Old Feb 06, 2012, 06:45 PM
Matt D is offline
Find More Posts by Matt D
Joined Feb 2012
Question
Converting a Futaba 7C from FM to 2.4ghz
Long story short, a couple years ago I wanted to get into helis, found a crazy deal on a brand new Futaba 7CHP, but never bought a heli so it collected dust. Unfortunately, this is not the 7UHP, so it doesn't have a module. I'm now picking up a heli so the radio will hopefully see some use.
Since then people have found a way to take the Spektrum DM8 transmitter module and solder it into the transmitter directly in place of the FM transmitter board. As my luck would have it I can not find the DM8 module for sale anywhere, it's not listed on Spektrum's site unless you search for it on Google, and it's not in stock anywhere.
Then I found the FrSky DIY 2.4 module. I hadn't heard of them until I started researching the conversion of a Futaba 7C to 2.4ghz. From what I've read is people have no problem with these modules as long as you avoid connecting it through the trainer port, which I wouldn't be doing.
Ideally I'd like to find a Spektrum DM8, but worst case is I'd try out the FrSky module. Thoughts, opinions?
Matt D is offline Find More Posts by Matt D
Old Feb 07, 2012, 05:40 AM
gdh240 is offline
Find More Posts by gdh240
Greg
gdh240's Avatar
Tas, Australia
Joined Oct 2010
I've converted my 7C to FrSky and it works perfectly. All my planes are now on FrSky. It's worth putting the switch and light on the front so you can see the light.
gdh240 is offline Find More Posts by gdh240
Old Feb 07, 2012, 11:57 AM
igorp is offline
Find More Posts by igorp
FPV Crash Dummy
igorp's Avatar
United States, CT, Bloomfield
Joined Aug 2007
You know the 7chp is not just a heli radio... In any case I converted my 7CHP to Frsky. I left the 72mhz board in and put it on a switch, now I can switch back and forth.
igorp is offline Find More Posts by igorp
Old Feb 07, 2012, 12:14 PM
Matt D is offline
Joined Feb 2012
That's what I was hoping to hear, thanks guys! Yep, I know it can do airplanes and helis, I like the throttle that doesn't have the notches in the movement.
Old Feb 08, 2012, 12:03 PM
Zeke0504 is offline
Find More Posts by Zeke0504
Zeke0504's Avatar
American Canyon, CA
Joined Sep 2004
I'd like to convert/upgrade my futaba 7c 72mhz to 2.4ghz...
Is it easy to do? just follow the instructions?
I'd like to have a switch where in I can switch to 72mhz or 2.4ghz. I have lots of 72mhz receivers and I dont want to replace them.
Zeke0504 is offline Find More Posts by Zeke0504
Old Feb 08, 2012, 06:38 PM
Matt D is offline
Joined Feb 2012
This should help you out: http://flitetest.com/articles/diy-2-4ghz-radio-upgrade/
Old Feb 08, 2012, 07:59 PM
Zeke0504 is offline
Zeke0504's Avatar
American Canyon, CA
Joined Sep 2004
Originally Posted by Matt D View Post
Thanks Matt D!
Old Feb 11, 2012, 04:00 PM
mmatheny is offline
Find More Posts by mmatheny
mmatheny's Avatar
United States, TX, Dickinson
Joined Mar 2003
Anyone tried THIS kit? Seems pretty simple:
http://hobbyking.com/hobbyking/store...RX_%28DSSS%29_
mmatheny is offline Find More Posts by mmatheny
For Sale Futaba 7C 2.4GHz Fasst Heli Version Mode 2 coptersrcool Aircraft - General - Radio Equipment (FS/W) 4 Jan 12, 2012 11:39 AM
Sold Futaba 7C 2.4GHz Radio System with the R617FS FASST 7-Channel Receiver ap_rpm Aircraft - General - Radio Equipment (FS/W) 4 Oct 18, 2011 09:30 AM
Sold Like new Futaba 7C 7-Channel 2.4GHz FASST Radio(SOLD) thundercl58 Aircraft - General - Radio Equipment (FS/W) 2 Oct 08, 2011 11:12 PM
Help! How do you program Futaba 6EX-2.4GHz and Futaba 7C-2.4GH for a plane badatflying Radios 3 Sep 03, 2011 08:22 PM
Discussion 1 watt 2.4ghz video tx, Futaba 7C 2.4ghz, 900mhz XBEE compability? crd FPV Talk 4 May 07, 2010 07:25 AM
