Old Sep 17, 2012, 12:53 AM
roguetrooperau is offline
Find More Posts by roguetrooperau
Joined Jul 2011
HK now have a Hitec section in the Rx's area.
http://www.hobbyking.com/hobbyking/s...idCategory=701
http://www.hobbyking.com/hobbyking/store/__27174__FrSky_2_4Ghz_A_FHSS_Compatible_5CH_Micro_ Receiver_Hitec_Minima_compatible_.html
Interesting on two levels:
1) Frsky might had got the idea from here?
2) Who want to test it out and see how it compares to Simon's code!
roguetrooperau is offline Find More Posts by roguetrooperau
Old Sep 17, 2012, 01:06 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Your first link above is broken.
Frsky receivers runs Simon's code.
renatoa is online now Find More Posts by renatoa
Old Sep 17, 2012, 01:19 AM
Joined Jul 2011
Link above fixed ....
Nice work Simon and Frsky!!!
Old Sep 17, 2012, 02:25 AM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Compatible with Minima radios??
4*60 is offline Find More Posts by 4*60
Old Sep 17, 2012, 02:33 AM
Joined Sep 2007
HK Chinglish
Fortunately, the manuals are written by Simon himself, and are very well done.
Old Sep 17, 2012, 03:05 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
What about the 8-ch? Are those by Simon too? Are the voltage telemetry, SPC and data port available there too?
chewy
chewytm is offline Find More Posts by chewytm
Old Sep 17, 2012, 04:15 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Couldn't possibly (or allowed to) comment if I'm involved or not.
I know if I was involved with it, I would be pretty annoyed that they put the text Minima on them... The word doesn't appear to be a trademarked word in the context of receivers, however you have to be a bit careful that there isn't any confusion that they are made by Hitec or not.
Seem a pretty good price once you put the logged in discount on.
Cheers,
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Sep 17, 2012, 04:19 AM
Radio? Screwdriver!
Joined Aug 2011
chewy
Again, see statement above.
However I would have thought that, as they are Minima compatible, they are non telemetry receivers. The Hitec Minima line is non-telemetry. The problem with telemetry is that it requires extra regulatory radio type approval (i.e. FCC, CE, etc testing) which is more expensive than just the basic EMC (electromagnetic compliance) testing - that a receive only receiver requires.
I'm sure if those sell well, that telemetry receivers could be next in the pipeline.
Si.
Old Sep 17, 2012, 05:37 AM
Radio? Screwdriver!
Joined Aug 2011
Originally Posted by eosglider View Post
Si,
How confident would you be to place one of these in a DLG?
Sorry, almost missed this.
No I wouldn't recommend putting the micro based version in anything larger than 500mm wingspan - especially as a glider your likely to be soaring pretty high.
I was hoping to convert the V8R4-II - which should fit nicely and (I believe) it has a preamp - so would be full range. However HK sent me the old version 1 instead which uses a different chipset not compatible with the existing firmware.
If this fits, it would be suitable. According to my calipers, out of the case the PCB is 20.5mm x 9.6mm x 42.5mm - including the end pins.
Cheers,
Si.
Old Sep 17, 2012, 08:36 AM
chewytm is offline
Joined Jul 2006
Si.
FrSky has quite a number of telemetry certified rx. I think changing the protocol will NOT invalidate the FCC certification of the RF section, accroding to Jim Drew of XPS fame. Why not use one of these telemetry capable rx to mod for the Optima series instead? I would buy a few of them in a heartbeat!
I thought you have already decoded the telemetry functions for your version ( and maybe FrSky's too) of the Optima.
chewy
chewy
Old Sep 17, 2012, 09:04 AM
Radio? Screwdriver!
Joined Aug 2011
The FrSky receivers operate at different frequency channels, bandwidth, modulation type, etc than the Hitec system. So the FrSky technical file for their receivers would be different for one that works on the Hitec system. So it would require a retest to be legal. For CE-approval (and not FCC, which is more expensive and be in addition), at UK prices, your looking at around the 4000 (~$6500) mark to just have the RF tested and report written for the technical file. So this would obviously be a factor that needs to be considered.
I've got a working telemetry receiver firmware for the same chipset as in the Minima equivalents as a proof of concept. However the FrSky telemetry receivers use a different processor (ST Micro ARM based device) than in the non-telemetry receivers (TI CC2510). Hence it requires a rewrite/port of the firmware to support this processor. I have started to do this (and also a Futaba S-FHSS compatible receiver), but recent work commitments have prevented me from finishing this just yet.
Cheers,
Si.
Old Sep 17, 2012, 09:09 AM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
That doesn't quite make sense. An RX requires no FCC certification in the first place, so invalidating something that doesn't exist...
If FCC requires a cert on any TX, and you put a TX on the receiver for telemetry, then it would now be in their jurisdiction.
He must mean that the whole RF link requires a cert, and once certified, a protocol change doesn't invalidate it. I would imagine that the telemetry rx/tx portion would still need to be in the original cert, though.
CE is a euro thing, and has no bearing on US products, unless they are sold in Europe. It's just a scam to keep small businesses out of their markets. We sell sat equip to Europe, and pay $10k -$20k per product for CE certification; and that's for non-transmitting equipment. Most of that cost would still be there if we were selling a $15 desk lamp...
jtaylor996 is offline Find More Posts by jtaylor996
Old Sep 17, 2012, 09:27 AM
Radio? Screwdriver!
Joined Aug 2011
That's the problem. The receive only receivers (i.e. non-telemetry) don't require FCC certification for the RF side. However the telemetry receivers have a transmit section in them too. Hence require certification.
I prefer CE certification to FCC, and that's not just because I'm sitting on this side of the pond! CE is self certified, so along as you have the equipment and can prove in a technical file, you can do it all yourself. Also I much prefer getting CE approval for the whole of Europe, than having individual requirements for each country in the EU (which would be the case otherwise). The problem with CE approval is that its not very well regulated. Your technical file is only scrutinised if a competitor has tested your product and takes you to court, and/or if the authorities ask for proof. Very few cases exist where this actually happens for most consumer type products.
Where as to get FCC certified, its very expensive to file listings and going to approved testing houses. Even if your widget doesn't require FCC approval, you still need to get the product testing by UL or similar - if you want to be covered by your product liability insurance.
Si.
Old Sep 17, 2012, 11:14 AM
BasTijs is offline
Find More Posts by BasTijs
The Netherlands
Joined Jul 2007
If it is like the minima there should be atleast voltage telemetry from the SPC port.
I'm gonna order a few, they are a factor 5 cheaper than the "real" ones!
BasTijs is offline Find More Posts by BasTijs
Old Sep 17, 2012, 11:22 AM
balesse is offline
Find More Posts by balesse
balesse's Avatar
USA, WA, Seattle
Joined Oct 2005
Minima's don't have any telemetry.
balesse is offline Find More Posts by balesse
Question Hitec 2.4GHz compatible receivers G_Wright Radios 1 May 09, 2011 06:02 PM
Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver lrplin Aircraft - General - Radio Equipment (FS/W) 2 Apr 18, 2011 12:07 PM
Discussion OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver WSWitby Electric Plane Talk 2 Apr 05, 2011 07:30 AM
Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver lrplin Aircraft - General - Radio Equipment (FS/W) 5 Mar 30, 2011 05:35 PM
Sold OrangeRX Orange RX Spektrum 2.4GHz DSM2/X compatible receiver lrplin Aircraft - General - Radio Equipment (FS/W) 0 Mar 28, 2011 03:38 PM
