Old Oct 09, 2012, 08:00 AM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
I did a barrel roll in in a 737-700
Park_aviator is offline Find More Posts by Park_aviator
Old Oct 09, 2012, 08:07 AM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by teookie View Post
This thing is cool.
I like this, someone know what it is / are their planes for it?
DaOldGuy is offline Find More Posts by DaOldGuy
Old Oct 09, 2012, 08:47 AM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by joesmith285 View Post
I was once told that a plane ejected its battery and on a fast dowline the prop spun very fast and back fed electricity into the system allowing for a quick flare to landing. I have no idea if this is true but would be fun to experiment with. I was told that if you use a starter for like nitro engines you could spin an electric motor and it would power the plane.
I highly doubt this is possible, just a rumor that I heard.
It worked for UTjason in a 68 velox. Confirmed with electric nitro starter after a safe no-battery and too-good-to-be-true landing.....at House Mountain.
Lucky I suppose...but if there'd been a separate RX pack, it would've never been required.
Bivens is offline Find More Posts by Bivens
Old Oct 09, 2012, 08:59 AM
ryan_m is online now
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
So all this brings up some interesting ideas... what happens then when you are in say a power off dive and the prop is spinning madly all by itself? Does the electricity generated by this backfeed the power produced by the ESC and risk causing problems to aircraft's power system?
ryan_m is online now Find More Posts by ryan_m
Old Oct 09, 2012, 09:13 AM
CrashesALot is offline
Find More Posts by CrashesALot
Team 3DHS
CrashesALot's Avatar
Western CT
Joined Aug 2009
I seem to recall that a similar situation killed the esc of a certain vr-1. The one rocket launched at Ohio huckfest a few years back. The prop was spinning so quickly on the upline, that the each no longer worked. Luckily, there was still power for the servos. I believe the plan had been to rocket launch it, then fly it with the lipo on board, but they ended up just gliding it down.
CrashesALot is offline Find More Posts by CrashesALot
Old Oct 09, 2012, 09:16 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Someone needs to set up a data logger and test? Mike will do it.
Old Oct 09, 2012, 09:28 AM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
The thing that baffles me with this, is that I thought the esc had a bunch of MOSFET's in it to turn power on and off to the different windings of the motor. How the heck to these things work in reverse? I guess there's a way...
Also, based on what I've read, back EMF is opposite to input voltage.
teookie is offline Find More Posts by teookie
Old Oct 09, 2012, 09:52 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I was told by castle with rc car escs that when you hit the breaks it back feeds the electricity from the motor to the battery as the esc can not dissipate that much power at one time with out dumping it to the battery. A spinning motor is a generator.
losifanatic is offline Find More Posts by losifanatic
Old Oct 09, 2012, 10:02 AM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
If I move a servo back and forth with a capacitor plugged into the RX I can get the spektrum RX to flicker and light up if I have the TX on for it to connect to. The servo acts like a generator powering the RX and the capacitor makes it easier since its holds some of the charge like a temporary battery.
I plugged in a voltmeter to the RX and I could generate 4 volts by moving the servo back and forth. Its easy experiment on an rc car since they usually only have one servo and a capacitor plugged in
HugoCraft is offline Find More Posts by HugoCraft
Old Oct 09, 2012, 10:13 AM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
It's something I got bored and made, no plans. Sizing was more "hey this looks about right" than anything else. There are lot of videos & tips if you go to the "Foamies (Scratchbuilt)" forum and then look in the "Foamboard Scratchbuild University" thread. You buy a couple sheets of dollar tree foam board, covert them in packing tape, and hot glue them together. If you really want more info about the plane, send me a PM.
Ace4 is offline Find More Posts by Ace4
Old Oct 09, 2012, 10:27 AM
DaOldGuy is offline
DaOldGuy's Avatar
Joined Dec 2007
Thanks,... I will look around the thread and see what I can sort out. There is nothing wrong with winging it.
Old Oct 09, 2012, 11:30 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
It's like Dynamic Braking or Regenerative Braking:
http://en.wikipedia.org/wiki/Regenerative_braking
heritageflyer is offline Find More Posts by heritageflyer
Old Oct 09, 2012, 12:10 PM
teookie is offline
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
It's the brushless aspect of airplane motors that confuses me. I understand how a brushed motor acts as a generator.
I guess that ESC's can work in reverse. They are such complicated little bits of tech that it surprises me.
Old Oct 09, 2012, 02:26 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
It looks like the fuselage is made from a piece of ABS plastic gutter drain pipe. There used to be a couple of planes that were made from the stuff called the Duraplane, and the Durabat. The Duraplane was a sport trainer, and the Duabat was a more aerobatic version.....
Edit....I guess they are still made......Duraplane However, it seems the Durabat is now called the "Aerobat"...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 09, 2012, 03:43 PM
SportFlyer2 is offline
Find More Posts by SportFlyer2
United States, TX, Palacios
Joined Feb 2009
SteveT
Hey, that was my first plane ever...I had the Taildragger version of the old Dura-plane...K&B .20 Sportster and 3 channel...
SportFlyer2 is offline Find More Posts by SportFlyer2
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
