Old Feb 05, 2012, 08:50 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Gallery
DiaLFonZo-Copter -- Special Projects --
Hi All,
Here is a place.. where anyone that have a special project cut by us that don't have a special thread can post...
Also.. i may post things that i am thinking of..
Let's the Gallery begin..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 05, 2012, 08:55 AM
KABAL99 is offline
Find More Posts by KABAL99
FRANCE
Joined Dec 2004
ok here is mine
hexa copter made for FPV ( thx to William father of the Shrediquette)
set up tomorrow
KABAL99 is offline Find More Posts by KABAL99
Old Feb 05, 2012, 08:57 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by KABAL99 View Post
ok here is mine
set up tomorrow
That's a real nice assembly.
Clean .. very clean installation..
KABAL99 is offline
FRANCE
Joined Dec 2004
Thx
Old Feb 05, 2012, 09:39 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Hi all,
This is my firs tricopter (very old). I think appropriate here.
Widelec is offline Find More Posts by Widelec
Old Feb 05, 2012, 09:44 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by Widelec View Post
Hi all,
Nice tri..
I have never build a Tri.. they look more complicated than quad to me.
But will do.. !
Just want to do a solid Yaw mechanism..
Old Feb 05, 2012, 10:26 AM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
Originally Posted by Dialfonzo View Post
Nice tri..
But will do.. !
You can use my yaw mech. It is very solid. I rotate the whole boom. It keeps more of the weight at the center of the copter. I use 12x18x4mm bearings for 12mm booms but you can adapt to other size booms. There are two bearing clamps spaced about 30mm apart. The inside milling of the clamp has a step to keep the bearing in one spot. There is a clamp/strap on the boom in front of one and behind the other to keep the boom from sliding in the bearings.
There are other images in my attachment gallery. http://www.rcgroups.com/forums/thumb...attach&u=51651
mr.incredible is offline Find More Posts by mr.incredible
Old Feb 05, 2012, 10:54 AM
Widelec is offline
Simple is the best
Joined May 2011
Nice tri..
But will do.. !
Very simple handmade and work vell. (3mm plywood)
Old Feb 05, 2012, 10:58 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I like your boom mount that twist.
Will probably explore that way... But i think it's usr by multiwiicopter already ?
Widelec
Yes i know there is simple way like that.
I want something on bearing...
Once the cnc is back i will probably play
How is a tri compare to a quad... In flight ?
Old Feb 05, 2012, 11:32 AM
Widelec is offline
Simple is the best
Joined May 2011
Widelec
if you are RC heli pilots more ago, adapting quickly and braver fly than rcheli.
Tricopter is very funny.(entertaining)
No need ball bearing in this size tricopter yaw. Does not contain any spaces in this model
Old Feb 16, 2012, 01:34 PM
KABAL99 is offline
FRANCE
Joined Dec 2004
Update
set up almost done
perhaps first flight tomorrow before a longggggg sleep because of my Job
Old Feb 16, 2012, 01:38 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Update
set up almost done
Make it fly.. Make it fly.. LOL
Real good work
I like your FC mount with bend aluminum plates.
Old Feb 28, 2012, 04:56 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Psstt...!
Old Feb 29, 2012, 06:32 AM
Joined Dec 2004
Psstt...!
It's a board? You got some splainin to do.
Old Feb 29, 2012, 09:06 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
35mm x 35mm
30.5mm mounting hole
Multiwii compatible
MPU sensor
LED on each side
Discussion DiaLFonZo-Copter MicroQuad V2 (170mm MtM) Dialfonzo Multirotor Talk 139 Apr 17, 2015 11:03 AM
New Product DiaLFonZo-Copter - Flight controller shield Dialfonzo Multirotor Talk 263 Feb 10, 2014 12:38 PM
Build Log HEXorcism 600 - Luis & DiaLFonZo-Copter - Design for Cyberdog Dialfonzo Multirotor Talk 77 Apr 08, 2012 10:52 PM
Sold DiaLFonZo-Copter MicroQuad V1.0 1.5mm Dialfonzo Aircraft - Electric - Multirotor (FS/W) 19 Jan 05, 2012 04:01 PM
Discussion FPV plate Soft mounted - Luis & DiaLFonZo-Copter Dialfonzo Multirotor Talk 5 Jan 05, 2012 12:04 PM
