Old Oct 31, 2001, 07:37 PM
budorren is offline
Find More Posts by budorren
Desert Rat
Rancho Mirage. CA
Joined Jul 2001
What Prop For Sp-400 On Yard Boy
I just completed my second Clancy Yard Bee, but this time I have a geared speed 400 and a 7x600 Nicad pack. I now realize that the old prop will not work. What should I use? I tried a 11x7 Master Airscrew Electric and it seems to turn OK but I am wondering if it is too much to fly with. BTW, is the 7x600 too much? Bud Orren
budorren is offline Find More Posts by budorren
Old Nov 01, 2001, 08:39 AM
zax is offline
zax
Find More Posts by zax
zax
Dallas, Texas, USA
Joined Sep 2001
Oh, a Yard Bee...
What gearing do you have ?
If it's 3:1 then you'll probably want less pitch, maybe a 11x4.7 or something in that range.
Zax.
zax is offline Find More Posts by zax
Old Nov 01, 2001, 11:05 AM
budorren is offline
Desert Rat
Rancho Mirage. CA
Joined Jul 2001
Thanx Zax- I haven't counted the gears, but the drive came with three small gears and I used the middle size.. I wonder about the weight of the 7x600 Nud
Old Nov 01, 2001, 11:21 AM
JREEVES is offline
Find More Posts by JREEVES
Wayward Pilot
JREEVES's Avatar
USA, FL, New Port Richey
Joined Sep 2001
I ran a search and came up with this link for a couple of Yard Bee's, no prop size, but both running direct drive s400's on smaller props. I'd guess you're over-powering it with a geared s400 and your ground clearance looks limited to less than an 11" prop anyway. Jim
http://www.rcshowroom.com/gallery/clancy/
JREEVES is offline Find More Posts by JREEVES
Old Nov 01, 2001, 01:58 PM
zax is offline
zax
zax
Dallas, Texas, USA
Joined Sep 2001
The gears are most likely 2:1, 2.5:1 and 3:1 (guessing), in which case you've used the 2.5:1...
What kind of performance/flight are you after ?
If the ground clearance won't run to an 11 inch prop you might try a 9x6 or similar.
Zax.
Old Nov 01, 2001, 02:32 PM
budorren is offline
Desert Rat
Rancho Mirage. CA
Joined Jul 2001
Zax-I am very fussy. I like to see a plane takeoff, fly around, and land in shape to do it all over again. Anything more is overkill. Anything less is unacceptable. Bud
Question what prop for a microdan 2505 on 4s ? skyking1231 Power Systems 1 Jun 28, 2007 04:24 PM
Question What prop for 3:1 gear drive on Wingo michaeljt Foamies (Kits) 2 Mar 06, 2004 09:22 PM
What is a good all around prop for speed 400? randall1959 Beginner Training Area (Aircraft-Electric) 6 Feb 16, 2004 12:46 PM
what gear/prop for razor 400 w/ 2S packs? birdie_in_texas Power Systems 8 Jan 12, 2004 10:02 PM
Need light weight folding prop for sp 400 aireze Electric Sailplanes 3 Oct 26, 2002 12:21 AM
