Old Feb 06, 2012, 09:57 AM
crd is offline
crd
Find More Posts by crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Fpv 27x zoom day/night color camera
Ok I bought (2) of this cameras for $65 each to test it on my Skywalker, have anyone tried this camera yet? it looks promising.
The model # ZP-270DN comes on google as a Police Car Camera and it looks like the ones I have seen here in Florida police cars so quality must be good. For $65 Shipped was a no brainer, I can have a servo set for pushing the button in the back for zoom.
The feedback about this camera are very good, everyone seems very happy with it. $65 Shipped for 480 lines of resolution, 27x optical Zoom, mirror mode, date stamp on/off, camera name on/off and more.
Features
Optical 27 x Power Zoom (Digital 10x)
True Day & Night (IR Cut-filter removable) "That's interesting
WDR (Wide Dynamic Rage)
Real Big Buttons
Compact and light weight
DC 12V
Signal System NTSC
Scanning System 2:1 Interlace
Scanning Frequency (H) 15.734 KHz
Scanning Frequency (V) 59.94 Hz
Sync System Internal
Effactive Pixels No 768 (H) x 494 (V)
S/N Ratio More than 48db (AGC Off)
Resolution Horizontal: 480 TV Lines
Video Output Level 1.0 Vp-p (75 Ohms, Composite)
Min. Illumination Day (0.3 Lux), Night (0.1 Lux)
Back Light On / Off
Day/Night (ICR) Auto / Day / Night
Lens 27x Optical Zoom
WDR (Wide Dynamic Range) On / Off
Shutter Speed 1/60 ~ 1/10,000 Sec
White Balance Auto
OSD (On Screen Display) On / Off
Camera ID/Zone Label On / Off
Mirror/Freeze/Nagative On / Off
Supplied Voltage DC 9V ~ 15V (Recommendation DC 12+0.5V)
Power Consumption 350mA / Max. 4.2W
Dimension (WxHxD) 63.9 x 57.6 x 124.6mm
http://www.ebay.com/itm/260866557541...#ht_3079wt_952
crd is offline Find More Posts by crd
Old Feb 06, 2012, 10:28 AM
gregor4711 is offline
Find More Posts by gregor4711
Germany
Joined Feb 2007
thanks for the link,
did you found any whight numbers? Looks havy, mayby 200-400g
12V should be not a problem, in case you use a 3S Lipo.
Driving the zoom, can become a chellange. I saw a video on youtube where such a funktion was in the video but no idea how it was working.
Also my first idea just glue 2 micro servos on the case and lets the servos press the buttons , or you have to open the case and try to find out how you can use your TX.
Whould be happy if you can check the wight.
Gregor
gregor4711 is offline Find More Posts by gregor4711
Old Feb 06, 2012, 10:41 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
hmm I don't know. The resolution is 'more than 480'. Which is decent, but nothing stellar. The only thing that bothers me is that the minimum illumination is stated at 6 lux. During the day it might be fine, but I don't know how it'll handle dusk. For reference, most of my cameras have a min illumination of .5 lux.
ashdec87 is offline Find More Posts by ashdec87
Old Feb 06, 2012, 11:01 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
They might have a typo because the manufacturer has this specs:
Features
Real Big Buttons
DC 12V
Signal System NTSC
Back Light On / Off
White Balance Auto
I have never seen a 6 lux camera, not even cheap ebay ones so that's must be a typo on their auction. This camera retails in other places for $500+ so it must be good. Will see when they get here.
Old Feb 06, 2012, 03:10 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
I have seen security cameras sell for $500+ and then found that they have the same Sony CCD chip inside as some of our board cameras for $120. Its often the packaging and zoom lens and so on that drives the price up.
You can't really use much zoom without stabilization. The image shakes around so much its unusable. As far as I know, there isn't any hobby level image stabilization systems available.
philthyy is offline Find More Posts by philthyy
Old Feb 06, 2012, 03:42 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
That would not be a problem since I design and sell camera mounts, www.claserdesigns.com and I'm now entering into stabilization and larger camera mounts. It will be a good challenge for me. I can always use them on my spy car that I'm building
Old Feb 11, 2012, 09:10 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Ok I received the cameras and took one apart to remove all the metal possible, now it weights around 160grams, I'm still looking for a servo channel controlled switch for the zoom.
This will be installed on my Skywalker with a custom Pan/Tilt 600mw 5.8ghz VTX and Cloverleaf antenna.
The camera while is in 27x zoom is not shaky, it might have some sort of mechanical stabilization system inside, I dont know.
Here is a little video (OSD can be eliminated but in this video I have the Zoom X showing)
Option I tried are:
Mirror
Negative
Mechanically removed IR sensor and switches to black and white
Rec Feb 10,2012 07 48pm (0 min 50 sec)
Old Feb 11, 2012, 10:26 AM
philthyy is offline
UAV Integrations
Joined Nov 2005
Most block cameras use RS232 to control zoom and focus. I think there are PWM to RS232 converters commercially available. I would check DIYDrones. This is a very cool project and one I've always wanted to try. Good luck!
Old Feb 11, 2012, 10:30 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
hm not to bad at all. Try it outside and see how it handles that. Lots of cameras look great inside, but at flying distances, not so much.
Does seem promising. Doesn't get grainy on zoom or anything.. nice find.
Old Feb 11, 2012, 12:56 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
I ordered one to experiment with....
galaxiex is offline Find More Posts by galaxiex
Old Feb 11, 2012, 02:24 PM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
as it says in the auction, it's a 1/4 inch sensor, and 6 lux minimal sensivity.. quite low-end numbers if confirmed
GliderLover is offline Find More Posts by GliderLover
Old Feb 11, 2012, 02:57 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
This one is meant for police car installations, no rs232 inputs/outputs.
Old Feb 11, 2012, 03:01 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
The camera outside works great, I will post better videos later today. The camera mechanicly removes the ir filter and converts to black and white, it has sharpness feature and a lot of other settings. I will try to record all the features.
I think 6lux is a typo, resolution is like any other Sony CCD camera outthere but with more features.
Old Feb 11, 2012, 03:22 PM
gizmointhesky is offline
Find More Posts by gizmointhesky
Love is the message
gizmointhesky's Avatar
gizmointhesky is offline Find More Posts by gizmointhesky
Old Feb 11, 2012, 04:13 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Here is a little video on the outside, keep in mind that it was recorded on a mini dvr edited and then uploaded to youtube
Rec Feb 11,2012 04 54pm (1 min 39 sec)
Yippee! TINY FPV ZOOM 10X CAMERA VIDEO !!! Incredible FPV camera with zoom capability. JettPilot FPV Talk 19 Mar 03, 2016 09:38 AM
Discussion 27X Zoom Camera Hack Blue Sky FPV Talk 29 Jun 23, 2011 05:47 PM
Sold 540 Line Color Camera/Night vision, 12v @ 75mAh...$50 Shipped crd FPV Equipment (FS/W) 8 May 12, 2011 09:56 AM
For Sale FPV 1/3 Sony CCD Color Camera with zoom lens / fixed lens crd Aircraft - General - Miscellaneous (FS/W) 0 May 20, 2010 11:48 PM
Sold FPV 1/3 Sony CCD Color Camera with zoom lens / fixed lens $50 Shipped crd Aircraft - General - Miscellaneous (FS/W) 2 May 20, 2010 09:25 AM
