Old Sep 15, 2012, 08:29 AM
macem is offline
Find More Posts by macem
Joined Sep 2012
Originally Posted by HobbyEurope View Post
Of course you cannot. Improvements will be done continously ... so ...
www.hobbyeurope.com
... i am not sure, i understand what you mean... but anyhow...
concerning my wire-problem:
*there is no sparepart in the list...
*unfortunately, the metallic pins broke themselfs, so i cannot solder them to the wires anymore.. have a look at the pictures below...
*and, i checked it out: the mcpx-tailmotor wire comes with the male-connector, the hisky with the femal side - so its not compatibel (additionally the mcpx-connectors are a little bit greater (half a millimeter, i guess...)
seems, i have to buy another heli-set (!) because of one micro-connector
macem is offline Find More Posts by macem
Old Sep 15, 2012, 11:55 PM
HobbyEurope is offline
Find More Posts by HobbyEurope
Norway
Joined Feb 2011
That means that improvements will be going on all the time.
About the female connector, it looks like a standard mini connector sure sold on the open market. But when you are in need, things are always hard to find ....
I have only the FBL80 here in office to check out what kind of connector it is, but I suppose both the FBL 100 and the FBL80 are using the same connector.
Anyway; I will ask HiSKY to send some of these connectors to our office in Shenzhen, and the people there can send you one or two pcs. Just message me you name and address, and I will see what can be done within a few days.
I am in our Bangkok office just now, and travelling to Norway tomorrow. So I will be "out of service" then for a couple of days.
HobbyEUSZ
www.hobbyeurope.com
HobbyEurope is offline Find More Posts by HobbyEurope
Old Sep 16, 2012, 09:10 AM
macem is offline
Joined Sep 2012
www.hobbyeurope.com
... very nice - i will send you some details. for the hisky-connector did not match any standard-size of micro-plugs in the market i found in the past few days ... sure i passed some shops, but to play it safe it would be graet to get it from hisky directly...
impressed of your customer-service...
macem
Old Sep 18, 2012, 04:32 AM
dragonal is offline
Find More Posts by dragonal
dragonal's Avatar
Turin, Italy
Joined Jun 2003
Hello
i have a serius issue....whiy motor lock the servo answer ist corret,move and when relase stick ist return to 0 position.Whit motor active (flying...)when the servo was moved by stick input not return at 0 position when stick retun at initail position.....this made hely not flyable...
This is my problem...ist my first FBL ...i talk with HK support and told me this is "normal" bheaviour for this kind of hely...
Ist true?.......
dragonal is offline Find More Posts by dragonal
Old Sep 18, 2012, 10:20 AM
macem is offline
Joined Sep 2012
Originally Posted by dragonal View Post
....Whit motor active (flying...)when the servo was moved by stick input not return at 0 position when stick retun at initail position.....
Ist true?.......
yes... the fbl-system tells the servos to be in position, until the steering-commands are executed. but i guess, to watch servo-moves during "flying" (!! !!) you had to fix the heli yet. so it was unable to follow the steering commands, even the poor servos tried and tried and tried to move the little bird....
this could have nasty effcts when lifting the heli. the fbl-system will tilt it over suddenly, if you gave (at the first unfollowable) stick-commands as long as the heli is at the floor... for the servos are in position, until the steering commands are executed...
macem
Old Sep 18, 2012, 01:24 PM
Norway
Joined Feb 2011
macem
Message from HiSKY about the female plugs:
" I've just sent them to Shenzhen.
Tracking No. is 661 ..9451970, it will get to SZ at this afternoon, pls have a check."
Message from our SZ office:
"I will send the Hisky 10pcs mini female white connecters to Norway on today, Tuesday."
HobbyEUSZ
www.hobbyeurope.com
Old Sep 18, 2012, 02:05 PM
macem is offline
Joined Sep 2012
wow ...
thanks a lot, macem
Old Sep 19, 2012, 04:04 AM
dragonal is offline
dragonal's Avatar
Turin, Italy
Joined Jun 2003
hi Macem
"flyng"is on my hands...because i want understnd this behaviour...
"in flight" ie rotor active but hely in my hand
Input stick -> plate moves -> i move the heli follow command -> release the stick-on plate stay in -> to return the plate to its original position reverse command
this is my question..ist right?...
Old Sep 20, 2012, 12:13 PM
macem is offline
Joined Sep 2012
hi Macem
... with fbl-system, the plate (= servos) always returns itself to its center-position after both turn-around and release the sticks (flybared helis respond differently...). but the heli (cp-heli), not the plate, is in another position now. you have to give reverse commands to return the heli to the initial position ... (this is unlike to the behavior of an coaxial-heli, or most fixed-pitch helis...)
macem
Old Sep 21, 2012, 06:32 AM
dragonal is offline
dragonal's Avatar
Turin, Italy
Joined Jun 2003
thks
THIS IS THE POINT..i have the impression that not happens... (flybared helis respond differently...). but the heli (cp-heli), not the plate, is in another position now. you have to give reverse commands to return the heli to the initial position ... (this is unlike to the behavior of an coaxial-heli, or most fixed-pitch helis...)
macem
in red my idea.........
Old Sep 21, 2012, 07:24 AM
macem is offline
Joined Sep 2012
.. ok .. i unterstand what you mean...
i guess, its hard to simulate the turn around by hand and make the fbl system believe the stick commandos have been executed... my expirience: mostly the fbl-system seems to be on a blink at the ground, but works well in the air...
macem
Old Sep 28, 2012, 03:44 PM
Norway
Joined Feb 2011
wow ...
thanks a lot, macem
Not received any further message ... ?
Anyway; this plug can be found here: http://www.throttlestore.com/spare_p...).aspx?lang=EN
HobbyEUSZ
www.hobbyeurope.com
Old Sep 28, 2012, 04:17 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
what ever happened to the 80?
indoorheli is offline Find More Posts by indoorheli
Old Sep 28, 2012, 04:43 PM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
I'm almost too scared to say it, but they are probably still figuring out how to duplicate the board from the nano cp x, then change it's shape and call it new improved tech...LOL.
Anyway, for $80 bucks or so with a module, I'd still like to give it a whirl.
skeppley is offline Find More Posts by skeppley
Old Sep 29, 2012, 06:11 AM
Norway
Joined Feb 2011
Planned launch of FBL80 was before the Mid-Autumn Festival (15th day of 8th lunar month), which starts today, 2012.09.29, in China.
Completion of the final hard testing program revealed too much vibration in the tail, so the FBL80 will not be available before after the Mid-Autumn Festival.
HobbyEUSZ
www.hobbyeurope.com
Sold $SOLD Trex 500 FBL clone Tarot 500 frame, Align FBL head All ALIGN Electronics CHEAP! paulpeffly Aircraft - Electric - Helis (FS/W) 10 Feb 02, 2012 11:36 PM
Sold $375 OBO - Trex 500 FBL clone Tarot 500 frame, Align FBL head All ALIGN Electronics paulpeffly Aircraft - Electric - Helis (FS/W) 0 Feb 01, 2012 09:48 AM
Discussion New competition for MCPX/Genius. Esky FBL 100 w servo driven tail and a 4-blader! GetterDragun Micro Helis 12 Dec 19, 2011 10:17 AM
Discussion Next step CP FB or FBL heli spectre6573 Micro Helis 10 Jun 05, 2011 12:46 PM
Sold Blade CP Pro CP+ complete with extra parts, plus other heli's and heli 'stuff' bubsnews Aircraft - Electric - Helis (FS/W) 1 Mar 15, 2011 02:40 PM
