Old Aug 27, 2012, 12:42 AM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
just ordered one
MrBen. is offline Find More Posts by MrBen.
Old Aug 29, 2012, 01:48 AM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Finally an OSD with decent sized connectors instead of those huge molex connectors used on other OSDs. I think I'm going to order one for my smaller models.
cmanley_nl is offline Find More Posts by cmanley_nl
Old Sep 03, 2012, 05:59 PM
747Pilot is offline
Find More Posts by 747Pilot
It's a job...
747Pilot's Avatar
United States, PA, Warrington
Joined May 2012
GPS Question.
Would it be possible to attach a different GPS sensor?
One that is 10 Hz, for better accuracy. Like this one. EBAY
Also has anyone had success using a 5v camera with this?
Either supplied from a separate power source (ie Vtx, UBEC or VR)
747Pilot is offline Find More Posts by 747Pilot
Old Sep 03, 2012, 07:02 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
I'm using a 5V camera(a fatshark/Immersion setup). All I had to do was run the video out wire from the camera to the OSD, then from the OSD to the Vtx. The camera + and - still go to the Immersion Vtx for power and ground.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Sep 03, 2012, 07:08 PM
Evansville, WI
Joined Dec 2006
I've noticed something odd with my OSD, wondering if anyone else has seen it too. When I set "home," my altitude reading zeros out like it should. But, after that, every time I plug it in, the altitude reads 300m and goes up from there. Anyone else experience this? My OSD is buried inside the fuse, so I can't really reset it every time I fly.
Old Sep 03, 2012, 10:13 PM
747Pilot is offline
It's a job...
747Pilot's Avatar
Joined May 2012
Just a hunch, but I believe the altitude display is taken from GPS and not pressure altitude (barometric pressure).
So given the town you live in, the display is reading correctly according to GPS altitude which is a reference to sea level. Evansville is ~300m above sea level.
I believe you said the altitude was reading zero before. Is it capable of being "zero'd out"? Don't own this yet but I do plan on buying one. I just confirmed with a friend today that you can throw on another gps sensor (10hz) for higher accuracy.
Old Sep 03, 2012, 10:27 PM
Evansville, WI
Joined Dec 2006
Yes, if I press the "home" button, it zeros out at my current altitude, and behaves like an altimeter should, using my "home" location as it's zero reference until it's unplugged. I zeroed it today, but if I go plug in the OSD right now, it will read 300m. While it remembers my location just fine, it does seem to remember my altitude.
Old Sep 04, 2012, 11:43 AM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Just like 747 said, when the OSD is first powered up, the altitude displayed defaults to the current GPS location. "home" should be reset every flight to zero the alt to your current location.
greedyg76 is offline Find More Posts by greedyg76
Old Sep 05, 2012, 02:23 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
Quick to ship
Originally Posted by Widelec View Post
will be shipped morning.
ordered on 8/21, just received 9/5 . 2 weeks Turkey to California - Thanks Widelec and BambuCopter!
Old Sep 06, 2012, 03:48 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
You are welcome
Some oversea package shipped from HK.
Europa package shipped from Turkey
Widelec is offline Find More Posts by Widelec
Old Sep 10, 2012, 03:27 PM
747Pilot is offline
It's a job...
747Pilot's Avatar
Joined May 2012
Any luck with it the altitude? What does the manual say? How in depth is it?
I just ordered one 3 days ago from JustGoRc (Not sure why) I think I should have gone with Bamboo.
Old Sep 10, 2012, 04:14 PM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Mine arrived in about 8 days to the UK, I just wired it up and its very straight forward. A couple of questions though.
1) On boot up it states Suppo OSD 2.0, does this mean I dont have the 2.3 version? Also noticed I dont have the option to change between feet & metres which is 2.3 only?
2) I am powering the OSD through the VTX power, the voltage displayed is 11.4v when in fact a multimeter shows the lipo @ 12.4v, the main reason for buying the OSD is to monitor voltage on my quad so I know when to land, why is it so far out?
Old Sep 10, 2012, 05:19 PM
747Pilot is offline
It's a job...
747Pilot's Avatar
Joined May 2012
From my understanding you would have the 2.0 version. The "big deal" with 2.3 is that you can choose ft.
http://www.suppomodel.com/FPV/OSD.html
So if you made an order for the 2.3 version and have a receipt for it, someone has some explaining to do. What website did you buy yours from?
Sorry can't help you on the voltage thing. Have you tried connecting it this way
Lipo--->OSD---->Vtx. The OSD diagram does show a dedicated +- connection on the OSD
for power in.
What I am having trouble with is understanding this wiring diagram. I believe there is an error. Please correct me if I'm wrong.
But to me it doesn't make sense the way they have drawn and labeled the blue wire between the Vtx and the OSD.
See attached pic.
-747
Old Sep 10, 2012, 07:53 PM
Evansville, WI
Joined Dec 2006
for power in.
See attached pic.
-747
You are correct, that is a misprint. Somewhere else of their website, it shows the correct wiring. The red should be power, black ground, blue video out(it's yellow on the V2.0)
Old Sep 10, 2012, 07:58 PM
Evansville, WI
Joined Dec 2006
Manual? Ha! What you see on the website is it. It really is a decent OSD, particularly for what it cost. The altimeter works correctly, it just doesn't remember "home" so if I don't reset home every time, it starts at 300m(my altitude above sea level).
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4153 Jun 27, 2016 10:56 AM
Discussion Suppo ESC help??? rotorkilla Racing Boats - Electric 3 Apr 18, 2011 03:38 PM
Discussion Suppo Shuttering kuczy Power Systems 4 Apr 12, 2011 07:42 PM
Help! Looking for Suppo motor GuyP Power Systems 6 Mar 05, 2011 05:34 PM
Sold REDUCED - ESC's - NEW Suppo 60a Opto - Suppo 70a Opto+BEC - $17.50 each shipped. Wingwrecker Aircraft - Electric - Power Systems (FS/W) 4 Aug 26, 2009 06:41 PM
