Old Feb 05, 2012, 03:57 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
hexTronik 5gram rewinding to higher kv
I read the following in the HK page of this motor:
Magnus Elofsson
"I changed one motor to Delta for one cell operating and used FR 130mAh:
GWS 3x3 1,3A 10200rpm thrust ~35g
GWS 4x2,5 1,6A 9100rpm thrust ~45g."
Anyone can point me to this guy, or give me layman instructions how to change it to delta ?
Any other advice to get 30 grams thrust from single cell would be great !
Or, wouldn't be simpler to use a bigger prop ?
Some computations show me I should be able to get 50 grams with a 5x3 prop, drawing 0.9Amps, so in limits of the single cell 3A ESC...
What I see now is that using a 3x2 prop the motor is not able to lift his own weight from single cell, which is strange...
Thank you !
renatoa is online now Find More Posts by renatoa
Old Feb 05, 2012, 04:16 AM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
the 5g hextronix can provide more than 30g on 1s w/o rewinding (sorry I don't have exact figure as I just based on the air flow compare to other motor). You can use GWS 5030, motor not getting hot with full throttle. Other options are AP03 7200kv or 4000kv or AP-05 3000kv but will cost more than double.
buratino is offline Find More Posts by buratino
Old Feb 05, 2012, 04:28 AM
Joined Sep 2007
I already bought 3 of them, I like to try first to get eveything I can from them before thrashing and look for others.
From the minimal knowledge I have about Y and delta windings, making such change does not implies effective rewinding, but only resoldering existing windings in other order, which I can do, just tell me how
I'll try 5x3 prop before anything anyway, ordering a 6 pieces pack.
Old Feb 05, 2012, 10:49 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
http://www.rcgroups.com/forums/showthread.php?t=587549
http://www.rcgroups.com/forums/showthread.php?t=240993
coriolan is online now Find More Posts by coriolan
Old Feb 05, 2012, 01:26 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
A 5g Hxt is only 2000Kv. It won't get hot on 2S with a 5030, but I doubt it makes over 25g of thrust at 1S with that prop.
Its a great motor on 2S, but its pathetic on 1S.
UNGN is offline Find More Posts by UNGN
Old Feb 05, 2012, 01:58 PM
Joined Sep 2007
So it needs rewinding, or trashing...
Anyone want three ?
Old Feb 05, 2012, 03:18 PM
Nooflyer is offline
Find More Posts by Nooflyer
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
I'm interested in one! lol but i'm guessing that it needs about 5600kv to work well one 1s.
I'm also thinking that might work for the ap03 but i'm not sure how many turns it would need!
Nooflyer is offline Find More Posts by Nooflyer
Old Feb 06, 2012, 01:13 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
You can avoid rewinding them by reconfiguring the magnets to NNSSNNSS.... which will double the kV.
I use that setup in my 1S Micro Christen Eagle etc. spinning a 4.1 prop. Lots of thrust and good performance.
NitroCharged is offline Find More Posts by NitroCharged
Old Feb 06, 2012, 09:15 AM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Nitro, You answered me when I ask this before but it is confusing. Are you using eight total magnets or are you using all of them in NNSS configuration. I know they have to be an even number. Which do you use 8,10, 12 or 16 ?
JCS
miatamama is offline Find More Posts by miatamama
Old Feb 06, 2012, 05:49 PM
buratino is offline
Singapore
Joined Nov 2007
I think you should use all magnet and join 2 together so in total you will have 8 double magnets. Btw, anyone know how many magnets on the AP-03 4000kv?
Old Feb 07, 2012, 06:51 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
JCS
Maibe one small drawing by the NItrocharged will be usefull!!!....We could,only hope!!!
cheers to all
nadine is offline Find More Posts by nadine
Old Feb 07, 2012, 03:10 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
ill throw in my .02 as i just rewound my second BL motor. basics, less turns of wire, more Kv.
thicker wire, = more amp draw.
take apart. un wind. take 3 wire and solder one end of each together, leaving three free ends.
label the wires as A and B and C. then wind them in order, start anyware. make the same number of turns.
when you get to C, start from A.
its kinda hard to screw up, just keep track of how many turns, make sure they are all the same!
mostly, just try it. some times too much planning is a bad thing.
nemoskull is offline Find More Posts by nemoskull
Old Feb 07, 2012, 03:14 PM
Joined Sep 2007
But changing magnets sounds far more simple...
Nitro, please...
Old Feb 07, 2012, 03:19 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I'll get on it today - been busy here working.
Old Feb 07, 2012, 05:35 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
The motor contains 16 small magnets, each arranged NSNS to give 16 magnet poles. What Nitro is saying is change the configuration to be NNSS to give 8 magnet poles (but still using all 16 magnets). Hopefully he will follow with a pic. His Christen Eagle flew well
Robbie d is offline Find More Posts by Robbie d
Discussion Rewinding a motor for higher KV Eddy Electric Motor Design and Construction 32 Jun 22, 2011 04:19 PM
Poll Most torque/'pop': Higher KV, lower tooth pinion or lower KV, higher tooth pinion. Infms Micro Helis 6 Feb 11, 2009 04:02 PM
Discussion Need Advice Rewinding BL Motor To Get Higher KV phupper Electric Motor Design and Construction 6 Dec 10, 2008 11:38 AM
Question Rewinding a 5gram outrunner methuso Scratchbuilt Indoor and Micro Models 7 Jun 09, 2008 01:21 PM
Discussion Rewinding an axi motor for higher KV? Eddy Electric Motor Design and Construction 10 May 05, 2007 11:30 AM
