Old Feb 06, 2013, 06:51 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by FIXXIN2FLY View Post
stopping and self correcting was not terribly uncommon in the slimey glow days. It is quite humorous when you see it in person.
If only you could do it both directions while in flight....you would have the only variable pitch gas system EVER!!!!
But if it did it in flight when you didn't want it to....Hooo boy...Turbo Raven crash... At the beginning of the video the TV station says it was an engine failure, but it was not, Wayne would go to reverse pitch for the down leg of this maneuver, but on this flight, when he tried to go back to positive pitch, it did not do so...So, he pancaked the plane. Wayne did survive the crash, but is something like 1.5" shorter now do to all the spinal crushing...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 06, 2013, 07:05 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Not the ignition....all ignitions spark when a magnet passes the hall sensor....they can not sense direction. It's in the intake/exhaust/spark timing combination...that particular engine happens to bounce off of the compression stroke on flips where it did not start.....and it fires on the "return" as it bounces through the compression stroke.....then it keeps going. Engines with less spark advance and not extremely aggressive intake/exhaust port timing have all of the "action" close enough to TDC that they will indeed run in reverse.....not as much performance in reverse of course...but it will run. Typically just getting the throttle in the "right" spot minimizes the problem.....but today I was starting with fresh radio programming.....
After the first real start, it was easy to zone in on the proper "idle" epa and then I was in fine shape for the rest of the afternoon....but that first time was interesting today...
Bivens is offline Find More Posts by Bivens
Old Feb 06, 2013, 07:14 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Park_aviator is offline Find More Posts by Park_aviator
Old Feb 06, 2013, 07:15 PM
DJO is online now
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Originally Posted by Park_aviator View Post
If anyone wants to buy a NIB 48" EPP Extra airframe PM me Slightly damaged from shipping...( nothing 30 seconds won't fix) Won it in the garage sale.
PM Alex, he's going to be building one. Not sure if he already ordered it though, so he might take it!
Dan
DJO is online now Find More Posts by DJO
Old Feb 06, 2013, 07:18 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
just dont mess up the thrust angle on them. they fly terrible after that.
cale10 is offline Find More Posts by cale10
Old Feb 06, 2013, 07:29 PM
aronph is offline
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
Originally Posted by bullittjeff View Post
What's causes the OS motor to start backwards. It's the only brand of engine I hear that does it? Is it something to do with ignition?
itit has to do with it being two stroke like bivens said...the old 2 stroke Detroit diesels were the same way....if you turned the motor over with the key and the engine kicked back just as you let off the key it would run in reverse....so my question is....if the engine is running backwards, would I have 10 gears in reverse and 2 forward?
aronph is offline Find More Posts by aronph
Old Feb 06, 2013, 07:58 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Ha! Ive wondered that myself
Manta1 is offline Find More Posts by Manta1
Old Feb 06, 2013, 08:03 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
LMAO
Tell ya what...buy me ten beers and two shots and I shall give you the answer to your riddle....
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Feb 06, 2013, 08:04 PM
wedoitall is offline
Find More Posts by wedoitall
wedoitall's Avatar
United States, WV, Clay
Joined Sep 2012
pm sent
wedoitall is offline Find More Posts by wedoitall
Old Feb 06, 2013, 08:22 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
And what a lot of people do not know, that most big pile drivers are nothing more than a two stroke diesel engine, that does not have a crankshaft... To start, a winch pulls the piston up, then fuel is injected into the cylinder. then the piston is dropped, and compression ignites the fuel which drives the driver down, and the piston up, as once it reaches the top, it drops, onto a fresh charge of fuel, and just keeps going until the fuel is shut off.....
Your trivia lesson for today.....(for those that didn't know it already)
SteveT.
Old Feb 06, 2013, 08:28 PM
3Dplank is online now
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
SteveT.
I thought a pile driver was when Hulk hogan picked up Andre the giant over his head
3Dplank is online now Find More Posts by 3Dplank
Old Feb 06, 2013, 08:38 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
.......double post
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
That could be....or it could be Vin Diesel doing it twice....(two stroke)
SteveT.
Old Feb 06, 2013, 09:08 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
I heard the Original engine name was SO, engineering got it backwards....
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 06, 2013, 09:23 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Well, at least it wasn't...."so-so"....Oh wait...that's DLE...
SteveT.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
