Old Jan 24, 2013, 09:11 AM
deerfreak is offline
Find More Posts by deerfreak
Joined Jul 2008
deerfreak is offline Find More Posts by deerfreak
Old Jan 24, 2013, 09:25 AM
obrieri is offline
Find More Posts by obrieri
Riley O'Brien
obrieri's Avatar
United States, NE, Lincoln
Joined Jul 2008
Originally Posted by cale10 View Post
BTW guys can using less expo on te sime transfer over to real life?
Yep, Expo on the sim(phoenix or realflight) is usually pretty accurate.
obrieri is offline Find More Posts by obrieri
Old Jan 24, 2013, 09:37 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'm suprised to hear about how many people fly with such low expo! I thought that I was in the minority by typically flying in the mid to low 60's on most planes but it sounds like I'm actually on the high end of the range!!
I usually start out at 75 all the way around and then work my way down to what feels right. If you're not careful then expo can actually make you think you need more when you need less. I was struggling with flying my nano CPx in the house until I started experimenting with expo. I found that I actually had too much and I eventually settled on no expo for indoor flying and only about 10 or so for outdoor flying. The expo was causing me to chase the heli around a lot and when eliminating it I found that I had the control I was looking for.
On my planes I find that I typically like lower expo on my rudder and a little higher expo on my ailerons while the elevator is right in the middle somewhere.
turnerm is offline Find More Posts by turnerm
Old Jan 24, 2013, 09:40 AM
obrieri is offline
Riley O'Brien
obrieri's Avatar
Joined Jul 2008
I don't like having to crank on the sticks to get the deflection I need. I usually try to find a "sweet spot" where the center is soft enough that it isn't twitchy but not so much expo that that I need to bang the sticks around to get it to respond.
Old Jan 24, 2013, 09:48 AM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
40-45 for high rates is my typical expo. Then adjust from there, some planes if I find myself 'chasing the sweet spot' in a hover or other move, I'll bump up the expo. Others might feel dead, and I lower the expo a bit. This is on a JR9503.
ryan_m is online now Find More Posts by ryan_m
Old Jan 24, 2013, 09:49 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Originally Posted by hugocraft View Post
With helicopters I run <10% expo and 3d planes <45% expo. Since I'm low with helicopters maybe I need to try lower with the planks
Helicopter blades stay at relatively low angles of attack in their flow, so over the range of deflection the force generated is still fairly linear with deflection. Therefore the pitch/roll rate of the heli will be close to linearly proportional to the transmitter stick position. This lends itself well to low expo, since it behaves how you think it should. Airplane surfaces are not full moving like a heli blade, only part of the surface deflects, so you aren't changing the angle of attack of the surface, you are effectively changing the camber of the airfoil on that surface. This tends to result in pitch/roll responses that are not that close to linearly proportional to stick position, so some level of expo helps maintain that "linear" response feeling. Also with the massive deflections on most 3-d planes, the response is very non-linear since you will end up stalling the surface at some deflection, totally changing the slope of the response beyond that deflection.
I run low expo on helis (0-30%) and moderate on 3-d planes (30-50%). That is what "feels" the best to me personally. There is no right answer, though, you just have to fly what feels comfortable to you. I was surprised to learn that several of the IMAC unlimited pilots at the contest I went to use 50-60% expo on their low rates, it's all a personal preference and there is no right answer.
Ace4 is offline Find More Posts by Ace4
Old Jan 24, 2013, 09:52 AM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Very informative post. Thanks for taking the time to post that!
joesmith285 is offline Find More Posts by joesmith285
Old Jan 24, 2013, 09:58 AM
obrieri is offline
Riley O'Brien
obrieri's Avatar
Joined Jul 2008
Yes very well put.
Old Jan 24, 2013, 10:58 AM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
Yes very well put Ace since that makes sense why I'm happy with the feel on helicopters and airplanes but with different expos.
HugoCraft is offline Find More Posts by HugoCraft
Old Jan 24, 2013, 11:53 AM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
Full scale aerobatic news posted 4 hours ago on Facebook from Skip Stewart:
"There is a lot of false information about Kirby out there. I was flying off his wing practicing a dual routine when it happened. So this is the correct information. We were flying a formation high alpha pass. At the end of the runway Kirby's engine quit. There was nowhere to land. He descended into a rocky ravine and crashed onto the side of a steep embankment. I was watching him the whole way. The plane crashed into small trees and flipped over. The airplane was badly damaged, but Kirby extracted himself and walked to a clearing. I had immediately called for the rescue helicopter and they were there very quickly. A testament to the readiness of the El Salvadorian military. Kirby is fine with superficial scrapes and bruises."
Kirby as in Kirby Chambliss and I'm glad he's okay!
I put my Edge 540 in a tree last year. It looked about the same as Kirby's. Of course, I was standing on the ground when it happened.
blaiss is offline Find More Posts by blaiss
Old Jan 24, 2013, 12:55 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
I hate that one tree!
heritageflyer is offline Find More Posts by heritageflyer
Old Jan 24, 2013, 02:30 PM
jtaylor996 is offline
Find More Posts by jtaylor996
Registered Crasher
United States, TX, Coppell
Joined Feb 2011
I'm just gonna put a challenge out there:
$20 to the first pilot that does an "inverted hover" 30s or longer at the FLI in grapvine. Nose down, stationary. Video required.
I think it's possible, but somebody needs to make it happen!
jtaylor996 is offline Find More Posts by jtaylor996
Old Jan 24, 2013, 02:42 PM
anthony7820 is offline
Find More Posts by anthony7820
Team CJ Youngblood
anthony7820's Avatar
United States, WV, Wheeling
Joined Jul 2009
You could always reverse the motor wires and drop the airplane from another airplane.
Do helicopters count?
anthony7820 is offline Find More Posts by anthony7820
Old Jan 24, 2013, 03:01 PM
wedoitall is offline
Find More Posts by wedoitall
wedoitall's Avatar
United States, WV, Clay
Joined Sep 2012
just in my short time flying ive had 2 trees reach out and grab my planes. luckily so far it has been on foamys
wedoitall is offline Find More Posts by wedoitall
Old Jan 24, 2013, 03:07 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
I'm going to put an engine on the back of a plane
Park_aviator is offline Find More Posts by Park_aviator
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
