Old Apr 16, 2012, 06:46 PM
theK2 is offline
Find More Posts by theK2
3D-wanna-B
theK2's Avatar
Lynchburg, VA
Joined Dec 2008
Originally Posted by JeffSchre View Post
For the 80's gamers like me...this is just cool....makes me wish I had $500 to donate to the cause, I can't be the only one that thinks getting their name in the credits "of a piece of gaming history" would be cool.
http://www.kickstarter.com/projects/...rry-come-again
Thanks for posting this! Was just thinking about Kings Quest, Space Quest and LLL a few weeks ago. BACKED this project!
Originally Posted by wamsy55 View Post
A great reason not to hover catch.
+1
Originally Posted by Stoned doggie View Post
omg!!!!!!!!!!!!!!!!!!!!!!!!! dude my mom is being lazy and wont vid tape my sweetness i am having right now hover tail touches just became really easy so are KE spins but i cant even hold a KE because i dont have any mixes and it pulls tarwds the wheels.
Check a page or two ago about setting CG using KE. Trim to level flight at 1/2 to 3/4 throttle in level flight, then roll to KE. Change battery location based on the results. Tail heavy will pull toward gear, nose heavy will pull toward canopy.
theK2 is offline Find More Posts by theK2
Old Apr 16, 2012, 06:49 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
yea but do the pros like joe use that method or does he just mix it out?
skarface is offline Find More Posts by skarface
Old Apr 16, 2012, 06:52 PM
theK2 is offline
3D-wanna-B
theK2's Avatar
Lynchburg, VA
Joined Dec 2008
I have my 48" Edge holding perfect KE with nearly no coupling just by adjusting the CG. Not sure what the pros do - but that worked for me and in the progress made all other aspects of flying the airplane easier, including landings.
Old Apr 16, 2012, 06:55 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
I am sure the pros use CG to get the coupling as low as possible, and then mix it out.
None of my airplanes have mixes, I just fly with the correct CoG.
wamsy55 is offline Find More Posts by wamsy55
Old Apr 16, 2012, 06:56 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
tap'n out for a while... you kids be good.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 16, 2012, 07:00 PM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Good luck KM, see you in a few weeks at Nall!
CrashesALot is offline Find More Posts by CrashesALot
Old Apr 16, 2012, 07:05 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Yeah, the pros set their CG so it is very close to neutral I am sure..Which means that all control surfaces should be in a neutral position and cause the plane to fly level. Technically speaking, unless their is a design flaw, or build flaw with a plane, you should be able to balance the plane with nothing but a good CG.
StormJunkie is offline Find More Posts by StormJunkie
Old Apr 16, 2012, 07:06 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
i dont think joe puts KE mixes in his planes
aronph is offline Find More Posts by aronph
Old Apr 16, 2012, 07:07 PM
aronph is offline
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
is that a rule?....or a "guideline"?
Old Apr 16, 2012, 07:12 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
HEY Joe! or joes dad, what do you do for your CG?
Old Apr 16, 2012, 07:24 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Actually AJ (Pro) likes slightly Nose Heavy airplanes. Better Precision. So no, the Control Surface, (Elevator) is not going to be (neutral position). Will have some Up Trim.
If you start getting Neutral to Tail Heavy, it is going to balloon up on you more and that can get you in trouble in some manuvers. Ok for low hucking if you can do Full (Deadstick) Harrier Landings already. If you are flying mixed Precision and 3D, gets harder to do the Precision side.
Last I heard Joe was flying Neutral or a tad ahead of Neutral to the Nose side...
heritageflyer is offline Find More Posts by heritageflyer
Old Apr 16, 2012, 07:25 PM
Joined Nov 2008
He's still flying those Auto CG's, probably on Version 8 by now...
Old Apr 16, 2012, 07:31 PM
Whoooo!
Summerville, SC
Joined Jan 2009
That was the "very close" part heritage...I seriously doubt that AJ, Joe, or any other really good pilot is adding more than a couple clicks of trim (off a centered surface) to achieve level flight.
Old Apr 16, 2012, 07:36 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
auto Cg, V8????
Old Apr 16, 2012, 07:44 PM
Balsa Breaker is offline
Find More Posts by Balsa Breaker
Balsa Breaker's Avatar
United States, MI, Lambertville
Joined Feb 2011
Originally Posted by Luv3d View Post
'nuff said!
Nice bokeh?
How do you reply and include the pics? Brain fart!
Balsa Breaker is offline Find More Posts by Balsa Breaker
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
