@nightstone what size esc and prop are you using with that 3000 bl? i used a 3800 edf bl with a 50amp esc and a 4" prop on my dynamic 400 i to am very conservative with the throttle, i know it will cook one day. But that little thing really screams, its scary fast at full throttle. there is very little drag and the motor doesn't get hot. Be sure to test your setups with a wat meter it could save you from a smoking pile of ash.
Joined Oct 2012
I know this is off topic but what is the difference in a pusher motor, than a regular front facing motor new to this and would like to make a pusher plane just confused on this and where would be a good place to find deal's on the complete pusher kit for like a Axon ? Thanks
I've build a noobtube with a single servo for ailerons and the wing was detachable, check out posts 848 and 850 in this thread. |
Funster 40 vintage 1983 |
Nightstone |
I use a Turnigy watt meter and test everything. I am really looking forward to those NTM's. A bit pricy at almost $20 each but the thrust is awesome. I am going to up prop them and keep them on 3s staying within amperage. Ordered some 50-60 amp esc's also. Now if will only get here... been over 2 weeks now. Love and hate hobbyking!!!!! Nightstone |
Thanks for that though I might end up giving that one up to the shelf till i get more servos.....and on to build a tube without the rudder to save those servos on my rc helo.... |
Joined Nov 2012
noob tube gear
I have tried to put landing gear on the noob tube and had a couple of successful flights but the foam bottom of the fuz seems to be a little to soft to support the stress of a landing. There are a couple of posts in the thread of noobs with gear but no real explinations.
Here is a picture of my first attempt I know I made several mistakes. 1. The gear is too long. Gives the skies too much leverage to tear the foam. 2. The gear wire is too strong, doesnt bend at all. I dont know what size it is, I used a very strong coat hanger. 3. The bottom of the fuse was not stong enough for my zip tie attachment technique. I have a picture of my first attempt which was a failure. Since then, I have laminated the bottom of the foam sheets where the gear attaches with gift cards and epoxy. if it comes out now I am losing the whole bottom of the fuz. The whole plane is clear tape. I painted the wing with $2 spray paint for orentation and it seems to work just fine. |
| Thread Tools | |
| Build Log SEW-SLO 30" Foamboard Wing | Atx_Heli | Foamies (Scratchbuilt) | 47 | Sep 18, 2012 10:14 AM |
| Build Log SEW-SLO 30" Foamboard Wing | Atx_Heli | Flying Wings | 0 | May 19, 2011 09:47 PM |
| Question So I have a sheet of $Tree foamboard... what to build? | Bomb Dropper | Foamies (Scratchbuilt) | 15 | Mar 23, 2011 02:49 PM |
| Discussion EDF/Motor for University Design Project | uwpropulsionguy | Electric Ducted Fan Jet Talk | 0 | Mar 06, 2011 03:24 PM |
