Old Jan 30, 2013, 11:04 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
Need help solving major problem!!
I need some help solving a major issue i have run into with my extra. My wingtube is a vary tight fit, but after talking to 3dhs I was told that was normal. Well I got it in the plane and when I was removing it it got stuck and then when I tried to turn it the receiver broke at the glue joints. Now the wing tube is stuck in my plane with no way to get it out, if I could remove it I can re-glue the receiver as the glue joints are the only things that broke. I sent an E-mail to Noll about it and I am sure he will get back to me soon. However sometimes people on here have some good ideas on how to solve issues like this.
3Daddict
3Daddict is offline Find More Posts by 3Daddict
Old Jan 30, 2013, 11:06 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
get a can of lithium grease and hit the affected areas. work it slowly, then reglue receiver tube.
Irg is online now Find More Posts by Irg
Old Jan 30, 2013, 11:08 PM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
How would I get the lithium grease into the receiver with the wing-tube still in it?
3Daddict.
Old Jan 30, 2013, 11:09 PM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
hmm, I was assuming you have some degree of play/movement bavk and forth.
Old Jan 30, 2013, 11:23 PM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
No, it just froze up for some reason. it was moving fine, snug but still able to turn. Then for some reason it just got stuck and when I tried to turn it the glue joints broke. I am scratching my head trying to figure out a way to get it out and can not think of anything.
Old Jan 30, 2013, 11:25 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
put it in the garage and check it in the morning
3drcparts is offline Find More Posts by 3drcparts
Old Jan 30, 2013, 11:26 PM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
I think the problem is that the receiver just spins in circles now every time I turn the tube. Combine that with the tight fit and that is why I can not get the tube out. i would try and grip the fiberglass receiver but I do not want to crack it. i guess i will have to weight and see if noll has any ideas, if not there is a local guy I know that is vary good at fixing planes. i could ask him if he has any ideas.
Old Jan 30, 2013, 11:28 PM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
That is what I am going to have to do for now, i need to get some sleep. I do not want to mess with it and make it worse right now. As there is nothing broke except for a glue joint. if anyone else has any more ideas please share them.
3Daddict
Old Jan 30, 2013, 11:31 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
3Daddict
Answered in the other thread....
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 31, 2013, 06:58 AM
Alex Schauer is online now
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
http://www.helimax-rc.com/helicopter...ssl/index.html
WANT!!
Brushless Axe 100 CP with night flying lights, TX-r so I can use my Futaba....
Alex Schauer is online now Find More Posts by Alex Schauer
Old Jan 31, 2013, 08:27 AM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
3Daddict
My 87shp wing tube started to get tight last summer so ended up using DuPont Teflon spray that I had laying around and seems to work really good. On the 103 I'm building the tail tubes are really tight so going to use that.
But since yours is stuck with the receiving tube spinning in the fuse the only thing I can think of to hold the receiving is rubber oil filter wrenches. I would think that would hold it without damaging the spinning tube or marking it up but you'll have to try it to find out. Also they only hold one direction so you would need 2 to go back and forth or just trying spinning the wingtube only one way to get it out. Something like this
then try to keep twisting to get it out so you can lube both up. Not sure what if anything will soak into the gap with it stuck but you can try with the fuse on its side so gravity can help pull whatever liquid you try to get in there.
HugoCraft is offline Find More Posts by HugoCraft
Old Jan 31, 2013, 09:38 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Also keep in mind that temperature is a factor in how tight the tubes are. My 87 wing tube is very difficult to install/remove when it's below 35F.
Ace4 is offline Find More Posts by Ace4
Old Jan 31, 2013, 09:48 AM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
I don't know if this is a nono, but my 70 Velox tube was so tight I was absolutely certain I was going to break something. I took some medium grit sand paper to it and took off just enough to make it snug but easy to insert.
FireyFate is offline Find More Posts by FireyFate
Old Jan 31, 2013, 10:17 AM
Joined Feb 2011
I've heard that weakens it...idk though.
Old Jan 31, 2013, 10:52 AM
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Taking material off of anything weakens it... I'd guess we're talking a fraction of a millimeter though.
At any rate... I'm flying that Velox on an overpowered A50-12L and have given it many full throttle blenders with no problem thus far.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
