Old Jun 15, 2012, 10:37 AM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
If I remember right, Cmala has the 103 in his 48" Edge.
Some fun with the 3DHS 48" Edge (8 min 23 sec)
teookie is offline Find More Posts by teookie
Old Jun 15, 2012, 10:39 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
There is nothing wrong with the 103g motor, as i said you can still do it all with that motor, but some folks(including myself) would like a little more power. On my blog i have a video of the SHP on the 103g motor and am hoping to get some footage with the 130 next week.
hone1er is offline Find More Posts by hone1er
Old Jun 15, 2012, 10:45 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
http://vimeo.com/29000415
Had. Past tense.
Edge is repairable. Given the choice, I would choose the 130 but if you have a 103 on hand then use it.
for a motor on the shp I would use whatever joe had at fli. That setup looked nice.
cmala is offline Find More Posts by cmala
Old Jun 15, 2012, 10:47 AM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I wore my 2011 okoberfest shirt yesterday
Originally Posted by Elixir220 View Post
http://api.viglink.com/api/click?for...13397714545411
Ben , Amy, Noll and a few of the 3dhobbyshop sponsored pilots plan to attend. Andrew Jesky and Joe Smith have been on the property in the past and hopefully we'll see them again real soon. hope to see you there
going4speed is offline Find More Posts by going4speed
split_s is offline
Find More Posts by split_s
Don't Midair Me, Bro!
split_s's Avatar
USA, IN, Auburn
Joined Jun 2010
Anyone going to the National Electric Fly in Muncie next weekend?
split_s is offline Find More Posts by split_s
Old Jun 15, 2012, 10:55 AM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
Originally Posted by cmala View Post
Had. Past tense.
Joe uses the same setup on all of the 48" planes.
Omega 130, 13x6.5, 3s 2200
6L6Amp is offline Find More Posts by 6L6Amp
Old Jun 15, 2012, 11:27 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
I assume the reason for recommending the 103 was the V3 SHP. With 65MGs in the tail and a 130g motor you probably could not achieve a neutral cg, the battery pack would hit the wing tube. My V3 SHP has a 123g Motrolfly motor and I have my battery 1/2" from the wing tube and the cg is slightly ahead of neutral, however I'm running Savox digitals in the tail which are slightly heavier than the 65MGs.
Since the V4 SHP is pull-pull with a heavier tail due to the airfoils, you should be able to put a 130g motor on it and still have plenty of room to hit a neutral cg with the battery ahead of the wing tube.
Ace4 is offline Find More Posts by Ace4
Old Jun 15, 2012, 11:29 AM
BOSSIER_ROB is offline
Find More Posts by BOSSIER_ROB
BOSSIER_ROB's Avatar
United States, LA, Bossier City
Joined May 2011
Looks like Joe's using his back up Slick at XFC. Extra is toast from possible lock out.
BOSSIER_ROB is offline Find More Posts by BOSSIER_ROB
Old Jun 15, 2012, 11:32 AM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
Radio WARS again.........................lock out.......................I thought only happens to spektrum/jr.......................but I'm really sad to hear anything like that no matter who it happens it to no matter what equipment or reason such as bad servo.
HugoCraft is offline Find More Posts by HugoCraft
Old Jun 15, 2012, 11:34 AM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
Maybe a servo failed? (that happened to me once.)
Old Jun 15, 2012, 11:37 AM
jfuller1250 is offline
Find More Posts by jfuller1250
Fly til dark
jfuller1250's Avatar
United States, IN, Bourbon
Joined Nov 2011
That sucks big time!
jfuller1250 is offline Find More Posts by jfuller1250
Old Jun 15, 2012, 11:40 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
That happened to me once as well, and then again the very next day
Old Jun 15, 2012, 11:46 AM
6L6Amp is offline
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
He had been chasing a problem with it for a few weeks. Thought he had it solved, but apparently not. It doesn't appear to be a radio issue because he used two different transmitters, as well as, two different receivers and they both resulted in the same issues. He didn't have any problems using the same TX on his other planes. It's sad to see. He really had that plane dialed in and he was flying it so well. Such is the hobby though...
Old Jun 15, 2012, 11:51 AM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Ummmm I put a 130g on my shp and the rudder servo as pull/pull. Will that be ok? I'm confused.
skarface is offline Find More Posts by skarface
Old Jun 15, 2012, 11:54 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Yeah thats fine, that is probably the best setup for that plane.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
