Old Feb 17, 2013, 09:57 PM
Da Big_G is offline
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Originally Posted by turnerm View Post
If I'm parallel charging 2 4s batteries I assume the voltage in your formula still stays at 14.8V?
Yes.
Da Big_G is offline Find More Posts by Da Big_G
Old Feb 17, 2013, 10:06 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Now you got it.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Feb 17, 2013, 10:16 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
So my new 4Runner has a 400W 120V plug in the back. It would be nice to use my meanwell power supply and my iCharger 3010B that way but the meanwell is a 1000W power supply.
I know NOTHING about electricity (voltage, wattage, etc). I assume it's feasible to plug my charger setup into the outlet as long as I don't go above a certain amp charge rate? Is there any way to figure out what that rate might be? Or is it best just not to use that at all for this purpose and stick with my deep cycle field charging battery?
Don't worry, if you overdo it you just blow a fuse. I've done it twice
Simple easy fix. Mine isn't 400w either, that's a nice enhancement. Mine is only like 100 watts or so, I can barely charge anything back there.
ryan_m is offline Find More Posts by ryan_m
Old Feb 18, 2013, 06:19 AM
alfabeast is offline
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Originally Posted by zmonster97 View Post
What day are you going?
sunday
alfabeast is offline Find More Posts by alfabeast
Old Feb 18, 2013, 07:31 AM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
Originally Posted by bryansifsof44 View Post
nope you should be able to parallel any amount of 4s batts at W(watts your system is rated for) / V (nominal voltage of pack...in your case 14.8V for a 4s) = A (amps you will be setting)
In other words... in your car 400W / 14.8V = 27A. Remember your efficiency will be around 70% with that system so 27A x .70 =18.9A safely no matter how many packs you have in parallel. 6s @ 22.2V your gonna be restricted to about 12.5 amps no matter how many packs you have hooked up.
At you house if you have a 24V power supply you are regulated by your 30A built in limit of the charger.
Just curious, but why would you want to go from DC to AC and back to DC? Wouldn't it be more efficient just to run a DC line off of the fuse panel to back of the vehicle? And wouldn't a 400W load run the battery down quickly?
blaiss is offline Find More Posts by blaiss
Old Feb 18, 2013, 07:36 AM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
i killed the battery in my dads truck charging 6S's at the field. we had to get a jump fro someone else.
cale10 is offline Find More Posts by cale10
Old Feb 18, 2013, 07:57 AM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
zmonster97,
Let me know what you come up with since I'll eventually want a 4" red spinner for the gas powered 103" with falcon prop. Would like to just buy it, drill it, and slap it on
HugoCraft is offline Find More Posts by HugoCraft
Old Feb 18, 2013, 07:58 AM
Aerobatic Fanatic
HugoCraft's Avatar
Joined Sep 2007
Just jump it from a charged 4s lipo next time if you have one laying around. I've done that once on a friends van
Old Feb 18, 2013, 08:32 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Thanks Bryan. But just to be clear I would be using the same power supply at the house and in the car. But I'm assuming what you're saying is that the limiting factor at home is the 30A max charge rate of my charger right?
turnerm is offline Find More Posts by turnerm
Old Feb 18, 2013, 08:36 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
The car has to be running in order to utilize this outlet. But yes... I would drain the car battery in a hurry if it weren't running.
The reason I'm trying to use AC power is because I've got my charger setup to run at the house and it goes off of AC. The car has both AC and DC outlets. The AC outlet can go up to 400W. So I want to simply take my meanwell power supply and my 3010B with me when I go flying and simply plug it up in the car just as I would in the house and charge my batteries that way.
I've also got a deep cycle marine battery for this purpose but I like having the flexibility of using both if I want to.
Old Feb 18, 2013, 08:38 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
That's true. It's odd though... in the manual they say not to use anything that pulls more than 10 amps from the DC outlet but they don't seem to specify for the AC outlet. They DO specify the watts though so I guess I should go by that (as Byran has done) instead and assume that the resulting amp draw is OK?
I could've sworn that I read somewhere at some point the other night that it was rated for up to 15 amps but now I can't find it.
Old Feb 18, 2013, 09:59 AM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by hugocraft View Post
zmonster97,
Ok, but I won't be getting a painted spinner.
zmonster97 is offline Find More Posts by zmonster97
Old Feb 18, 2013, 10:12 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
who's going to WRAM? I'm planning for friday, but may be there saturday instead.
Irg is offline Find More Posts by Irg
Old Feb 18, 2013, 10:15 AM
zmonster97's Avatar
Joined May 2011
I hope to! I want to go friday, but I'll probably be there saturday.
Old Feb 18, 2013, 10:25 AM
Joined Oct 2011
Totally.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
