Old Feb 04, 2012, 07:37 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
DJI F330 Lil Quad
Thought I would do a quick build (pic) thread on the Little F330 Quad.
Its a blast to fly indoors.
UAVProducts is offline Find More Posts by UAVProducts
Old Feb 04, 2012, 07:56 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
Very nice Robert. You using the same 920kv DJI motors that ship with the F450 and F550 ARF's? What is the AUW without battery?
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 04, 2012, 08:01 PM
Joined Mar 2004
Have to weigh it.
Old Feb 04, 2012, 08:03 PM
Joined Mar 2004
1lb 3oz with Naza and JR921rx
Yes, DJI 920kv motors, 18amp Opto and 8" props.
Old Apr 16, 2012, 08:48 PM
skyhulk is offline
Find More Posts by skyhulk
skyhulk's Avatar
Joined Jun 2009
i bought this quad, love it any idea what landing gear and gimbal i can use?
skyhulk is offline Find More Posts by skyhulk
Old Jun 16, 2012, 06:02 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Not much activity on the F330 threads. I've managed to break three arms on mine (two because of me 'stunting' the last because of a bad battery wire solder joint from the factory (I think). Luckily I have a spare frame to steal arms from. I'm down to my last arm from it though. Has anyone seen anyone selling just arms? Robert...can you help out???
Vantasstic is offline Find More Posts by Vantasstic
Old Jun 16, 2012, 08:29 PM
giek2000 is offline
Find More Posts by giek2000
Joined Nov 2008
Brilliant little quad. Though the bit of the arm near the motor seems to be a weak spot I've noticed. Flying MultiWii 2.0, 1200kv, 30a esc. 8" props with plenty of power Here's a picture of mine for good measure
giek2000 is offline Find More Posts by giek2000
Old Oct 17, 2012, 03:21 PM
advera is offline
Find More Posts by advera
Joined Sep 2004
@ giek2000
Hello, YES this is what i want to see !
Is it possible to get another picture without the "glass" at the TOP ??
tnx from germany
Herbert
advera is offline Find More Posts by advera
Old Oct 17, 2012, 04:17 PM
RTRyder is offline
Find More Posts by RTRyder
Registered Lunatic
RTRyder's Avatar
Boston, MA
Joined Jul 2010
I've been using one as an FPV quad for a while. Takes some creativity to find a way to get all the necessary gear on it but once setup it's a great little flyer through the goggles...
Ken
RTRyder is offline Find More Posts by RTRyder
Old Oct 17, 2012, 05:11 PM
giek2000 is offline
Joined Nov 2008
Originally Posted by advera View Post
@ giek2000
tnx from germany
Herbert
Unfortunately this one had a tx lockout and flew off into the sunset. I haven't got any pictures of the quad without it, but maybe this will help.
Old Oct 17, 2012, 06:46 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Giek you have a sweet setup with your 330. I have been looking for something a little bigger than my 250 sized Y6 FPV to do more aggressive FPV with, and I am thinking a 330 size is the near perfect size.
That is arguably as small as viable if you want to carry a fixed GoPro and FPV kit because the 250 sized frames simply don't have many motor choices that are suitable.
330 seems to be the minimum size to have plenty of climb-out punch due to the multiple motor choices available including motors that allow 4S.
This then makes for relatively small and wildly powerful and nimble FPV machine, without needing to spend huge dollars on high end motors and batteries that would be required for a larger and heavier frame.
Anyway, for your kit (if you intend on making a new one) what I would do is Dremel away the top 3mm or so of your motor shaft so the propeller adapter can slide all the way down onto the motor bell and tighten onto the motor shaft with zero gap between the bell and the adapter.
This will minimize the chances of the motor shaft bending from collision or a heavy landing.
My question is: Are people finding the DJI 330 frames are as fragile and vibrate as much as the other DJI frames?
Please advise...
Mike.
Sad Sack is offline Find More Posts by Sad Sack
Old Oct 17, 2012, 09:23 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Please advise...
Mike.
Fragile? No. Breakable? Yes. I've broken two or three arms on mine while learning quadrabatics with control rates that were a little to low. I bought spare arms and a spare frame and haven't broken anything since...go figure. As for vibrations...I don't see/hear vibs, but my Multiwii controller seems to. After setting it up with an LPF of ~24 (I think) it's nice and smooth...and very responsive. I did my first double loops and rolls with it this past weekend...no issues and easy as pie. I'm really having a blast with my F330. My OP CC board had no issues with the F330. The Multiwii firmware just feels tighter with the sport flying while the CC board felt a little drifty.
Old Oct 17, 2012, 11:39 PM
Birdman4498 is offline
Find More Posts by Birdman4498
Birdman4498's Avatar
Canada, ON, Ajax
Joined Jul 2011
I also have the DJI f330 with Bumble Bee FC 20 amp ST esc's and the Gaui Scorpian motors. It flys very nice and I really like the size. I run 1500 3s and can get almost 10min. I have broken 2 arms so far on crashes I would not of expected things to break but at $3.00 a pop and very little time to repair that is acceptable.
Dave
Birdman4498 is offline Find More Posts by Birdman4498
Old Oct 18, 2012, 12:15 AM
monkey1 is offline
Find More Posts by monkey1
Joined Jun 2010
This is my quad330, which is made by APM2.0
OSD module & 433Mhz data transfer module
monkey1 is offline Find More Posts by monkey1
Old Oct 18, 2012, 10:23 AM
giek2000 is offline
Joined Nov 2008
Please advise...
Mike.
Hi Mike. Personally I find 330 size a laugh to fly. Strap on some 1200kv motors and you've built yourself a rocket ship. I did have issues with vibrations with the F330 frame, or rather it was only when I built a quad with aluminium arms I noticed how much better it flew. Also the F330 arms seemed to snap easily near the motor when crashed, something that wasnt as bad with my F450 but still happened. Currently flying a scratch built 330 frame with alu arms. Awesome for acro and steady for quietly flying it around.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
Sold DJI F450 flamewheel quad frame kauaicuda Aircraft - Electric - Multirotor (FS/W) 2 Dec 14, 2011 07:33 PM
Discussion Quad Q-700Pro DJI skycam4 Aerial Photography 17 Dec 08, 2011 02:41 PM
Help! Putting together a component list for DJI Quad system keith.uk Multirotor Talk 2 Nov 16, 2011 07:51 AM
New Product DJI's Quad System with Position Hold borneobear Multirotor Talk 10 Jul 23, 2011 04:54 PM
