Old Apr 15, 2012, 06:52 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
Originally Posted by Stoned doggie View Post
just went for a hover catch on my 42" and i turned off the throttle alittle to early, i went for the grab and i went no throttle and it started dropping to early and the tail slipped from my hands and at the same time i droped my radio.
the rudder hit the ground and then MG hit then it was on a sliht hill so it flipped over upside down. So i pick my radio up quick because i was worried the throttle got pushed up and it was so i moved it down but the tx switch was on off.
So i pick up my plane, laugh and walk back to house. (I think the laugh was Holy s**t im lucky)
A great reason not to hover catch.
wamsy55 is offline Find More Posts by wamsy55
Old Apr 15, 2012, 07:14 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
yea but i know i will try it again and i know safty hawk will keep coming in my mind, i swear dude every single time i get close enough and thinking about the hover catch i think of the image he had...
skarface is offline Find More Posts by skarface
Old Apr 15, 2012, 07:18 PM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
Change your name to multiple scarface
3Dplank is offline Find More Posts by 3Dplank
Old Apr 15, 2012, 07:51 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
haha i will only do that if i do get hit so when you see my name as multiple scarface you know what happen
Old Apr 15, 2012, 08:46 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by hugocraft View Post
Random question:
Trying to fix a really old garage door which works great but the pulley/sprocket at the other end is gone and the chain would just make a 180 turn around a 5/8" diameter bolt. Well that bolt is 90% cut through now and that’s when I realized what was happening. Where I'm living used to be a rental house so someone rigged this up to get the garage door to work.
But I need a pulley like a belt guide or a sprocket like off a bicycle that is <1" diameter but can mount to a 5/8" hole that has a valley to fit a chain that is 3/8" wide.
I could temporally put in a new bolt but it will eventually cut it and it can't be good for the motor. Or another temporary thing would be put some washers on a new bolt to let them spin on the bolt but they might cut the bolt too.
Looking on advice on what to rig up or where I can order something to fix it for a decent price.
If you strike out on the idler pulley....possibly just a bearing would work OK in your situation...but the Idler pulley would be perfect.
Honestly...looks like a challenge Cmala's machine shop would like a crack at...
No...read again...no catch to it...this time any way....
Bivens is offline Find More Posts by Bivens
Old Apr 15, 2012, 09:37 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
would you guys suggest me getting a castle 50 esc instead of the hacker x-40 so i can mkae my servo's 6V, what would they be now with the x-40, or can i somehow program my x-40 and make the servo's 6V.
Or is it not worth it becuz its not much of a difference?????
Old Apr 15, 2012, 09:40 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
the output voltage isnt the only advantage of the ice lite 50 over the x40
aronph is offline Find More Posts by aronph
Old Apr 15, 2012, 09:59 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
More program ability, more voltage to the servos, smoother starting of the motor. Just to piont out a few of the pluses of the castle.
losifanatic is offline Find More Posts by losifanatic
Old Apr 15, 2012, 10:00 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
hacker *should* be 5.5v output and no you cant program it different. Castle has more bells and whistles but at a cost. If your really interested in 6v output i would invest in a BEC
shadow102 is offline Find More Posts by shadow102
Old Apr 15, 2012, 10:10 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
no comment lol (biting my tongue)
3DNater is offline Find More Posts by 3DNater
Old Apr 15, 2012, 10:14 PM
pvogel is offline
Find More Posts by pvogel
Team JetiUSA
pvogel's Avatar
Santa Clara, CA
Joined Nov 2008
Originally Posted by StormJunkie View Post
Actually, it will hold the 45 degree downline for plenty long enough to check balance. Momentum and gravity are offset by lift and it holds the line...
Now what bigster just said confuses me a little. I would think that if it tucked it would be nose heavy, and if it it tried to pull up from the 45, it would be tail heavy.
It's simple, if it's tail heavy and you trim it out for a level cruise you'll have dialed in down elevator to push the heavy tail up. When you put it in the 45 downline as you gain airspeed over the tail it will tuck to the gear. Similarly, if it's nose heavy and you trim it out, you'll have dialed in up elevator to hold the heavy nose up. When you put it into a 45 degree downline with power off, as it gains airspeed it will pull to the canopy.
Peter+
pvogel is offline Find More Posts by pvogel
Old Apr 15, 2012, 10:37 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
3DHS airframes are so well designed that I've started using knife edge coupling to set the CG (as per AJ's All Things Slick DVD if I remember correctly). Just trim for level flight at 1/2 to 3/4 throttle. Roll to KE and check if it pulls to the gear or the canopy. Pulling to the gear is tail heavy and pulling to the canopy is nose heavy. Adjust CG to get the least KE coupling, and you'll have an amazing flying airplane. They will usually have slight push on the elevator when inverted, and will excell at both precision and 3D.
G.P. is offline Find More Posts by G.P.
Old Apr 15, 2012, 11:53 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
That is a great tip! I'll have to try that on my 70" slick. The maiden is still probly 3 weeks away but the plane is almost done. I'm waiting on my buddy making the 4 hour drive for it and that is when we have it slated.
Old Apr 16, 2012, 04:16 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
mate, get a twisted hobby foamy! :P you are crashing too much! and use foamy for low stuff and slick for hig stuff!
rimaarts is offline Find More Posts by rimaarts
Old Apr 16, 2012, 04:17 AM
rimaarts is offline
Joined Jul 2011
i dont know about hacker x40 but x55 had IN THEORY 5.8 output... and when i swapped to ICE for 6v i didnt see a BIG improvement...
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
