Old Jul 23, 2012, 12:55 AM
SportFlyer2 is offline
Find More Posts by SportFlyer2
United States, TX, Palacios
Joined Feb 2009
Originally Posted by Park_aviator View Post
Cheap and easy night flying = Success!
Put a head lamp (Idk what it's called) on and you can fly The flash from the camera lit up a lot too!
Now why didn't I think of that !!!
SportFlyer2 is offline Find More Posts by SportFlyer2
Old Jul 23, 2012, 01:23 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by skarface View Post
order a gas one all you would need is exstesions for the motor.
It's not really the same, as the cowling is different, and the canopy/hatch does not go as far forward, so therefore, it is more difficult to strap the batteries down. It's not impossible, just harder...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 23, 2012, 02:34 AM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
SteveT
I know just talking and throwing out an idea that I am sure he already knew.
skarface is offline Find More Posts by skarface
Old Jul 23, 2012, 06:27 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by jcfab View Post
The other old saying goes, "Ya gotta be smarter than the tool you're working with"
Jeff
LOL I say that all the time. I just wonder if it still applies if you are the only tool (ie buffoon, numbskull, nimwit, ect., ect.) doing the work?
Another I use quite often "You only have to be 10% smarter than what ever it is you are working on."
Eagle34 is offline Find More Posts by Eagle34
Old Jul 23, 2012, 09:23 AM
cale10 is offline
Find More Posts by cale10
AMA Another Mans Airplane
cale10's Avatar
United States, OH
Joined Jul 2011
ok my epp extra just isnt doing the job of "3d flying" so i need a 3dhs balsa airframe. wich 3D's best? the 41 edge, 42 slick, 46 yak, 47 extra or the 48 edge? i really want a hardcore 3d plane to huck around so wich is best?
cale10 is offline Find More Posts by cale10
Old Jul 23, 2012, 09:40 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
What is the EPP extra lacking in 3d flying?
I've only had the 41'' and 47'' of the ones listed and i have to recommend the 47''. It feels like a very well rounded airframe. Just make sure to get the 130 omega not the 103
hone1er is offline Find More Posts by hone1er
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
I've heard the 47 shp is really good.
zmonster97 is offline Find More Posts by zmonster97
Old Jul 23, 2012, 09:47 AM
cale10 is offline
cale10's Avatar
United States, OH
Joined Jul 2011
it doesnt fly at full speed. the airframe flexes.
Old Jul 23, 2012, 09:49 AM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Full speed 3D ey? Interesting...
The only thing I found I can't get my 48 Extra to do is pop tops. I'm thinking the large flat sides just kill that.
FireyFate is offline Find More Posts by FireyFate
Old Jul 23, 2012, 10:56 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
48 Edge is hands down the best 3D ship you listed, followed closely by the SHP. If you are learning, i would go with the Edge since it has wire LG and will not break where as the Extra has carbon gear and is also a bit more expensive.
nebwake is offline Find More Posts by nebwake
Old Jul 23, 2012, 11:56 AM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Indeed. Here I was, thinking that 3D flight was post-stall, slow and low, hanging on the prop kind of stuff. I never knew it involved high speed maneuvers with the wings generating lift. This must be that newfangled 3D that all the kids are doing these days.
Seriously though... high speed aerobatics and 3D flight are not the same. The EPP Extra is a fine 3D aircraft and loves to be flown in such a fashion. It is not a high speed aerobat capable of handling crankshafts, pop-tops and other violent maneuvers over and over again. It's still a foam plane for Pete's sake!
SD One. is offline Find More Posts by SD One.
Old Jul 23, 2012, 12:06 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Huh?
I fly WOT all the time with mine. I will say it doesn't tumble like a balsa plane with all that surface area, but full speed is not a problem. That flexing you see may be flexing of the rubber bands holding the wings together. I use thin zip ties on my wings - no flexing and will probably break in a hard enough crash (haven't tested this yet, though).
Jboy90277 is offline Find More Posts by Jboy90277
Old Jul 23, 2012, 12:23 PM
cale10 is offline
cale10's Avatar
United States, OH
Joined Jul 2011
Originally Posted by Jboy90277 View Post
Huh?
when I fly WOT i roll with the alirons and it just doesnt seem to roll as much. i use zip ties too. but i still love the plane and it flys great with low speed 3d.
Old Jul 23, 2012, 12:37 PM
Joined Dec 2011
There are a lot of flat surfaces that want to keep the plane from rolling (tail, fuse, wing). At WOT, their combined effect is probably more difficult to overcome with the ailerons. I find with my not so great flying that my plane rolls faster when I'm trying to do rollers at a moderate speed (to keep my stick movements in sync with the roll rate) - eventually it starts rolling too fast and I fall behind and have to bail.
Probably easier to show you what I mean:
3DHS 48" EPP Extra 330SC - Windy Day (5 min 38 sec)
Old Jul 23, 2012, 03:00 PM
3Dplank is offline
Find More Posts by 3Dplank
TEAM HILLBILLY
3Dplank's Avatar
Joined Mar 2010
+1 I agree 100% I guess 3d turned into wot for the whole flight
3Dplank is offline Find More Posts by 3Dplank
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
