Old Oct 11, 2003, 03:34 PM
ICRSHLTS is offline
Find More Posts by ICRSHLTS
Two Rivers, WI
Joined Mar 2003
If 3s voltage is too high?
This may sound stupid- Most people are having trouble finding a spot between 8-9 cell NMH and lithiums. If 12 volts is too much and Lipo don't have a memory couldn't I just watch my charger and quit at say 11 volts? don't let it peak to full charge. Is this a problem or a downfall I'm missing? Of course they would not be full capacity- but most have too much anyway-8000 MAH's
ICRSHLTS is offline Find More Posts by ICRSHLTS
Old Oct 11, 2003, 05:44 PM
gtstubbs is offline
Find More Posts by gtstubbs
gtstubbs's Avatar
Perth Westen Australia
Joined Jun 2003
This is my guess as to some of the implications of your proposition.
Capacity
See attached graph
Source http://www.buchmann.ca/Chap4-page8.asp
The charged capacity of a cell (ignoring losses etc) if the charge terminates at 3% of rated current is a function of amps into the battery over time.
The green area (assuming the curve is correct) represents the capacity of the battery at 100% of charge based on termination at 3% of rated current
If you terminate the charge at about 3.7 volts / cell then you get about 11 volts for a 3s pack.
The charged capacity of the cells (and hence the pack) is represented by the red area.
If the curve function was known then you could by calculating the red and green areas under the curve arrive at the % capacity for an 11-volt pack charge.
My eyeball calculation method suggests at 11 volts you would have 50% or less capacity in your pack.
Amp Draw and ESC cut-off.
If you only charge to a pack voltage of 11 volts and then hit the pack with WOT runs you will drag the battery terminal voltage down and depending on your ESC setting may cause a cut-off.
“Digital devices are especially demanding on a battery. Momentary pulsed loads cause a brief voltage drop, which may push the voltage into the cut-off region.”
Source http://www.buchmann.ca/Chap5-page3.asp
If you charge to 4.2 volts the terminal voltage is less likely to drop at WOT to a level that may trigger the ESC.
Discharge Depth
“Most rechargeable batteries prefer a partial rather than a full discharge. Repeated full discharge robs the battery of its capacity. The battery chemistry which is most affected by repeat deep discharge is lead acid. Additives to the deep-cycle version of the lead acid battery compensate for some of the cycling strain.
Similar to the lead acid battery, the Li-ion battery prefers shallow over repetitive deep discharge cycles. Up to 1000 cycles can be achieved if the battery is only partially discharged. Besides cycling, the performance of the Li-ion is also affected by aging. Capacity loss through aging is independent of use. However, in daily use, there is a combination of both.”
On balance for capacity, cutoff and life span reasons managing the throttle may be the way to go.
gtstubbs is offline Find More Posts by gtstubbs
Old Oct 11, 2003, 06:06 PM
ICRSHLTS is offline
Two Rivers, WI
Joined Mar 2003
wow!
Now that's an answer! Thank you
Old Oct 11, 2003, 06:46 PM
JTinCT is online now
Find More Posts by JTinCT
JTinCT's Avatar
New Milford CT 06776
Joined Sep 2000
gtstubbs, I'm having trouble with a solution to world peace issue I've been working on
JT
JTinCT is online now Find More Posts by JTinCT
Old Oct 11, 2003, 07:13 PM
gtstubbs is offline
gtstubbs's Avatar
Joined Jun 2003
JTinCT
The solution is the Gubenator of California.
Old Oct 11, 2003, 07:17 PM
mbcone is offline
Find More Posts by mbcone
Albuquerque Intl, New Mexico, United States
Joined Jun 2003
A 3s pack charges to about 12.6v, but delivers more like 11.1v. Still a little high, but the inexpensive GWS-ICS 100 ESC doesn't seem to mind - Brian
mbcone is offline Find More Posts by mbcone
Old Oct 17, 2003, 04:52 PM
gtstubbs is offline
gtstubbs's Avatar
Joined Jun 2003
I found another graph in the The Kokam USA
Lithium Polymer Battery System manual that seems to show that my estimate of less than 50% capacity was far to optimistic, see attached modified graph. (red line)
Source
https://www.fmadirect.com/support_docs/item_1115.pdf
The graph suggests that charging to 3.7v would only put in 5%-10% of the capacity of the pack.
One of the interesting things about this graph is that it demonstrates fairly clearly the futility of charging LiPo’s over 1C.
This can be seen from the coincidence of the capacity curves for 1,2,3C charge rates at 1 hour and the fact that each curve at that point is within 2-3% of all others.
The manual also says in respect of this graph.
“The above chart is very important, so study it carefully. The following charging guidelines emanate from the chart:
1 Never exceed a 2C charge rate and accept that cycle life will be maximized by charging at 1C.
2 never exceed a maximum charge voltage of 4.235 VDC.”
This is a good manual in relation to the use of LiPo's, pack construction, wiring and support materials etc and should be read by all LiPo users.
There is another manual that contains further info, the Kokam/FMA Lithium Polymer Cell application manual. Also worth a read.
Old Oct 17, 2003, 05:49 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
the solution most used is to change the prop load and/or gearing to adjust the total power to what you want using either 2s or 3s
dave morris is offline Find More Posts by dave morris
Discussion Output voltage too high (hyperion 1210i)? expertzx Batteries and Chargers 0 May 14, 2007 08:40 PM
Discussion If HS too high can run at lower throttle? rmasu Electric Heli Talk 2 Aug 25, 2006 05:38 PM
Too high of voltage? ElvisLivesOn77 Radios 2 Jul 06, 2004 01:53 PM
Help! I think I ran the voltage onmy 3s 1200 too low j_z_123 Batteries and Chargers 19 Jan 15, 2004 08:56 PM
Endo current draw seems too high? Herky-Bird Sport Planes 8 Sep 08, 2001 09:47 PM
