This thread is privately moderated by kdwzagi, who may elect to delete unwanted replies.
Old Feb 05, 2012, 07:46 AM
kdwzagi is offline
Find More Posts by kdwzagi
(madkev :) )
kdwzagi's Avatar
United Kingdom, England, Stafford
Joined Dec 2002
Build Log
nearly there
Hi
bit more progress..
I've made the elevons up from layers of balsa. a soft 6mm bottom sheet a triangular hard balsa middle section and 3mm soft top sheet with the grain running in the opposite direction to the 6mm. they are very light and stiff
I've glued on the nose. shaped the battery hatch and fitted the elevons
got to add some colour and sort out a last couple of bits before flying Name: SN855667.jpg
Description: shaped 6mm balsa
Description: nearly there
Description: just "checking" the under side !!
kdwzagi is offline Find More Posts by kdwzagi
Yippee! Nearly there on the Easy Glider Pro slowstick4ap Electric Sailplanes 0 Sep 09, 2011 04:05 PM
Build Log Nearly There NeilMac Steam Boats 8 May 04, 2011 01:42 PM
Cool RETROPLANE 2006 !! Nearly there ! LoopingFred Sailplane Events 2 Oct 16, 2006 06:43 AM
Nearly there! flyonline Dynamic Soaring 3 Sep 26, 2003 06:55 PM
