This thread is privately moderated by Martintin, who may elect to delete unwanted replies.
Old Feb 03, 2012, 02:38 PM
Martintin is offline
Find More Posts by Martintin
1 more flight!
Martintin's Avatar
Denmark, Central Denmark Region, Aarhus
Joined Oct 2011
Build Log
My TRIcopter v.2.5
Here is the finished project of the RC Exploere TRI copter v.2.5. David has done an exelent job, especialy on the build description. I have had no problems in the building process. Thanks a lot David.
The worst thing, is the waiting on all the parts from HK. They are always sold out (Thanks to David?) It took me at least tree month to get the all the parts, but it is worth the wait. Props came from a friend in Denmark (Thanks Peder) and I already crashed one prop ;-)
I think there must be a lot of Davids TRI copters out in the world!!!
  • The board is a KK Plus 5.5e with the LCD Display
  • Tx Rx is a Turingy 9X, firmware upgraded to ER9X
  • Camera is a HobbyKing Wingcam. Be sure to set the focus right and it a okay fycam!
  • And battery: HK 3S 2200 Nanotec LiPo, with a LiPo alarm installed on every flight!
I'm going to expand the KK borad with a MEMS module, witch is a extreme stabiliser. Coming in march.
/martin
Martintin is offline Find More Posts by Martintin
Old Feb 09, 2012, 11:46 AM
1 more flight!
Martintin's Avatar
Joined Oct 2011
Status feb. 4. 2012
Crash and this is what you get
Strips are good. A lot of them broke in the "landing" witch is good. The frame survived.
Soldered new servo, flash and motor pins on the
Soldered new 3-legged Vref thingy
Can't do anything about the yaw gyro (yet).
Right now I'm trying to get the board up and running without the yaw gyro.
<edit> The yaw gyro can not be repared so i'll use this board with the new MEMS gyro add on.
I'll be back
/martin
Old Feb 16, 2012, 08:06 AM
1 more flight!
Martintin's Avatar
Joined Oct 2011
I'm back in the air, witch is great! But two of my motors suffers, so I have balanced them with one and two strips and new barrings.
I also installed LED underneeth the frame. They flashes at low voltage.
Also a protecting box for my precious KK board
Old Mar 17, 2012, 11:56 AM
1 more flight!
Martintin's Avatar
Joined Oct 2011
Free FPV rides!
So I go my FatShark goggels and made a temporary setup, giving free rides to friends and neighbors. I'ts very fun to see and hear their reactions. Haven't yet tried the goggles myself when flying. Gotta have a friend near by to step in
OSD is under way and soon I'll be flying FPV. I will fit the camera on my fixed wing glider and try it that way first. I can't wait
I also fitted the Tricopter with a landing gear undercarriage. I looks okay, but I think i will put little wooden ball on as fixed wheels, as it tends to "dig in" when landing in soft ground.
Old Mar 17, 2012, 12:23 PM
1 more flight!
Martintin's Avatar
Joined Oct 2011
Starting on my MEMS board today. I will attach it to my crached KK board.
Old Mar 17, 2012, 01:26 PM
igoralekseevcom is offline
Find More Posts by igoralekseevcom
Joined Nov 2011
I'm sure many have read of how to create trikopter from the Swedish guy http://rcexplorer.se/projects/tricop...copterv25.html
trikopter made ​​to this instruction and there are several questions to the esteemed public
1. It is rather strange behavior on the tail servo
if move Rudder stick - servo moves but:
movement to the right - well
Move left - almost servo does not move
Trimming with subtrimers achieved approximately the right-left, a little bit
even with an increase in the gas servo begins to deviate
2, we can not put CCW (reverse rotation) prop? are there any pitfalls?
igoralekseevcom is offline Find More Posts by igoralekseevcom
Old Mar 24, 2012, 05:58 AM
1 more flight!
Martintin's Avatar
Joined Oct 2011
Crached KK seems not to respond correctly, so I will modify my good KK.
Later....
Hmmmm I need the PPM decoder Shuld have read the READ ME file
PPM decoder is ordered now. Just have to wait another week to get airborne
Old Apr 11, 2012, 08:49 AM
1 more flight!
Martintin's Avatar
Joined Oct 2011
Flyes like a dream
http://youtu.be/TH1eN0K-WCU
Discussion Pulsar 2.5 poly res v tail set up... NickBee Electric Sailplanes 20 Jan 08, 2012 06:26 PM
Discussion Alternative props for Rcexplorers Tricopter 2.5 xardinen Multirotor Talk 0 Dec 18, 2011 11:25 AM
Found Found for a mikado v-bar 5.1 or 5.2 blue version. trexstuntin3d Aircraft - Electric - Power Systems (FS/W) 0 Oct 25, 2011 05:17 AM
Help! How to link my new Aurora 9 2.4 to real flt 5.5 flying_rhyno Simulators 2 Apr 01, 2011 06:44 PM
Question Cell 1=2v Cell 2=5.4 V...Is my 2c Lipo Toast? Dr.Oates Batteries and Chargers 5 Jul 22, 2008 10:37 AM
