Old Feb 05, 2012, 03:52 AM
hermanmango is offline
Find More Posts by hermanmango
United States, UT, Logan
Joined Feb 2012
using a 6 channel Tx (Dx6i) for a 3 Channel trainer / switching rudder stick
-background story- (if you want to understand my question better)
I'm new in the hobby and this is my first post on the site, so bear with me. I recently grabbed an ancient old balsa 3 channel trainer that has been sitting in my parents house for ages, from my first attempt when i failed to get into rc planes, I'm now older and have some more experience and have been learning on some UM planes and just started flying some bigger stuff, then i remembered that old balsa trainer i had, i found it at my parents house, and took it out, it had stopped working on my all those years ago, and i didn't know why, but me being older, and much better at working with planes I quickly found the problem and fixed it, so i now had this old working plane, but it had an old 72 Rx in it, no being sure if old stuff would work with new stuff i plugged it all into a spektrum Rx and presto, it came to life, and was now bound to my dx6i, but there is a problem, and now that you have the background story here is my actually question
-actual question
a 3 channel trainer usually has the rudder on the right stick, when i plugged this badboy in my rudder of course was controlled by my left stick, like it should be on a 6 channel rx, my question is what is the correct way to move my rudder control back to the right stick for flying this particular plane?
I have found a few work arounds but i want to know if there is a "right" way to do it. my first work around was to mix my rudder with my aileron, which for this plane doesn't exist. workaround 2 was to simply plug the rudder into the aileron channel. both of these worked, but me being sort of new i just wanted to ask here if that is an okay way to go around it, or if you guys would recommend a different way.
hermanmango is offline Find More Posts by hermanmango
Old Feb 05, 2012, 05:03 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Yup, plug the rudder servo into the "aileron" slot.
The slots themselves obviously don't know what servos they're driving. They're simply labeled in the manner of a conventional 4- channel plane for simplicity.
Piece is online now Find More Posts by Piece
Old Feb 06, 2012, 05:19 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
The receiver's slot labeled "ailerons" SHOULD read "PRIMARY ROLL CONTROL"
rtbates is offline Find More Posts by rtbates
Old Feb 07, 2012, 08:08 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
As stated above, just plug the rudder servo into the aileron slot on the receiver. Now the right stick controls the rudder.
Rodney is offline Find More Posts by Rodney
Old Feb 07, 2012, 11:59 AM
Joined Feb 2012
k, thanks for the replies, thats what I ended up doing but i just wanted to be sure.
For Sale Hitec NEON-SS FM single-stick 3 channel transmitter and Hitec Electron 6 receiver $25 shooboy Aircraft - General - Radio Equipment (FS/W) 1 Feb 05, 2012 03:17 PM
Sold KRAFT Single stick Mark 3 7 channel TX $215 shipped sagomon Aircraft - General - Radio Equipment (FS/W) 2 Jan 22, 2012 07:20 AM
Wanted An inexpensive 4 or 6 channel Tx with trainer port for Sim use. dafremen Aircraft - Electric - Helis (FS/W) 4 Sep 28, 2011 10:33 AM
Discussion 3 Channel Trainer- Which Channel for the Rudder? fresbill Beginner Training Area (Aircraft-Electric) 11 Dec 19, 2007 11:51 PM
Discussion using a 3 channel RX with a 6 channel TX Le petit normand Radios 5 Jun 08, 2007 06:25 AM
