Old Jul 01, 2012, 10:17 AM
RotorJockey is offline
Find More Posts by RotorJockey
Fly Low-Crash-Rebuild-Repeat !
RotorJockey's Avatar
Jackson, MO
Joined May 2009
Is there a thread for the 126" Slick either here or on FG?
I haven't had any luck with the search tool...
Fred
RotorJockey is offline Find More Posts by RotorJockey
Old Jul 01, 2012, 10:46 AM
Trixie3D is offline
Find More Posts by Trixie3D
Joined May 2012
http://www.rcgroups.com/forums/showt...7#post22045550
Now there is. Have at it.
Trixie3D is offline Find More Posts by Trixie3D
Old Jul 01, 2012, 01:27 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by DeadStick Dave View Post
Attention Austin and San Antonio guys, I'm cutting down - for local pickup only - Kerrville TX. My Flight simulator: 21" monitor, Compac Computer, Falcon 4 sim, 747 Sim. Saitec controls and stand set-up. PM me if interested.
What?? No rudder pedals??? Looks nice a nice set-up!!
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 01, 2012, 02:28 PM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Originally Posted by hugocraft View Post
Does a video make it happen?!?!?!?
http://www.youtube.com/watch?v=i4pP6-g2GWI
Nice John!!!
Thing is fast and sounds like a Wood Router!
Here's my Day 3 Power Outage vid from this AM. First inside hovering on new Solid CF Boom, but the Quick Grip didn't hold, so just CA'd. The frame hole is a little fragile and off. Seems solid now. Went out into garage for more room and cooler temps. 90 in the house right now with all windows open.
Generator on, no water, just keeping Fridge cool since Friday 7pm. Gassing Generator every 3 hrs. Still 69% out in our County. Saying 90% back on by Thurs Midnight this week.... Worst ever around here!
I need a 240v Generator to run the well pump. It's Going to Happen!
My plug went last night and this AM the Recoil Starter broke. Had to remove it, so improvised. Flip starting it like a GS Engine.....
heritageflyer is offline Find More Posts by heritageflyer
Old Jul 01, 2012, 06:56 PM
aronph is online now
Find More Posts by aronph
TEAM HILLBILLY
aronph's Avatar
Groveport, OH...USA
Joined Nov 2010
without internet i cant keep up with this thread and it doesnt even move as fast as part IV...
aronph is online now Find More Posts by aronph
Old Jul 01, 2012, 07:47 PM
SteveT.'s Avatar
San Jose, CA
Bullet connector safety covers.....
Check these nifty covers I found that fit Castle 6.5mm bullet connectors perfectly....
I do business with a machine shop supply that has little plastic tubes that they put drill bits etc. in. I happen to notice that the two sizes that they normally use had some ends on them that when pulled off fit the bullet connectors. So...on Friday I went to the supply house and asked if I could buy some of the tubes or ends, and they end up giving me about fifty of each size....and even better, the smaller size which is black, fits the male plug which is what I use on the negative side, and the larger size which is red fits over the heat shrink tubing tubing on the female connector on the positive side!!
While I have not tried to find them anyplace other than where I got them, you might be able to get them at Tap plastics or other places..
SteveT
Old Jul 01, 2012, 07:59 PM
davebloomer is offline
Find More Posts by davebloomer
Fly Low, Fly 3d, Repair Often
davebloomer's Avatar
United States, OK, Weatherford
Joined Jun 2011
Fool me once shame on you fool me 11 times shame on me. My relationship with hitec hs65mg servos is over.
davebloomer is offline Find More Posts by davebloomer
Old Jul 01, 2012, 08:07 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
dude...check and re check your linkages for any kind of binding. believe me, I've been through just about every 65mg alternative and for the moment they are the best.
I feel your pain though I really do.
Irg is offline Find More Posts by Irg
Old Jul 01, 2012, 08:11 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I'm tempted to pull these off my 450 heli and put them in a 48" plane
3drcparts is offline Find More Posts by 3drcparts
Old Jul 01, 2012, 08:22 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
I am jealous I can't seem to kill them anymore.
I recently fell in love with the 47" shp and I have never been so hard on servos. The hs65mgs in it have over a hundred extremely hard flights and they are still going strong.
I had quite a bit of trouble with them for awhile. It is extremely important to make sure there is zero binding. It is sooo easy to get binding in E/Z connectors and ball links. Also when you are hinging the plane, make sure you leave a nice little gap. The servos should make ZERO noise when the surface is fully deflected. If they are making any noise, then they will probably fail in the air. Noise means the servo is struggling just to move the surface. Then you go and add the pressure of the air on the surface, and it kills the servo.
I also run mine at 6.5 volts and haven't killed one since I started doing that.
All I can say is that the HS65MG doesn't have an issue and I know this because with a proper setup, they will last a really long time even being pushed really hard.
I thought I was really good at setting up planes but was killing servos. Ended up finding out that I was really bad at setting up linkages.
joesmith285 is offline Find More Posts by joesmith285
Old Jul 01, 2012, 08:26 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
I fricken HATE LOCKOUTS!!
I was maidening my cub and was too lazy to put te reciever wires in a 90* anlge. I kinda thought that was all hoo hah.
Appearently not.
Sh*t.
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jul 01, 2012, 08:46 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Appearently not.
Sh*t.
Man, I'm sorry to hear 'bout that.... Repairable? I just threw one Rx wire through the fuselage and 1 outside...
Park_aviator is offline Find More Posts by Park_aviator
Old Jul 01, 2012, 08:47 PM
SteveT.'s Avatar
San Jose, CA
Appearently not.
Sh*t.
This is Futaba....right???
SteveT
Old Jul 01, 2012, 08:49 PM
Joined Feb 2011
SteveT
Yeah.
The airframe is repairable, but not the looks.
Its only a $53 plane....I might just get a new one.
Old Jul 01, 2012, 08:50 PM
3D, 1D at a time!
Joined Aug 2010
SteveT
Yep!
Discussion You are addicted to flying when.... postalflyer72 Electric Plane Talk 34 Jul 16, 2011 11:12 PM
Video Angelo Lomelí flying 3D antics Jorge Fernandez Electric Plane Talk 0 Sep 30, 2006 02:22 PM
Tiger Moth antics - flying inverted w/video SnoJetter Parkflyers 49 Sep 16, 2003 07:25 PM
Help! Getting addicted to Park Flying fly4fun Parkflyers 11 Feb 16, 2002 10:58 AM
You know when your addicted to Slow Flying when..... Gman Parkflyers 51 Aug 05, 2001 03:19 AM
