United Kingdom, England, Bristol
Joined Aug 2011
If you want, I can post you both a PicoBlade Molex (micro connector) female to male standard servo connector and a PicoBlade Molex (micro connector) male to female standard servo connector. So you can test the servo on another, standard receiver and also test the micro receiver with a standard servo. If so, let me know and I'll put them into the post tomorrow. |
Servos The ESC seems to be a hobbywing 6A plush, not entirely sure though. I'll just fly it, shouldn't affect flight much I hope ![]() Quote:
Joined Feb 2011
HK has micro servos which are labeled 5V and carry an explicit warning that they will burn up on anything more. Considering those are labeled 2.8V/4.2V it would not surprise me if they are having a voltage problem at 5V.
Well that was uneventful
![]() No problems whatsoever, a bit of right and up elevator trim and it flew hands off. The twitching doesn't affect flight in any way so that's a moot point now. I didn't fly it more than 100m away, it's just too small to go further than that. AUW is right around 60g so it's a floater. I prefer it over the fox, it's faster, more agile and tracks well even without the motor on. Much like the funjet actually. Oh right, the receiver preformed flawlessly :P |
Joined Aug 2011
If the other guys that bought receivers want the Pre-crimped Molex leads, let me know by just PM'ing me your address too. Postage to the US is £3.30. All future receivers I'll sell personally will have them included (unless stated otherwise). Quote:
![]() Interesting in regards to those servos. I've bought a bunch to go into a Hobbyking 30mm Mig-15 and also used one in the receiver demo video earlier. Never appeared to have a problem with them on my 1.5v Alkaline test pack - however that could have discharged below 5v. Quote:
?. Great to hear that its all going well for you too. I would point out again that these are parkflyer range receivers and when tested on a 880mm plane with the receiver connected to a lost model alarm, I could get the beeper to beep (loosing packets) at around the 300m distance (cross referenced with a GPS data logger and timestamped video). However even with a 880mm span plane, it was far enough out to make it very uncomfortable to fly. So small planes (~<400mm wingspan) and indoor flyers are the most suitable for this receiver. To be honest, any bigger than this, the weight penalty from a Minima would be minimal and not a concern anyway. Remember the distance is line of sight, so according to Pythagoras theorem, 250m away at 100m high, its 269m away - which would be getting close to the range limit (and eyesight on a small plane). I've just put 7 more on order with Hobbyking and waiting for them to be posted. ![]() Usually take around 2 to 2.5 weeks to get here from the time the order is placed - depending how long it takes for HobbyKing to ship. Cheers, Si. |
Joined Aug 2011
Personally, if they do sell, the cash from the sale would pay some towards a Futaba 6J S-FHSS - the next radio system on my sights for reverse engineering. Or maybe the Graupner system? Not sure quite which to target next. I reckon the Futaba system may (bit too early to say for certain) get a good market penetration, as its a good starter system that I can see die-hard Futaba fan model shop sellers could flog with trainers. Also I know from my own model club, some of the older folk are stuck on 35MHz and refuse to move - but that may be down to them wanting a Futaba system and not wanting to pay a lot! If your not prepared to pay a lot of for a transmitter, then I guess your not prepared to pay a lot for receivers. Perhaps I should get a poll going to see which next to target.
Joined Feb 2011
Never seen anyone using Graupner here in the US. The Futaba S-FHSS is pretty new, most of the die hard Futaba fans are already running FASST, but then again those are people who buy Futaba for the brand and are not likely to buy a "compatible" rx over the name brand.
Joined Aug 2011
I was probably thinking more also with a commercial hat on. In the UK already, the Futaba distributor (Ripmax) are already going to ship FTR (Futaba Transmitter Ready - i.e. Bind n' Fly) S-FHSS aircraft. No doubt to try and compete with Horizon offerings. This may be an aim to try and help boost Futaba sales in the UK and I believe the US Futaba distributor is trying to do the same. Also Hobbyking are doing similar Bind 'n Fly packages too - so far it appears for Spektrum only though. So I reckon a receiver that supports both Futaba and Hitec (plus any other CC2500 based systems) could potentially have a good OEM market for the alternative Plug 'n Fly manufacturers. Purely as an example (I have no connection with HobbyKing), the RadJet 420 could come either in a Spektrum/Multiplex (plus other Cypress chipset users) or a Hitec/Futaba/Graupner/FrSky Bind and Fly style package. Having multiple system compatibly in one boxed package would reduce the level of stock a seller would need and start to allow users to swap between 2.4GHz manufacturer. Also, for example, a user starts off with a [pants] Futaba 6J and decides that they want to upgrade, they could switch to an [awesome] Aurora 9 without having a load of useless receivers. ![]() Of course the flip side is that breaking the "not able to use other brand 2.4GHz stuff together" rule, could confuse users - especially if the split is based on the chipset used. I should imagine most users are completely obvious on what is going on inside the black boxes and don't really care much either - unless they frequent the Radios section on RC Groups of course. ![]() The other thing is that I'm really interested to see how other manufacturers implemented their 2.4GHz technology and how it compares across them. Out of interest, does any one know what chipset the Hobbico AnyLink uses (not that we can get it in the UK, yet)? Also if anyone has any of the Chinese receivers around, it would be awesome if you could pop the lid and see if it uses a CC2500 or CC2510 chip? I know the RadioLink stuff uses a CC2500 but they have scrubbed the markings off the main microcontroller, so I can't tell what it is, to be able to reprogram it. What does the Assan, Corona (I think this is a CC2500 - but no idea on the main microcontroller), Turnigy (FlySky) and Hobbyking receivers use? I'm on the look out for other good quality full-range receivers that could be a potential to convert! Cheers, Si. |
USA, WA, Seattle
Joined Oct 2005
Si, here are some picts of the 4 channel Assan. Unfortunately the chips have their markings scraped off.
Too bad as I would love to have a Hitec compatible version of this. It is a 3g receiver and has normal servo pins which is great for most of my planes.If you think you could actually make it work, I'll send you one to play with. |
| Thread Tools | |
| Question Hitec 2.4GHz compatible receivers | G_Wright | Radios | 1 | May 09, 2011 06:02 PM |
| Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver | lrplin | Aircraft - General - Radio Equipment (FS/W) | 2 | Apr 18, 2011 12:07 PM |
| Discussion OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver | WSWitby | Electric Plane Talk | 2 | Apr 05, 2011 07:30 AM |
| Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver | lrplin | Aircraft - General - Radio Equipment (FS/W) | 5 | Mar 30, 2011 05:35 PM |
| Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver | lrplin | Aircraft - General - Radio Equipment (FS/W) | 0 | Mar 28, 2011 03:38 PM |
