Old Feb 17, 2013, 07:25 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Originally Posted by turnerm View Post
The 3010B can only go up to 30A max. But I agree. It's an awesome charger.
Max on the 3010B is 30A, that makes the charger rating under 670W on 6s and under 450W max for 4s. So to get the 1000W that it is rated for you need to be charging 9s or higher at almost 30A. In other words it is a 670W charger at 6s and a 445W charger on 4S... And max 500W on any batt with a 12V power source.
bryansifsof44 is online now Find More Posts by bryansifsof44
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
How to kill a servo in about 3 minutes ...
How to kill a servo (3 min 44 sec)
wamsy55 is offline Find More Posts by wamsy55
Old Feb 17, 2013, 07:32 PM
quadracer is offline
Find More Posts by quadracer
No, I won't ship it. Don't ask
quadracer's Avatar
United States, IN, Derby
Joined Feb 2012
Originally Posted by wamsy55 View Post
I told you to get the TowerPro MG's.......
quadracer is offline Find More Posts by quadracer
Old Feb 17, 2013, 07:59 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
just be glad it wasnt the elevator servo!
cale10 is offline Find More Posts by cale10
Old Feb 17, 2013, 08:04 PM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
Nice flying Wamsy.
On a different note, today was a productive day (I hope). I was able to piece together the motor box to my old 47" edge (without a motor box kit). It's all back together, but with 40mph gusts, there was no way I was going to try a remaiden. 2 years to do a rebuild, not so bad .... lol.
Hopefully it flies decently as it was thoroughly destroyed. lol
CrashesALot is offline Find More Posts by CrashesALot
Old Feb 17, 2013, 08:09 PM
alfabeast is offline
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
will there be any "goodies" at the WRAM show? I plan on stopping by ... I need a new 48-in airframe, and could be tempted with a new velox, and I really need an Omega 130 motor adapter BAD. That's just for starters.
alfabeast is offline Find More Posts by alfabeast
Old Feb 17, 2013, 08:10 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Nice flying wamsy. I have decided I'm not nearly hard enough on my planes. Lol.
Aaeolien is offline Find More Posts by Aaeolien
Old Feb 17, 2013, 08:14 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
What servo were you running in it?
3Daddict is offline Find More Posts by 3Daddict
Old Feb 17, 2013, 08:21 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
What day are you going?
zmonster97 is offline Find More Posts by zmonster97
Old Feb 17, 2013, 08:33 PM
cale10 is offline
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
yestermorrow.
Old Feb 17, 2013, 08:45 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
My Review!
Woot! Check it out! My review is finally published!
Even made the cover too!!!!
Be sure to check your Electric Flight mag
Alex Schauer is offline Find More Posts by Alex Schauer
Old Feb 17, 2013, 09:22 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Congrats
losifanatic is offline Find More Posts by losifanatic
Old Feb 17, 2013, 09:31 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by bryansifsof44 View Post
15 amps is the rating of the standard household plug.
400W/120V= 3.33Amps@ 120V so it just over 20% of what a household outlet would handle. So at 400W you could charge 6s batts at 400W/22.2V=18A x 70% efficiency = 12.5A safely.
4S would be 400W/14.8V=27A X 70% efficiency = 18.9A.
So I wouldn't charge greater then 19 amps on 4s or 12.5 amps on 6s... Hope this helps.
If I'm parallel charging 2 4s batteries I assume the voltage in your formula still stays at 14.8V?
turnerm is offline Find More Posts by turnerm
Old Feb 17, 2013, 09:54 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
I am running HS-225's on the tail and they have been great, but on the ailerons I have been through 225's and HS-5245's. Some have lasted 20 flights, some have lasted one or two.
The plane with the Motrofly motor is so sweet though. I need to order another motor for my 71" but I just need to get around to fixing it first.
Old Feb 17, 2013, 09:55 PM
Joined Oct 2011
If I'm parallel charging 2 4s batteries I assume the voltage in your formula still stays at 22.2V?
nope you should be able to parallel any amount of 4s batts at W(watts your system is rated for) / V (nominal voltage of pack...in your case 14.8V for a 4s) = A (amps you will be setting)
In other words... in your car 400W / 14.8V = 27A. Remember your efficiency will be around 70% with that system so 27A x .70 =18.9A safely no matter how many packs you have in parallel. 6s @ 22.2V your gonna be restricted to about 12.5 amps no matter how many packs you have hooked up.
At you house if you have a 24V power supply you are regulated by your 30A built in limit of the charger.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
