Old Feb 17, 2013, 04:12 PM
teflon97239 is offline
Find More Posts by teflon97239
teflon97239's Avatar
United States, OR, Portland
Joined Aug 2011
Originally Posted by Thetis View Post
Interesting..!
I like your keychain cam on top like that because it sits right-side-up, and up there it doesn't interfere with battery install/removal/connection, etc.
So my big question is regarding field of view:
Is the lens view so wide that it sees the spinning rotors? Or is it sufficiently narrow to shoot clean video in between them? I used a keychain cam on my plane and had to try a lot of creative mounting locations to avoid shooting through the spinning prop (which really diminishes image quality).
Maybe different with a rotor? Perhaps not an issue at all?
teflon97239 is offline Find More Posts by teflon97239
Old Feb 18, 2013, 02:46 PM
IndiaHobby is offline
Find More Posts by IndiaHobby
Fly and Drive RC
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
Originally Posted by superfets View Post
Love the 1SQ packaging canopy. Gonna do that for sure. But here's what I've been up to. Gonna finish it this weekend and see how it goes.
Nice looking set-up!
Is that FPV camera sending live video feed to you while flying? If so, where did you get your micro vTX/vRX?
IndiaHobby is offline Find More Posts by IndiaHobby
Old Feb 18, 2013, 04:49 PM
SJMarty is offline
Find More Posts by SJMarty
SJMarty's Avatar
United States, FL, Jacksonville
Joined Aug 2012
Also, what camera is that you are using? The fisheye makes it look huge!
SJMarty is offline Find More Posts by SJMarty
Old Feb 18, 2013, 05:33 PM
Sinewavz is offline
Find More Posts by Sinewavz
Test Product Destroyer
Sinewavz's Avatar
United States, CA, San Diego
Joined Feb 2013
Nice job guys! I love having my mqx for the indoors and local park flying. Been modding mine since the day I got it. Now this is how is sits...
Custom Canopy w tape to help orientation
Extended thruster booms
GWS props en route to me too
Shaved off battery cage and make a Velcro set up. One for just carrying a bigger battery (1s 3.7v 600), and one to carry both battery and 808 camera with foam insulation for vibration canceling
Description:
Description:
Description:
Description:
Love seeing new creations! Keep em coming!
Sinewavz is offline Find More Posts by Sinewavz
Old Feb 18, 2013, 06:25 PM
Sinewavz is offline
Sinewavz's Avatar
Joined Feb 2013
I have noticed less prop wash from extended thruster booms also. and ive noticed with my round tight to frame style canopy, it also reduces the prop wash dramatically. i can drop from 150 ft to a hover 1ft off the deck a LOT easier...almost no prop wash or violent sway. I also glued the main gears to rotor shaft so if I meet something in the air (bird,tree,pole..lol), I don't come down and loose a gear. It has worked sooo many times so far!
Old Feb 19, 2013, 04:49 AM
c7x is offline
c7x
Find More Posts by c7x
c7x
Joined Apr 2012
Here's my mQX TARDIS flying at the Doctor Who convention in Los Angeles over the weekend.
TARDIS quadcopter at Gallifrey One 2013 (0 min 17 sec)
c7x is offline Find More Posts by c7x
Old Feb 21, 2013, 10:42 AM
Sinewavz is offline
Sinewavz's Avatar
Joined Feb 2013
Made a new canopy! Looks almost like the first but bigger cause I can't see the damn thing at 150+ ft! Lol also put mesh on the top to colorectal board from leaves and such as I like to "buzz" everything I see, and added a window in the back to see the blue light(looks awesome at night. Still looking for an LED kit using the existing battery. Using disc golf beacon lights velcro on each arm...not $ efficient...$18 a set.
Description:
Description:
Old Feb 24, 2013, 01:30 PM
Sinewavz is offline
Sinewavz's Avatar
Joined Feb 2013
Broke my motor power wires (cheap pieces of sh!) so I broke out the solder gun and bang! Using RJ45 (cat5) twisted pair and some heat shrink. I think it looks better with the wires showing rather than through the boom. Added a led too straight to the board just for the heck of it. Got it from a brookstone (broom it up after)piece my son trashed.Tell me what you think.
Description:
Description:
Description:
Description:
Old Feb 25, 2013, 12:01 AM
Joined Aug 2011
I'm running my nav lights inside a clear body, moving them around in there with scotch tape until I settle on where I want them permanently for the best night orientation, then I'll move them to the airframe like you did. That will let me swap out bodies and not worry about wires.
Mine run on the main battery, and I see no extra drain there. Here's where I got them:
SF Design Solutions: "Taking the ultra-micro to the dark side" www.sf-design-solutions.com
Old Feb 28, 2013, 12:15 PM
variantman is offline
Find More Posts by variantman
United States, TN, Knoxville
Joined Jun 2012
http://www.youtube.com/watch?v=1SIDK3bStv0
Nice. Now you need a tx with a Doctor Who scarf as a neckstrap.
variantman is offline Find More Posts by variantman
Old Feb 28, 2013, 07:48 PM
Sinewavz is offline
Sinewavz's Avatar
Joined Feb 2013
Took my new props out for a spin in 15+mph winds and they work damn well! Just needed a good balancing(a lot actually) and now wow! Fast throttle!
Also, I put stock booms back on for weight w the magnet wire again. Just did the GWS blades...what a difference! Now if only banggood would not F up their orders!! I bought 4 sets (not pairs, sets of 4) and they sent me 1 complete set and the rest are all CCW! Emailed them today and awaiting response. Checked my order invoice too and I'm right...BAD Banggood!!
Old Feb 28, 2013, 08:47 PM
jbarchuk is offline
Find More Posts by jbarchuk
DeBary, FL
Joined Nov 2010
By how much? By the space between the brick and the prop tips I'm guessing 1" each, 2" added to the diameter? That would be a good starting point to try, about 25%.
jbarchuk is offline Find More Posts by jbarchuk
Old Mar 01, 2013, 01:02 AM
Sinewavz is offline
Sinewavz's Avatar
Joined Feb 2013
That's a good starting point for sure. I just decided to go back to stock as the extended would crack from the stress I was putting them through from hard banks. Good for hovering though.
Old Mar 05, 2013, 07:18 PM
wing_man is offline
Find More Posts by wing_man
USAF Retired
wing_man's Avatar
Stockton, NY
Joined Jul 2001
Dollar Tree UFO
This is a pic of my $1.00 fuse. I couldn't find one with a clear top except one that was about three times the size. Got to love the Dollar Tree... Waiting for my aliens to arrive!
Out here.
Dennis
wing_man is offline Find More Posts by wing_man
Old Mar 05, 2013, 08:01 PM
Blackanthem is online now
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
This is my Key cam set up
Description:
Blackanthem is online now Find More Posts by Blackanthem
Discussion Help with Alternate Canopy JHawk19 Micro Helis 4 Oct 06, 2011 02:47 PM
Discussion Alternate Brushed motors for PKZ Micros msdumo Power Systems 5 Sep 21, 2011 02:21 PM
Discussion PKZ Ultra Micros - Alternate motor discussion msdumo Micro Ready-to-Fly 4 Sep 17, 2011 03:48 PM
Discussion COAX Scale bodies and mods gbruce Scale Helicopters 6 Dec 20, 2007 05:09 AM
Alternate bodies on H-II gstew Micro Helis 8 Mar 28, 2004 12:24 AM
