our air. -BK |
So, I went to the source of Polystyrene -----> Styrene. How harmful is Styrene?
Wiki: http://en.wikipedia.org/wiki/Styrene Quote:
TerraGenesis: http://terragenesis.co.uk/infopages/page173.html Has some health information regarding cutting foam. However, it does not have hard data towards it's toxicity. It says it can cause doziness in small children, etc... but that could be due to CO2 replacing oxygen in the air. HealthyChild.org: http://healthychild.org/issues/chemical-pop/styrene/ Quote:
So they actually used lab animals to check for health hazards... but I'm sure it's in very large quantities. It appears Styrene comes from cigarette smoke as well. This is from CDC.gov: Occupational Health Guidelines for Styrene (PDF) PDF file from CDC.gov provides some standards for protecting yourself on Page 5. OSHA.gov: http://www.osha.gov/SLTC/styrene/index.html Too much stuff to quote, but it's a good read on their outlook on Styrene. Has a lot of data and studies. ---------------------------- Whatever those websites say, it appears that things are still being researched and no hard conclusions have been formed. It is important to protect yourself against those POSSIBLE health hazards. It seems that everything that comes from petroleum ends up being cancerous or toxic. Even though there's not enough data to prove that Styrene is in fact harmful, I would probably go ahead and protect yourself as much as possible. Makes me wonder why Hot Wire Foam Factory website would claim that those fumes are not all that toxic... along with Wiki page for Polystyrene. And my only guess would be this: a regular hobbyist does not cut production amount of foam, thus exposing himself/herself to less fumes. Most of the fumes are CO2 and water; however, a small part of the fumes is styrene, along with a few other harmful chemicals, but it's not enough to cause a huge concern if exposures are limited (I would still protect myself as much as possible). My personal conclusion is this: Those fumes do indeed inhibit harmful chemicals. Most of the fumes are CO2 and water, but a small portion are toxins. Most of those studies are geared towards someone who's exposed to that stuff every day, possible due to their work environment (foam-production plant). If they're exposed to that stuff every day for 30 years without any protection equipment, there's a pretty good chance they're not going to milk their retirement. As far as I'm concerned... we get exposed to the same chemicals from car exhaust fumes every day. I wouldn't want to add anything on top of that, so I'll use my mask and maybe get a workshop air filtration system. But in small amounts, it's not something that's going to kill you.... it'll take a moderate amount over a lengthy period. Just as OutcastZeroOne and many others have mentioned, a good ventilation will do most of the work. You can go one step ahead and get a respirator (like mine from Harbor Freight ($16): http://www.harborfreight.com/p95-mai...tor-66554.html or Amazon ($25-30): http://www.amazon.com/3M-R6211-Low-M...8588294&sr=1-2 & http://www.amazon.com/MSA-Safety-Wor...8588294&sr=1-1). You can even get air purification system for a workshop environment: Amazon ($170) http://www.amazon.com/708620B-AFS-10...8588409&sr=1-1. Heck, you can even go one step further and get a HEPA-certified Chemical Air Purifier such as IQAir or Austin Air (I got Austin Air... it works, seriously): Amazon Link What kind of air purifiers do you guys use, if any? I know that Jet air purifier is very popular, but it doesn't collect chemical fumes... Austin Air and IQAir do that pretty well, but are pricier (especially IQAir). Also, what kind respirators do you use, if any? Do you use organic vapor filter or some kind of other carbon filter? Please, share your knowledge. -BK |
Joined May 2005
when I first built and used my hotwire a long time ago, I did it in a large room but didnt have ventalation. Project took way longer then I had planned. after a few hours of having that thing on (i was still learning the machine and made a lot of "test parts") my eyes where starting to burn a bit. There is something there when the foam is cut with the hot wire.
Now my current set up has a filtration system to collect all those nasty fumes and filter them from the air. Also with my table having a light on it, I can see that there is some smoke made, even at low settings. its just very hard to see unless lit up. My table has 8 LEDs around the wire to light up my work area. |
Joined May 2005
directly above the wire I have some ducting that leads to my filter system. Ive got a few different types of filters including an activated carbon filter.
they sell smaller units for soldering stations like these guys: http://www.mpja.com/prodinfo.asp?number=17529+TL http://www.mpja.com/Solder-Fume-and-...tinfo/15166+TL |
| Thread Tools | |
| Discussion Foam Fumes? | Evan Byrne | Slope | 11 | Mar 21, 2006 01:45 AM |
| Poll A warning about certian foam based glues and epp fumes | flybaby2000 | Slope | 27 | Feb 07, 2006 06:22 AM |
| Foam fumes? | bubbahotep | Foamies (Kits) | 2 | Sep 28, 2005 11:35 AM |
| Are lipo fumes toxic??? | Philpops | Batteries and Chargers | 5 | Feb 02, 2005 05:37 PM |
| EPP Foam Fumes | Pitt76 | Foamies (Kits) | 3 | Jul 13, 2001 02:37 PM |
