Old Oct 16, 2012, 01:46 AM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Originally Posted by 747Pilot View Post
Can you describe your setup?
Volts, Camera, UBECS? Etc..
Power from 3s lipo battery connected to video TX, power coming from video TX connected to OSD, OSD connected to Pixim Seawolf camera. No ubecs, only one homebrew LC filter between the battery and the video TX.
icah is offline Find More Posts by icah
Old Oct 16, 2012, 09:48 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by BCSaltchucker View Post
does not have to be. And probably 95% of FPV set ups out there are not using shielded wiring.
However, shielding is a very good idea, and is growing in popularity for FPV. The most common method is to use shielded Cat-6 ethernet cable, and run all your A/V lines throught it, plus even use it for servo leads.
I ordered a bunch of Cat 6, and plan to use it, but haven't received my order yet.
Brilliant idea. I've just rebuilt my plane and have tonnes of wires going all over the place. I have miles of Cat5e lying around doing nothing...
heinduplessis is offline Find More Posts by heinduplessis
Old Oct 29, 2012, 01:20 PM
markeydoo is offline
Find More Posts by markeydoo
Joined May 2008
How can you tell what version it is. i dont think mine is V2.3 because it does not have Unit mode to convert to feet.
I am trying to get it to work in NTSC mode but no success. The OSD display writing is fuzy and is larger than the monitor.
Any suggestions?
I can post a video after work.
Thanks.
Mark
markeydoo is offline Find More Posts by markeydoo
Old Nov 01, 2012, 10:17 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Any suggestions?
Thanks.
Mark
Please check the "menu setting".
If there is has the 4th item:"UNIT MODE"setting,that is OSD V2.3
If there is not the 4th item:"UNIT MODE" that is V2.0
Widelec is offline Find More Posts by Widelec
Old Nov 01, 2012, 11:26 PM
SuperFPVflyer is offline
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
It's pretty misleading that you advertise that you sell version 2.3 but I received v2.0
What say you?
SuperFPVflyer is offline Find More Posts by SuperFPVflyer
Old Nov 12, 2012, 10:36 PM
willieprinsloo is offline
Find More Posts by willieprinsloo
willieprinsloo's Avatar
Joined Oct 2007
Did anybody managed to remove the lines on the OSD's video?
willieprinsloo is offline Find More Posts by willieprinsloo
Old Nov 13, 2012, 11:42 AM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
What say you?
Seems that has happened to quite a few of us...
greedyg76 is offline Find More Posts by greedyg76
Old Nov 13, 2012, 05:21 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Does anyone actually have a v2.3 in hand, or have they just been advertised?
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Nov 13, 2012, 07:41 PM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
Does anyone know if this OSD has a distance limit, I'm looking for an osd that can read past 100 miles/ 160km.
Marc
Pixturethis is offline Find More Posts by Pixturethis
Old Nov 13, 2012, 09:12 PM
Evansville, WI
Joined Dec 2006
You've got an FPV setup that will cover 100 miles, and you want to use a $60 OSD? Am I missing something?
Old Nov 14, 2012, 06:45 AM
Wichita
Joined Dec 2008
I completely understand your comment, but it's not a money thing, Eagletree only goes to 65,535 ft, DOSD only goes to 62 miles, RVOSD will goes that far, but I'm waiting on my third osd from them, due to quality issues. If I could, I would make one, but I don't have kind of knowledge. So the only reason I ask this in about all the osd threads is to get an answer.
So do you know if it has a distance limit?
Marc.
Old Nov 14, 2012, 12:01 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
I have a 2.3, he initially sent me a 2.0 which also had incorrect voltage readings, I returned it and he sent me a v2.3 which still has voltage out by 0.2v but its better than the 0.6v it was out before
MrBen. is offline Find More Posts by MrBen.
Old Nov 14, 2012, 03:24 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
What did it cost you to send it all the way back to Turkey...?
Old Nov 14, 2012, 10:55 PM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
i guess about £5
Old Nov 16, 2012, 07:37 AM
Gamani is offline
Find More Posts by Gamani
Joined Mar 2012
Mine arrived in about 8 days to the UK, I just wired it up and its very straight forward. A couple of questions though.
2) I am powering the OSD through the VTX power, the voltage displayed is 11.4v when in fact a multimeter shows the lipo @ 12.4v, the main reason for buying the OSD is to monitor voltage on my quad so I know when to land, why is it so far out?
Have you found a solution concerning the voltage problem ? i have also 11.4v ...
Gamani is offline Find More Posts by Gamani
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4153 Jun 27, 2016 10:56 AM
Discussion Suppo ESC help??? rotorkilla Racing Boats - Electric 3 Apr 18, 2011 03:38 PM
Discussion Suppo Shuttering kuczy Power Systems 4 Apr 12, 2011 07:42 PM
Help! Looking for Suppo motor GuyP Power Systems 6 Mar 05, 2011 05:34 PM
Sold REDUCED - ESC's - NEW Suppo 60a Opto - Suppo 70a Opto+BEC - $17.50 each shipped. Wingwrecker Aircraft - Electric - Power Systems (FS/W) 4 Aug 26, 2009 06:41 PM
