Old Feb 04, 2012, 05:14 AM
antboy6969 is offline
Find More Posts by antboy6969
Joined Jan 2012
Skyartech Ninja 400 tail rotor problem
hey guys recently i have been having some problens with my ninja 400 . the tail keeps jittering too much probably the gyro set too high but when i had a look at the gyro the gain was turned to less than half way? is it something wronge with my tx (sky 706) ? and i also notice when i am hovering and i quickly put the throttle all the way up it goes up realy fast but the tail keeps moving left. that only happens when i give the heli bout 90% throttle quick , is that normal or is their something wrong with the belt?
sorry for my bad english
any help will be helpfull.
thankyou so much for your time.
ps my tx is loaded up with the mode 2 default ninja 400 profile.
antboy6969 is offline Find More Posts by antboy6969
Old Feb 05, 2012, 12:17 AM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Do not change the gyro setting on the gyro unit. change the sensitivity in the software settings of the transmitter, using the configuration software. Maybe reduce the setting only a few percent at a time. Also insure you do not have any broken or worn down teeth on the main gear. make sure tail belt is very taut, like a stretched out rubber band.
Let us know if any of this helps
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Discussion Blade 400 KBDD Tail Rotor Blades pvtparts Electric Heli Talk 1 Sep 09, 2011 01:15 AM
Discussion Weird KDS 450S tail rotor assembly problem JeremyT 3D Electric Heli Flying 0 Sep 06, 2011 06:32 PM
Discussion blade 400 tail rotor pattystacker Beginner Training Area (Heli-Electric) 6 Jul 21, 2011 09:41 AM
Sold Blade 400 Cabon Fiber Main Rotor and Tail Rotor Blades Jose5x5 Aircraft - Electric - Helis (FS/W) 1 Apr 04, 2011 09:00 PM
Question APLUS 400 V2 Tail Rotor Problem CaptainMurphy Mini Helis 6 Jan 19, 2007 11:25 AM
