Old Sep 09, 2012, 10:56 AM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by BOSSIER_ROB View Post
It is the 45% AJ Slick in the orange color scheme. Chad must not have that one so it shows up as the old Dietrich Slick 540. I actually have one of those stuffed in the attic. It flies as bad as the Realflight version. Turd!
Great! Thank you.
Buzzed is offline Find More Posts by Buzzed
Old Sep 09, 2012, 01:49 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by Inverted-I-Fly View Post
48-57 balsa bigfoot would be better
Aw, come on.....a little positive thinking please.......I'm very happy to see a new prototype foamfoot...can't wait to get one.....that's gonna be FUN. I agree a 48-57 would be fun...but I'm happy to see what will be available, whenever they're ready to be seen....
Bivens is offline Find More Posts by Bivens
Old Sep 09, 2012, 01:50 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
New 103 is almost ready to fly....can't wait...but during the build, I learned something new and very important that I thought I'd better share with you guys........
Some of you saw my 104 get wadded up in Ohio a couple of weeks ago....well, I had bought a 103 to build, and this weekend I was working on the build when I found something important that caught me by surprise....
On my 104, I used the stock elevator servo extension wires......and my plane had about 180 flights in 15 months or so......I had never once looked again at those extensions......
There was a "chaffed" spot on both of them where they entered the fiberglass tube on the way back to the tail...the insulation was completely worn off of all 3 conductors in both extensions where they had rubbed against the tube. While using those extensions to program my 103 servos in the wings....the motion of the wire while I was shuffling around caused the ground to get into the signal wire and then the positive to get into both....causing my servos I was programming to go crazy mixed with dead......no big deal on the build table...but it would've crashed my 104 for sure had those wires gotten together in the air since when the signal wire gets grounded the Hitec servo's go to "sleep" and when it touches the positive, they jerk around wildly.....
The bottom line...check to see if you have a similar problem on existing planes....and on a new build, protect those wires better where they enter the fuse-tube and where they exit.
Lesson learned.
Old Sep 09, 2012, 02:08 PM
Elec 1800 is offline
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Thank you guys for the info for my dle 30 flooding problems. I ended up taking the carb apart and cleaning, it was slightly dirty on metering side. Put it back together and the flooding stop but still wont start. It pumps fuel while priming but wont start, wants to start while i flip it but thats it. Checke d the spark and it is giving a nice blue spark
Elec 1800 is offline Find More Posts by Elec 1800
Old Sep 09, 2012, 02:10 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Agree....110%
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 09, 2012, 02:41 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
If leaning both neddles doesn't help I would get a carb kit and rebuild the diaphrams and needle valve
nebwake is offline Find More Posts by nebwake
Old Sep 09, 2012, 02:56 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
We have always wrapped. The servo wires entering the fiberglass tube in foam. Cuts right thru them if you dont
jsmith285 is offline Find More Posts by jsmith285
Old Sep 09, 2012, 02:59 PM
SteveT.'s Avatar
San Jose, CA
Well....I only have one plane with the tube in it....but it will most definitely get the foam treatment!!
Thanks guys for this info!! I have even worried about using Ty-raps to fasten servo leads to former, so I use pieces of fuel line that I split down one side to go over the edges......better safe than sorry.....
SteveT
Old Sep 09, 2012, 03:04 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Had a close call just now. Had to land without rudder. She wanted to go left so I circled around twice and plopped her down. No damage.
48 Edge 540 - CLOSE CALL (0 min 53 sec)
tominator06 is offline Find More Posts by tominator06
Old Sep 09, 2012, 03:22 PM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Ok cool thanks. Yeah i had both needles at 1.5 turns and leaned out the low end about 1/8 turn but just didnt fire. The carb was recently.rebuilt about 3 weeks ago. I replaced the gaskets and diaphram. One question though, on the metering
Side of the carb. The tab that opens the needle when the diaphragm pushes down, how high up should that be or does it need to flush with the carb body
Old Sep 09, 2012, 04:23 PM
skippy78 is online now
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
I got to go to my first real airshow today and it was alot of fun. Kevin Coleman in the extra and Super Dave flew the mx2 they both put on a great show.
skippy78 is online now Find More Posts by skippy78
Old Sep 09, 2012, 04:46 PM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
I'm pretty sure it's flush or slightly below, a friend of mine has a walbro tool that sets the height, each carb is different but I'm sure the dle is just below, look up the carb # and google should have the answer. If not a small engine repair shop should be able to set the height with their little tool
Old Sep 09, 2012, 05:23 PM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Awesome thanks bud. Yeah cause currently its above the carb body where it sits. I will google
Old Sep 09, 2012, 06:32 PM
BOSSIER_ROB is offline
Find More Posts by BOSSIER_ROB
BOSSIER_ROB's Avatar
United States, LA, Bossier City
Joined May 2011
Kevin's a local. We fly at the same airport which happens to be right down the street from where I work so I get to see him fly all the time. He's a pretty good stick and only getting better. I love hanging out at their hangar. Other airshow pilots are always dropping by with some nice toys.
BOSSIER_ROB is offline Find More Posts by BOSSIER_ROB
Old Sep 09, 2012, 06:44 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Great lookin' bird!
http://www.superdaveairshows.com/aircraft.html
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
