Old Jul 13, 2012, 11:42 AM
The_MonsterMash is offline
Find More Posts by The_MonsterMash
3d flippin
The_MonsterMash's Avatar
United States, CA, Ontario
Joined Jan 2012
thanks for all the great input guys i want to run life unregulated but i am going to run a wike ibef from TBM with my dle30 and i am using 4 hs 5945mg and a high speed throttle servo....just want to make it as light as possible without using regulators
The_MonsterMash is offline Find More Posts by The_MonsterMash
Old Jul 13, 2012, 11:52 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
that regulator is not going to add any appreciable amount of weight...I don't think your plane will notice it at all.
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 13, 2012, 12:05 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I've quit using foam under everything since I switched to 2.4 about 5 years ago
cmala is offline Find More Posts by cmala
Old Jul 13, 2012, 12:21 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Shoutout to davebloomer:
Thank you so much for going out of your way to send me a battery for free. That was realy awesome of you!! Thank you so much!!!!
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jul 13, 2012, 12:56 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
I only put foam under fuel tanks and ignition boxes.
Ace4 is offline Find More Posts by Ace4
Old Jul 13, 2012, 01:05 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
I am not sure I get your logic there. If 2.4 in your reply is a 2.4 gHz radio, how does that help a solder joint on your battery, switch and internal receiver when a connection is shaken down and becomes intermittent or broken? That is the advantage of isolating your electronics from frame vibration.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Jul 13, 2012, 01:19 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I still foam everything....receiver is velco only though
going4speed is offline Find More Posts by going4speed
Old Jul 13, 2012, 01:49 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I'm not claiming any logic. Back in the glow, 72 mhz days I wrapped the receiver and battery in a nice foam bundle. With electrics and 2.4 ghz radios I have not used foam.
Even on my 100cc plane, I just use velcro for the batteries and receiver. I have some foam under the fuel tank and ignition module.
I haven't had any issues yet.
Old Jul 13, 2012, 02:52 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
On the gas planes I have foam under the RX and fuel tank then velcroed straped down to the frame. The ignition is wrapped in foam then zip tied to the motor box. But the batteries are velcroed down just like an electric plane. Really never thought of having foam under them.
But anyways here is a video of the 51" a couple nights ago. Nothing new, its just the same stuff I always do. But something with the overcast stormy clouds, sun hitting my back at sunset, and the bright colors of the slick make this video look really cool to me
3d'ing the 51" AJ Slick from 3dhs Again! (4 min 38 sec)
HugoCraft is offline Find More Posts by HugoCraft
Old Jul 13, 2012, 03:20 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
So I'm getting ready to finally mount my motrofly motor on my new 57" Extra and I noticed that Ken put the motor wires THROUGH the fiberglass mount. So I can't mount the motor directly to the firewall but it didn't come with any standoffs.
I called my LHS and asked if they had any standoffs and they acted like I was crazy.
What the heck do I use for this?
turnerm is offline Find More Posts by turnerm
Old Jul 13, 2012, 03:22 PM
Joined Jan 2009
go to your local Hardware store and get some plastic ones
something like these:
http://www.homedepot.com/buy/buildin...lon-84961.html
Old Jul 13, 2012, 03:28 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Take that you mangy cat!!!
Not really a mangy cat....but it's funny... Cat VS. Heli....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 13, 2012, 03:37 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
SteveT
Can't wait to watch this when I get home. Neighbors have two new kittens and they now think they belong in our fenced in yard to play and poo. So the water hose is now set on Stun! (since Jet didn't work)....
heritageflyer is offline Find More Posts by heritageflyer
Old Jul 13, 2012, 04:21 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Www.customstandoffs.com
I just need to know the length you need and I can make you some
Old Jul 13, 2012, 06:18 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
yep, you NEED standoffs, i screwed this up also and cut a bigger hole in the firewall of my 59. Once I got the standoffs set I felt a little D.U.M. dumb...
nebwake is offline Find More Posts by nebwake
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
