Old Feb 18, 2012, 10:14 PM
Fodigo is offline
Find More Posts by Fodigo
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Proboat 47' MLB rebuild
Thanks Greg. She's coming along!...
Like a good story- hard to put down sometimes.
After a few more coats of black - and days drying- and wet sanding...
She's ready for the white bottom.
Seems not all the paint was fully dry. I had a feeling I should have squeezed at least one more day of drying time seeing its been pretty cold.
Well, I had to wet sand anyway. Just didn't want to do it so soon.
The idea is to retain the silver undertones, and use the stainless color as the "dirty aluminum" look. (you'll just have to wait and see the grand master plan for the paint).
Wet sanding the ... Ah humm, mistake:
LoL- she looks like she's had a brush with a coral reef!
Prepping for more color and coats:
In the mean time. A few accessory details in progress. Here, I'm making the three aft storage doors.
Using the plastic packaging from my epoxy resin - this gave the perfect curve for the interior of the hatch. The handle will eventually be made and fit inside. I'll have to cut some holes in the rear of the boat to fit these in so they will have to be water tight.
I also made the escape hatch.
A little sanding and slap on some paint and it'll look just like a door.
Fodigo is offline Find More Posts by Fodigo
Last edited by Fodigo; Feb 19, 2012 at 01:54 PM. Reason: It's wet sand not wetland. Damn auto spell
Old Feb 19, 2012, 02:19 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Repairs to the rebuild repairs
Repainted the hull. "a-gain" Got a nice smooth match. Layering paint is great. Very strong! As long as you let it dry thoroughly between coats... (Doh!). Otherwise you pull off 6 or 7 layers by accident and create a huge divot! Anyway. This is me being very careful not to expose another 7 layers of under coat, and final coat of the black. I think this totals around 7 layers as well (?). I lost count of the black. Flat black goes on quickly and covers nicely. I'll later have a final wet sand on these coats (black and stainless) before hitting it with clear.
And yes, that's electrical tape. I like using it over masking tape. Makes SUPER defined straight lines without the paint bleeding under like masking tape does. You just have to be certain the paint is dry before applying. I prefer the 3-4 day method but I've been know to use a hair dryer before to quick cure it. ...As in this case. ...It just takes long (about hour between coats) to gently warm the hull with the dryer and dry the paint. I allow the hull to reach room temp too before the next coat goes on. And I coat very lightly and wet sand between coats.
Now it's taping it back up again (yaye!  . ) to add the white bottom.
Hey, my pooch has those same markings:
I like working with gloss white but hate gloss in any other color. White always goes on like silk and never orange peels like black or red or blue in gloss.
Now, carefully remove the tape!!
The tape peeled away nicely without any problems this time.
I'll be doing more with the hull later.
Now, I'm off to build this red portable sump pump.
Old Feb 19, 2012, 10:17 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
47' MLB sump pump
Old Feb 19, 2012, 10:31 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
47' MLB sump pump
Banged out the portable sump pump in an afternoon.
For this part of the rebuild I'll need to cut into the aft storage box. A little nervous but I'm hopeful it will work out ok. I guess'timated the area from looking at many pictures (most stock photos of the MLB don't show this area well) and started cutting. The picture above in the prior post was taken from a news crew video.
After THE HOLE was cut into it, I used a 3/4" wide flat file to square up the lines.  I found the floor of the MLB slants downward slightly. By just looking at it, it appears as level as the top of the storage locker. This will make the insert I plan to install slightly difficult as I plan on a zero tolerance fit to make sure this area is water tight.
I looked at a lot of possibilities to make the sump pump out of but ended up using this red dowel from my 41' Dumas USCG kit.
I plan on cutting it in half so it doesn't fit in the hole too deep and of course shorten it as its too tall.
Here's the dowel cut in half. I used a file and shortened the ends so it would fit in the hole better, and allowing space for a frame. It won't be noticeable later.
And then constructed a frame. I built the frame inside the hull first, then filed down any needed places on the dowel second so the dowel would fit snug in the frame (top to bottom) and the frame fit snug in the hull section.
I made the bottom fit under the can a bit differently so I'd know which side is UP seeing the hole is not exactly square.
I left a little air-gap in the sides so it looks more "lose" in the frame.
The air gap was later covered with epoxy resin to make it water tight but still appear as if it's loose.
Now it's just a matter of fitting the square peg in the round hole.
And now you have a portable sump pump.
I'll detail the pump with a lid and canister straps as soon as I figure out what to use.
Old Feb 19, 2012, 10:38 PM
6789boat is offline
Find More Posts by 6789boat
Model trains, Rc Boats, Rc air
United States, CA, SF
Joined Mar 2009
I have seen one of those silver uscg cutters in the bay, and those are noisy.
