Old Apr 16, 2012, 02:56 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
wow 40+ planes ok lol
skarface is offline Find More Posts by skarface
Old Apr 16, 2012, 02:57 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
If I count its probable over 50 in the last 3 years that I have built for me and my brother
losifanatic is offline Find More Posts by losifanatic
Old Apr 16, 2012, 03:02 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
Originally Posted by Stoned doggie View Post
Ok i was just wondering because i think on the 71" build vid he said its better to a x instead of smashing the whole thing so i did an x on my slick, just seeing if there is an offical. Est way to do it.
I X them with a pair of old dykes that I put tape on the blades so it wouldn't actually cut. Either way really doesn't really matter as long as you ADD CA
StormJunkie is offline Find More Posts by StormJunkie
Old Apr 16, 2012, 04:14 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I don't smash mine either, couple crimps, maybe some CA but lately not. The loop is designed to take all the load, the crimp keeps things in check.
A little work and I can uncrimp. But I've only had to uncrimp the 51. I put the adjustments in the middle so I have some room to tighten....which usually needs to happed after a few flights.
robj is offline Find More Posts by robj
Old Apr 16, 2012, 04:16 PM
Whoooo!
Summerville, SC
Joined Jan 2009
Here are pics, etc of the thrust angle issue I was talking about...
One thing I did on the last pull-pull, was to crimp both ends, and had only screwed the ball links in part way while setting up the other end. Then I adjusted the ball links so that the other end barely fit all the way through the servo swivels. I also tightened the cable up just a little extra. By time I got to maiden, the cable had stretched to a point where it was not taught anymore. This also still leaves me full adjustment potential on the servo end. I CA'd the ball link end where it screws in to the ball link. After I had an aileron pull out after a couple flights, I always CA these now. I also believe that I will replace the ball links with the beefier Dubro's from now on as well. Likely over kill, but after loosing that aileron surface in air, I'm not taking changes on a surface that is more critical like rudder, or even worse, elevator.
Old Apr 16, 2012, 04:39 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
Kinda bummed I am going to Houston for 3 weeks and won't really be doing any flying or building or tinkering with airplanes.
davebloomer is offline Find More Posts by davebloomer
Old Apr 16, 2012, 05:08 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Well at least your planes can relax now and they will be safe!
heritageflyer is offline Find More Posts by heritageflyer
Old Apr 16, 2012, 05:12 PM
Joined Nov 2008
Originally Posted by SnowDog1974 View Post
I was actually able to "uncrimp" the brass sleeves (applied pressure using pliers on the "edges") so I could undo the wires and redo them. I reused the brass sleeves but I also have new brass tubing I could use if I didn't want to reuse the old sleeves.
I smash flat with small ViseGrips and CA and I have still undone them by squeezing on the edge, working along it with needle nose or same ViseGrip. CA cracks and shatters off. Tube opens up enough to change it. Even reused the same tube and resmashed and CA'd.
Old Apr 16, 2012, 05:13 PM
robj is offline
robj's Avatar
Joined Nov 2008
Lots of clubs in houston to hang around if you are there on the weekend.
Old Apr 16, 2012, 05:28 PM
Joined Jun 2011
Wife and little boy are going with me. Don't think ill have much free time that I get to decide the plans.
Old Apr 16, 2012, 05:44 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Wrong forum...
Park_aviator is offline Find More Posts by Park_aviator
Old Apr 16, 2012, 06:01 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
Originally Posted by Park_aviator View Post
Wrong forum...
the circle flyers forum is marked "Park Flyers"
aronph is offline Find More Posts by aronph
Old Apr 16, 2012, 06:24 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
'nuff said!
Luv3d is offline Find More Posts by Luv3d
Old Apr 16, 2012, 06:30 PM
DeadStick Dave is offline
Find More Posts by DeadStick Dave
I AM Smiling
DeadStick Dave's Avatar
Joined Dec 2007
Capt. NOrway moved to Houston -- wonder what happened to him?
DeadStick Dave is offline Find More Posts by DeadStick Dave
Old Apr 16, 2012, 06:35 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
omg!!!!!!!!!!!!!!!!!!!!!!!!! dude my mom is being lazy and wont vid tape my sweetness i am having right now hover tail touches just became really easy so are KE spins but i cant even hold a KE because i dont have any mixes and it pulls tarwds the wheels.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
