Old Sep 29, 2012, 06:22 PM
heinduplessis is online now
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Hi Widelec
Both my friend and I ordered this osd, but we are both experiencing bad video quality - thick horizontal lines. I've tried it without any other equipment, still thick lines.
Can we send it back RMA?
heinduplessis is online now Find More Posts by heinduplessis
Old Sep 30, 2012, 12:59 PM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Hi Widelec,
I would like to sent mine back, as well.
It did not warn me for incoming power lines !!!
FPV good luck (0 min 4 sec)
Otherwise, it works fine (V2).
icah is offline Find More Posts by icah
Old Sep 30, 2012, 06:23 PM
Foam Snow
Joined Aug 2011
Originally Posted by icah View Post
Hi Widelec,
https://www.youtube.com/watch?v=Db3PB0-WOW0
Looks like you got lucky there!!
Old Sep 30, 2012, 07:25 PM
Foam Snow
Joined Aug 2011
Originally Posted by heinduplessis View Post
Hi Widelec
There is a difference in the lines when supplying 2 cell vs 3 cell. Is there anything I can do?
Old Oct 01, 2012, 01:05 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Originally Posted by greedyg76 View Post
What difference does it make how our cameras are connected if we got V2.0 after we were told only V2.3 was shipping?
Hello? Anyone? Bueller?
greedyg76 is offline Find More Posts by greedyg76
Old Oct 02, 2012, 10:12 AM
Foam Snow
Joined Aug 2011
When I only supply 5v to the main power input the noise is gone..
Are you all running 12v to the board??
Old Oct 02, 2012, 02:25 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
Has Widelec suddenly disappeared after selling a bunch of bad V2.0 OSD's...?
Old Oct 14, 2012, 08:12 PM
riahut.com is offline
Find More Posts by riahut.com
Joined Apr 2012
Here is my OSD V2.0 wiring:
riahut.com is offline Find More Posts by riahut.com
Old Oct 14, 2012, 08:13 PM
Joined Apr 2012
I'm curious, should be wires between camera and OSD, OSD and TX be shielded?
Old Oct 15, 2012, 01:55 PM
747Pilot is offline
Find More Posts by 747Pilot
It's a job...
747Pilot's Avatar
United States, PA, Warrington
Joined May 2012
Hi Widelec,
Can you describe your setup?
Volts, Camera, UBECS? Etc..
747Pilot is offline Find More Posts by 747Pilot
Old Oct 15, 2012, 02:10 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
does not have to be. And probably 95% of FPV set ups out there are not using shielded wiring.
However, shielding is a very good idea, and is growing in popularity for FPV. The most common method is to use shielded Cat-6 ethernet cable, and run all your A/V lines throught it, plus even use it for servo leads.
I ordered a bunch of Cat 6, and plan to use it, but haven't received my order yet.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Oct 15, 2012, 02:20 PM
Joined Apr 2012
The most common method is to use shielded Cat-6 ethernet cable....
Interesting, but can you explain exact usage? Cat6 has 8 wires, why do I need 8 shielded wires If I need only 2.... kinda waste of weight and wires?!
Old Oct 15, 2012, 04:10 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
I received my replacement pretty quick, this one is a version 2.3, voltage is 0.2v out (better than 0.6v n the last one) and everything seems to be working ok. will post a vid in a bit just uploading
MrBen. is offline Find More Posts by MrBen.
Old Oct 15, 2012, 04:11 PM
fly by night
Joined Sep 2011
you don't need all the twisted pairs necessarily, but might be able to use them anyways for making wire harnesses with the power, AV, servo lines all on the same cable, say, one going out to each wing. Can pull out the excess wires if you want, can also double-up power lines if the load/distance is greater. I do this on my ground station - double wired cat6 for Pos and Neg (runs to goggles, and receivers), then one wire for video, one for audio, so I am using 6 wires.
I also hear there is some nicely shielded USB cable that is a bit smaller with only 4 wires in it. The best Cat 6 has individual metal shields around each twisted pair, though I am going to use the basic single shield type.
Old Oct 16, 2012, 12:07 AM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
here's my test with suppo
TBS Discovery Quad with Suppo OSD (8 min 54 sec)
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4153 Jun 27, 2016 10:56 AM
Discussion Suppo ESC help??? rotorkilla Racing Boats - Electric 3 Apr 18, 2011 03:38 PM
Discussion Suppo Shuttering kuczy Power Systems 4 Apr 12, 2011 07:42 PM
Help! Looking for Suppo motor GuyP Power Systems 6 Mar 05, 2011 05:34 PM
Sold REDUCED - ESC's - NEW Suppo 60a Opto - Suppo 70a Opto+BEC - $17.50 each shipped. Wingwrecker Aircraft - Electric - Power Systems (FS/W) 4 Aug 26, 2009 06:41 PM
