Old Sep 24, 2012, 03:22 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Your meter just measures the voltage and the amps and then multiplies them together to show you watts.
Some of your power can be lost because it is just being used to generate heat. This will be different with different motors.
Your voltage under load along with motor kv sets the prop rpm. If your batteries let the voltage decrease under load then your rpm will drop and your total watts will drop.
Kv is rpm per volt
cmala is offline Find More Posts by cmala
Old Sep 24, 2012, 05:39 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
Just saw this over on FG in the huckfest coverage from the past weekend.
Kansas City KS Huckfest 2012 Pete Rosas Freestyle (1 min 49 sec)
maybe wrong model selected...????
HugoCraft is offline Find More Posts by HugoCraft
Old Sep 24, 2012, 05:41 PM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
Ya that looked pretty wicked for sure! Brandon Chitty's 103 extra demo was sick for sure!
Kansas City KS Huckfest 2012 Brandon Chitty Demo (6 min 41 sec)
joshet89 is offline Find More Posts by joshet89
Old Sep 24, 2012, 07:39 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Maybe, but for sure there was no pre-flight control surface check.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Sep 24, 2012, 07:40 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Hell he was even having trouble taxiing and takeing off! What a ding dong!
I suspect he had two receiver channels mixed up..plugged in wrong.
Alex Schauer is offline Find More Posts by Alex Schauer
Old Sep 24, 2012, 07:53 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
http://www.youtube.com/watch?v=13a8BeaL0U4
OUCH!!!!!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 24, 2012, 07:56 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
It looked like he was having issues on the runway. Then I thought it looked like his ailerons were reversed on takeoff.
tominator06 is offline Find More Posts by tominator06
Old Sep 24, 2012, 08:04 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Hey guys, I have previously spliced my pro bec into the battery lines but I think Ive decided to isolate my radio system from the esc on this next build and have decided to run a lipo for the rx. I already have pro bec installed in the plane with a deans on it. So I am trying to figure out whether to run a 3s or only a 2s. 2s obviously less weight and Im assuming that the radio system isnt going to use much as far as capacity goes. Is there a common size that folks use for this application? 70 AJSlick and its going to be mounted right at the wing tube insert inside the cabin for easy access.
ƒ2ƒ
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Sep 24, 2012, 08:13 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
ƒ2ƒ
Are you using HV servos? If so, then go with 3s and regulate the voltage to 8.2v. If you're not, then just go with 2s.
zmonster97 is offline Find More Posts by zmonster97
Old Sep 24, 2012, 08:20 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
Actually will probably run 6v to be on the safe side for this one. Trying the new XQ servos and not willing to push em till the jury is back in. How many milliamps do you think a flight or two will use, approx of course. Again I want to be on the safe side till I can get a few bench mark flights on it. I guess the other option would be to eliminate the bec pro and get a LIFE pack
Old Sep 24, 2012, 08:22 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I like how they call it aluvium instead of aluminum on the web page...nice!
going4speed is offline Find More Posts by going4speed
Old Sep 24, 2012, 08:41 PM
zmonster97's Avatar
Joined May 2011
Okay, then go with 2s and set your bec to 6v.
What are XQ servos? Never heard of them.
I am going to be using a 2s 1550mah battery for my receiver pack. So I'd say go with a 1300mah to 1800mah rx battery. I'm using electric also.
What?
Old Sep 24, 2012, 08:43 PM
FLY ANGRY
FIXXIN2FLY's Avatar
Joined Jul 2008
These are the XQ servos
3DHS 'native'
USA, TX, Spring
I looked up XQ servos and one of the slides on their webpage said it has an aluvium center section.
Old Sep 24, 2012, 08:47 PM
zmonster97's Avatar
Joined May 2011
Thanks!
Ok, gotcha.
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
