Old Feb 08, 2012, 07:37 PM
catchthis is offline
Find More Posts by catchthis
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
ps, where did it say the conversation was between fodigo and mrlego? I never said building a boat was easy either, I said the plans & instructions were easy enough to read and follow for me that I was able to build the kits. I didn't say it was easy for everyone. like you said and maybe I read it the wrong way, words can be read differently that heard.
catchthis is offline Find More Posts by catchthis
Old Feb 08, 2012, 09:30 PM
Fodigo is offline
Find More Posts by Fodigo
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Double post
Fodigo is offline Find More Posts by Fodigo
Old Feb 08, 2012, 09:34 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Radar building
Guys, this is a build info thread. Please don't post confrontations.
Here's how I made the radar.
The working motor, brass rod, and the receiver antenna from the boat
I filed down one end of the brass rod so it would fit in the plastic antenna tube.
The rotating beacon easily separated from the motor housing using a quick twist. I hand drilled a hole in the shaft of the beacon to accept the brass rod.
I cut the antenna tube, drilled the same size hole thru the motor housing and all that's needed is just assembly. The real motor shaft fits up thru the radar beacon motor housing and the antenna tube from the boat matched up perfectly.
As I crammed it all in, I thought to add an on off switch that turned off the radar and light but still allowed charging of the battery via the solar panel so I could have the option of turning everything off if I wanted.
Affixed the solar panel
testing the light and motor
Epoxy resin'ed the lid down. It's strung up so that all areas of the top cap were securely attached to the main base.
Completed
Painted and Remounted
Old Feb 08, 2012, 09:38 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Video of working unit
RC Radar (Solar Powered) (1 min 9 sec)
Old Feb 08, 2012, 11:00 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
That's cool.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Feb 08, 2012, 11:24 PM
MrLego is offline
Find More Posts by MrLego
RC Flying;Lego Contraption Guy
MrLego's Avatar
Smalltown, USA
Joined Sep 2010
I like the solar panel idea. if you could somehow hide that into the grip tape, center that radar, it would be awesome! Its still cool now too.
MrLego is offline Find More Posts by MrLego
Old Feb 10, 2012, 02:22 AM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Ha! If it were only that easy. Well, I did try a smaller set of panels but there wasn't enough power generated. So this is what I had to settle for. It's not so bad. GoIng green! (LOL)
Old Feb 10, 2012, 02:38 AM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Rebuilding the forward battery box.
One major problem about building the box outside the boat is you can't get it in!
Luckily, the epoxy hadn't dried yet so I could still take it apart end reassemble it inside the hull.
PREP FOR PAINT;
Really don't want to redo all pieces of grip tape so we're covering them one by one with grip tape.
All fittings, accessories, decals removed.
Old Feb 10, 2012, 08:10 AM
CurtisP40 is offline
Find More Posts by CurtisP40
CurtisP40's Avatar
Joined Oct 2011
Cool radar.
CurtisP40 is offline Find More Posts by CurtisP40
Old Feb 10, 2012, 09:55 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Originally Posted by CurtisP40 View Post
Cool radar.
Yeah! I was amazed it actually worked (LOL
Hit it with grey.
Comparison behind
Started working on the exhaust.
Testing the tube placement.
Old Feb 14, 2012, 02:19 AM
MrFriendly is offline
Find More Posts by MrFriendly
Joined Jan 2012
I really want a Coast Guard boat now.... I saw one on ebay just earlier for about $250. I might get it. But its not the ones youre picturing here... I dont know if i sohuld wait for this one to show up or to get the one listed on ebay now. Its the older lifeboats.
MrFriendly is offline Find More Posts by MrFriendly
Old Feb 15, 2012, 02:22 AM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
R/C MLB update
Decided to not do a grey color after-all.  Color change:
Going to make this one: Bodega Bay. It's closer than San Franciscio to me. Although I'll still use some Fodigo'izing to personalize it a bit.
The upper deck was tested for color...
Making way for new deck hardware:
Polishing some fitting hardware
Building some life float accessories to add to the scale look of the real one
More scale pieces will be added...
Tapered the captain chairs while they are off:
Old Feb 15, 2012, 07:23 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
Finding the right color is a challenge
That paint was OK but up close, just toooo metallic so... If its not right, it sucks.
Found this paint: giving it a try...
You can't tell much difference in this pic but the difference is - no metal flake. I like it. looks more like metal. I looked at the "aluminum" colored paint but they looked to much like regular silver paint. The look in going or is a "dirty" aluminum. I'll add other details to the paint later.
Old Feb 16, 2012, 11:26 PM
Fodigo is offline
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
47' mlb
Work continues.
Painting the bottom.
The bottom needed another coat:
Old Feb 17, 2012, 08:16 PM
G1ST is online now
Find More Posts by G1ST
G1ST's Avatar
USA, CA, Petaluma
Joined Mar 2010
It's looking real good Dave
G1ST is online now Find More Posts by G1ST
Discussion big problem with proboat coast guard boat modelerchina Scale Boats 40 May 12, 2012 01:39 AM
Wanted 47' MLB Coast Guard (in search of) Fodigo Boats (FS/W) 8 Jan 27, 2012 11:58 PM
Wanted Proboat or Midwest Coast Guard MLB ChanceJ Boats (FS/W) 17 Nov 24, 2011 09:47 PM
Sold midwest products 47' coast guard boat 48chebbie Boats (FS/W) 2 Nov 01, 2011 12:26 PM
Sold Proboat Coast guard boat PKDURANGO Boats (FS/W) 1 Jul 25, 2011 06:54 PM
