This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Jun 27, 2012, 11:13 PM
Gordosoar is offline
Find More Posts by Gordosoar
Sabre holic
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
Originally Posted by TimJC View Post
Did you cut the lower wing to fit the fuse, or cut the fuse to fit the wing? What's the AUW?
You should make a cowl for the motor with a tube big enough to slip over the front of the fuselage. Use a constrasting color and cut the end that slips over the fuse into an ornate shape.
A setup like this is just begging for LEDs.
I cut the lower wing to fit the fuse, i think it was the easier way to go.
here is what I came up with for the cowling.
as you can see i cut the end off a $ tree bat and had to add some foam around the fuse and cut to shape.Name: IMG_1570.jpg
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Description:
Gordosoar is offline Find More Posts by Gordosoar
Old Jun 27, 2012, 11:57 PM
templton89 is offline
Find More Posts by templton89
templton89's Avatar
United States, NY, Kings County
Joined Nov 2011
as you can see i cut the end off a $ tree bat and had to add some foam around the fuse and cut to shape.Attachment 4970891
Attachment 4970889
Attachment 4970883
Attachment 4970887
Attachment 4970894
Attachment 4970890
Attachment 4970886
Attachment 4970892
Attachment 4970893
Attachment 4970885
Attachment 4970888
Attachment 4970896
Attachment 4970884
Attachment 4970895
You guys are out of control with your awesome builds!
That cowl idea is brilliant, I'll have to check if my $tree carries those plastic bats
templton89 is offline Find More Posts by templton89
Old Jun 28, 2012, 12:41 AM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Originally Posted by antennahead View Post
I have recently built an axon to Ed's specs and it flew great right from the very first flight. a few tips that I can pass along to others that have not yet tried to build using Ed's procedures, do not use quality 3M packing tape, it's too thick and not very flexible. use the cheap stuff,it's thinner and more flexible. Also, When I went to the hardware store to get some aluminium flat stock for the motor mount, I felt that they wanted too much money, so instead I bought an aluminium yardstick that was $4.99. I can make a ton of motor mounts and If you want to remove the markings on the yard stick, just wipe it down with laquer thinner!!
Now I am on to my next built that will be a modified axon and I'm thinking of building a wing with a 10 inch cord because the 5 inch one seems a little thin and I want a real floater for my dragon link fpv system. What do you guys think?
Try this for motor mounts...
http://www.rcgroups.com/forums/showp...&postcount=116
Mykro is offline Find More Posts by Mykro
Old Jun 28, 2012, 01:50 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Another thing you can do to seal the edges of foamboard is use a heat sealing iron that is made for iron-on coverings. I cut my tape as close to flush with the edges as I can then use the iron to seal any excess to the edges. This also slightly melts and hardens the foam.
chris1379 is offline Find More Posts by chris1379
Old Jun 28, 2012, 01:52 AM
Wabball is offline
Find More Posts by Wabball
Wabball's Avatar
United States, WA, Pullman
Joined Aug 2011
Looks awesome Gordosoar, can't wait to see how it flies! I was thinking of doing something like this to use as a motor mount, something like a pickle jar lid that could fit over the fuselage tube. This looks really good and is lightweight! I'll have to see if my $tree carries these bats as well...
Wabball is offline Find More Posts by Wabball
Old Jun 28, 2012, 06:15 AM
tonystro is online now
Find More Posts by tonystro
TonyS
United States, AR
Joined May 2010
Didn't know about all that incidence stuff when I put it togather, so I tried to get them the same. What should I have done?
Update... Just checked it, and found the upper wing has a few degrees of positive incidence. What does that mean?
My typing is atrocious this morning So, let me offer information links --
Discussion of biplane wing set up -- http://www.hippocketaeronautics.com/...p?topic=2497.0
And wing incidence "How To" -- http://balsabusters.warp0.com/INCIDENCE.html
TonyS
tonystro is online now Find More Posts by tonystro
Old Jun 28, 2012, 09:39 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
If not you can try various size plastic bottles to find one that fits your plane.
They are usually 3-3 1/2 " but come in many other sizes.
Old Jun 28, 2012, 10:00 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Originally Posted by Mykro View Post
Great idea and cheap. I use a piece of light ply and glue it to the front which give the fuse more stability, and then cut holes to let air through to the batt and Esc.
I sometimes put scoops on the side of the fuse to get air in there.
But for a wing or flat fuse your idea can't be beat.
Another great idea. I'm telling you, we have some very inventive people on here.
Still don't have my video camera, but as soon as I do I'll try to post some of it flying. It's a great design borrowed from the contest winer. With all the lift and drag, it really flys slow, and is a piece o cake to land.
TonyS
I'll check it out and thanks for thinking of me. Us old men need all the attention we can get.
I flew the Wing, Tube Addiction, FunBat, and FuglyJet today.
I've been experimenting with the exhaust cone on the FuglyJet trying to get the best proformence out of it and today it flew the best ever. I shortend it up a bit and the plane seemed to have more power. I was able to go vertical for a bit and do loops with ease.
Later gents,
G
Also, also, I was able to fly it around on a lot less than full power. Last week if I backed off on the power, it wanted to fall out of the sky.
Ok.
Old Jun 28, 2012, 10:17 AM
LawnDartMike is offline
Find More Posts by LawnDartMike
LawnDartMike's Avatar
United States, OR, Salem
Joined Jan 2012
The $Tree stores around here don't carry the bigger bats. I bought mine at Walmart but they were more then a dollar. I was also thinking the bottom of a 1 liter Coke bottle would make an interesting cowling.
LawnDartMike is offline Find More Posts by LawnDartMike
Old Jun 28, 2012, 10:38 AM
vrex is online now
Find More Posts by vrex
Denver
Joined Mar 2004
What do you all use on the top of the fuse to keep the wing from sliding around if you want to use rubber bands to hold the wing on?
vrex is online now Find More Posts by vrex
Old Jun 28, 2012, 10:45 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Just put a rubber band on the fues before you put the wing on and it should keep it in place, as Ed shows in one of his many wonderful videos.
Old Jun 28, 2012, 10:52 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
I've seen that bat at wallyworld, it was about $4-5. And felt heavy.
Your plane looks like it will fly very well. I have one of the $ tree bats of that size also, I'm saving it for something with a bigger wing, like maybe 40-50" .
Please let you know how it flies. But if it has Eds wing and you built it straight,
It should fly like a bat out of hell.
Old Jun 28, 2012, 01:35 PM
r0beert0 is offline
Find More Posts by r0beert0
<<x USMC
r0beert0's Avatar
United States, CA, Fontana
Joined Jun 2010
That looks great!!! here is what I did on one of my basla models that had the original cowl broken to pieces.
more here: http://www.rcgroups.com/forums/showp...93&postcount=7
r0beert0 is offline Find More Posts by r0beert0
Old Jun 28, 2012, 02:58 PM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Semper-FI my friend.
Ya know, looking at that bottle I wouldn't think you could use any part if it, but man you nailed it. You found just the right conures and put them in the right places. It really works with that kind of plane.
Congrats.
G
Joined Jan 2012
It has a 40x8" wing of Ed's design and flys very well. It is my go to plane when the wind is up. 26oz RTF. I use a BL2220/10 (Headsuprc) motor with 10x4.7sf prop and it will cruise at below half throttle or go vertical forever if you get carried away. I put the motor inside the bat so unless it goes stright in the motor is safe from damage. You truly never worry about crash damage to the bat. It makes for a good easy flying trainer.
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 73 Mar 27, 2016 02:15 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 03:24 PM