6789boat is offline Find More Posts by 6789boat
Old Feb 20, 2012, 07:53 AM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
I haven't seen one in person yet, just pics and videos. ONE DAY! And when I do I hope to take A LOT of pictures and maybe get a ride
Old Feb 20, 2012, 10:36 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
"It's all in the details."
And your eye for detail is great and your mod's are awesome!
Kmot is offline Find More Posts by Kmot
Old Feb 20, 2012, 11:06 AM
MrLego is offline
Find More Posts by MrLego
RC Flying;Lego Contraption Guy
MrLego's Avatar
Smalltown, USA
Joined Sep 2010
just go surfing in the bay and "get stuck." A Motor Lifeboat is bound to come around and pick you up and bring you back to shore.
MrLego is offline Find More Posts by MrLego
Old Feb 21, 2012, 01:39 AM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Hahaha.. That's funny Kev. Although I'm just not quite ready to fight the sharks off while the MLB arrives.
Got another update for ya.
Adding a "little" more black. The line just was a hair off on thickness.
That looks better.
Time to work on the logo
Problem:
The white area I accounted for the logo was 1/8 inch too big. Only because when I removed the original logo, I didn't account for the small overlap of clear on the original decal.
Arse back to the sanding stone!
Other works... The rear doors prototype now.
The new doors will look much better now. The prototype looked good.
Construction of the aft bay doors
Doors are progressing nicely.
Old Feb 21, 2012, 10:14 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
MLB Aft storage Hatch Doors
Work on the aft stair age bay doors continue
Painted the area (included the sump pump) and laid out the door location. Also made the two vents.
Marking the site for the hinges
After notching the lip where the hinge will be be placed, I started working on nipping out the hinge from stock styrene)
Mounting up
Hinges coming along on door number one.
Marking out the door handle location.
Started working on the hatch door channel and handles.
Pencil added for size comparison. Yes, I'm using eye loops to see what the heck im doing (LOL)
Old Feb 21, 2012, 10:23 PM
MrLego is offline
MrLego's Avatar
Smalltown, USA
Joined Sep 2010
man... your HUGE photo postings crashed my inexpensive phone...
That looks good! Could you make me like 3 sets of those?
Old Feb 22, 2012, 02:09 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
MLB doors
LOL - make more!?! Oh God no! Maybe in my "spare" time (LOL).
Testing picture posts ways. Photobucket only allows so many posting options.
Email/IM: http://s218.photobucket.com/albums/c...t=b449368d.jpg
Direct: http://i218.photobucket.com/albums/c...s/b449368d.jpg
HTML: <a href="http://s218.photobucket.com/albums/cc150/spbarriers/?action=view&current=b449368d.jpg" target="_blank"><img src="http://i218.photobucket.com/albums/cc150/spbarriers/b449368d.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Ok. So that didn't work. How are you guys posting pics?
I'm using the [IMG] method.
Old Feb 22, 2012, 02:17 PM
MrLego is offline
MrLego's Avatar
Smalltown, USA
Joined Sep 2010
oh! so you know when you post a reply?
look for that little paper clip icon and click on that. A popup should appear and you could choose the photos you want to upload.
select the photos you want to upload and click upload.
Scroll down to add captions.
Then, click close window when youre finished.
Just for telling you, you need to make me 3 sets of those hatches.
Old Feb 22, 2012, 02:53 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Flash player
LOL...
Ah, the "paper clip" - unfortunately, apple doesnt allow the upload of flash player to iPhone or iPad (where I send my pix from). It'll take a little longer to post pics because ill have to transfer a different way and use my desktop but I'll start posting that way. I hate the long page loading time too.
Old Feb 22, 2012, 07:25 PM
drpower is offline
Find More Posts by drpower
drpower's Avatar
British columbia
Joined Nov 2008
I just got a new PRB3500 today, next to impossible to find but after a lot of research I managed to find one in Canada thats been on a shelf for 3 years the store owner said. I'm going to paint it CCG colors, what type paint should I be looking for? I already have some decals for 'Cape Naden' from CanMilarAir.com on the way. I guess now starts the research process on how all that is done and what the proper procedure and things like what paint to use starts.
drpower is offline Find More Posts by drpower
Discussion big problem with proboat coast guard boat modelerchina Scale Boats 40 May 12, 2012 01:39 AM
Wanted 47' MLB Coast Guard (in search of) Fodigo Boats (FS/W) 8 Jan 27, 2012 11:58 PM
Wanted Proboat or Midwest Coast Guard MLB ChanceJ Boats (FS/W) 17 Nov 24, 2011 09:47 PM
Sold midwest products 47' coast guard boat 48chebbie Boats (FS/W) 2 Nov 01, 2011 12:26 PM
Sold Proboat Coast guard boat PKDURANGO Boats (FS/W) 1 Jul 25, 2011 06:54 PM
