Old Feb 05, 2012, 06:43 PM
Ursine is offline
Find More Posts by Ursine
Ursine's Avatar
Central Florida, United States
Joined Jan 2004
DIY GoPro2 mount for 450 Flamewheel
After playing with AP on my Slowstick and Trex, I wanted to give a quadrotor a try. About a week ago I got a Naza 450 kit. After seeing how stable the quad was I knew I had to slap a camera onto it. I bought a GoPro2 HD and fired up the laser cutter. I cut a piece of 1/4 inch lite ply in the shape of the bottom frame plate. I wanted it to sit flush with the base so I cut holes for the screw heads. I used some small vbration isolators to mount a small piece of acrylic to the plywood base. I used acrylic for better adhesion with theGoPro mounts. For added isolation I cut the same pattern in a piece of 1/4 inch craft foam. Everything is tie wrapped (just snug) through the slots in the frame base.
I'm using 6 inch tall pieces cut from a pool noodle to raise the platform. They're tiewrapped through slots in the motor bases.
The pool noodles do give it a bit more of a wind profile. If it proves to be a problem I can mount some thin aluminum landing gear directly to the mount.
I just came back from a test flight. The footage is pretty noisy because it's dark out, but from what I can see it looks pretty smooth. I'll try again tomorrow.
Dave
Ursine is offline Find More Posts by Ursine
Old Feb 05, 2012, 09:45 PM
Canada Goose is offline
Find More Posts by Canada Goose
Canada Goose's Avatar
Canada, AB, Lethbridge
Joined Jun 2002
Looking good Dave, keep us posted!
CG
Canada Goose is offline Find More Posts by Canada Goose
Old Mar 03, 2012, 07:13 PM
Paltik.45acp is offline
Find More Posts by Paltik.45acp
United States, CA, San Diego
Joined Nov 2011
How's the result of your mount, I have the same frame and I want to do the same thing. Thanks Dave.
Mark
Paltik.45acp is offline Find More Posts by Paltik.45acp
Mini-HowTo DIY Cascade Tail Rotor for AH-64 Apache (450 size) BlackTitanium Scale Helicopters 4 Sep 28, 2014 04:47 PM
Sold DJI Flamewheel 450 + 2830-13 850Kv Motors FE Obsessed Aircraft - Electric - Multirotor (FS/W) 2 Jan 29, 2012 11:13 AM
Question My FlameWheel 450 Quad sharonx Multirotor Talk 16 Jan 27, 2012 01:14 PM
Discussion Easy -Simple Camera Mount(DIY) -The Flight Test Samples.. guyg Aerial Photography 9 Oct 16, 2011 01:47 PM
