Must be your receiver!
Latest blog entry: 3DHS 48" Extra Windy Day Flying
Is that fourth paces in range check mode? If it is you are good to go.
Latest blog entry: smacked the beeeeg slick
I got the ones with the studs for the 71 Slick, has a big spin on colored aluminum nut. CA'd the stud in the wing after checking for correct length into the Fuse. Those are nice! Secraft-Wing-Bolts |
Did it stall or did NOTHING happpen?
Is the servo moving?
Latest blog entry: Weak Signals Toledo 2012
You are going to have to some messin around to isolate the problem in order to fix it. This random guessing will result in another replacement airframe
Turn tx on then plane Check for power to rx and servos Check power to the motor. Walk the 40 paces and check all again If you can come to the conclusion that you think it may be your rx, at that point switch rx's with another plane and see if you can duplicate the problem in the other plane, If not, try to duplicate the problem in the original problem plane with another rx. If you are able to do that, then its pretty safe to assume its something other that the rx. (or two bad rx's....not likely) Follow me? Process of elimination by use of controlled experiments. Good luck |
Latest blog entry: The family continues to grow
| Thread Tools | |
| Discussion You are addicted to flying when.... | postalflyer72 | Electric Plane Talk | 34 | Jul 16, 2011 11:12 PM |
| Video Angelo Lomelí flying 3D antics | Jorge Fernandez | Electric Plane Talk | 0 | Sep 30, 2006 02:22 PM |
| Tiger Moth antics - flying inverted w/video | SnoJetter | Parkflyers | 49 | Sep 16, 2003 07:25 PM |
| Help! Getting addicted to Park Flying | fly4fun | Parkflyers | 11 | Feb 16, 2002 10:58 AM |
| You know when your addicted to Slow Flying when..... | Gman | Parkflyers | 51 | Aug 05, 2001 03:19 AM |
