This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Apr 09, 2012, 09:12 PM
bhcnomo is offline
Find More Posts by bhcnomo
James Stockton
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
thanks Ed
here some more video of the Fuglyjet
fuglyjet 4-8-12.mp4 (3 min 42 sec)
bhcnomo is offline Find More Posts by bhcnomo
Old Apr 10, 2012, 08:46 PM
Donny Harwood1 is offline
Find More Posts by Donny Harwood1
Fallin with Style (slopeing)
Donny Harwood1's Avatar
United States, CA, Covina
Joined Aug 2011
Do you have any videos on how to make the Delta wings?
Donny Harwood1 is offline Find More Posts by Donny Harwood1
Old Apr 10, 2012, 08:49 PM
Rob Mackenzie is offline
Find More Posts by Rob Mackenzie
Canada, AB, Olds
Joined Apr 2011
Delta Wing
Here's a smoking little Delta wing by Ed at
FAST FOAMBOARD DELTA WING - Details (14 min 42 sec)
Careful though... it'll cost you a whole dollar for enough foamboard!
Rob Mackenzie is offline Find More Posts by Rob Mackenzie
Old Apr 11, 2012, 11:02 AM
Joined Aug 2011
Thanks for the video.
Old Apr 11, 2012, 12:08 PM
bhcnomo is offline
James Stockton
bhcnomo's Avatar
Joined May 2010
second flight from saturday 4/7/12
cracked the wing but did not see until the last crash
fuglyjet crashes (2 min 3 sec)
Old Apr 11, 2012, 03:08 PM
RevJVegas is offline
Find More Posts by RevJVegas
United States, TX, Houston
Joined Dec 2011
@ bhcnomo "...two points..."
LOL, I think you get more than that for at least missing the car :-)
RevJVegas is offline Find More Posts by RevJVegas
Old Apr 12, 2012, 11:05 AM
ducoop is offline
Find More Posts by ducoop
Joined Feb 2012
Where do you put the edf on the jet. I built one nut the cg was way to far back. And by the time I got it right it was to heavy to fly well
ducoop is offline Find More Posts by ducoop
Old Apr 12, 2012, 12:40 PM
ExperimentalAir is offline
Find More Posts by ExperimentalAir
Ed @ Experimental Airlines
ExperimentalAir's Avatar
United States, AZ, Phoenix
Joined Sep 2011
The EDF is just inside the rear of the fuselage, with the intake lip being about 2" aft of dead center of the fuselage. Have a look at the video for a little more detail. A 2200mAh battery mounted in the nose about 2" aft of the very tip should yield a CG 1.5" aft of the leading edge of the wing. AUW should be around 600g as built in the video.
ExperimentalAir is offline Find More Posts by ExperimentalAir
Old Apr 12, 2012, 12:53 PM
rnmosaic is offline
Find More Posts by rnmosaic
Ichy to Build and Fly.
rnmosaic's Avatar
United States, FL, Davie
Joined Feb 2011
Hi Ed,
Here is my Zoom Jet - as my 6 year old named it...
It runs off of 50 mm EDF power house with a 20 A ESC.
I used 1800 mah / 20 C / 3S battery.
It flies good but very sober and slow - not like a jet at all.
I plan to change the wing to reduce the AUW so that power plant can push this easier.
I will post the updated picture with in a week as soon as I make it fly at least a bit fast.
In the mean time - here are some pictures taken during build.
Wing span is 24" and Length is 23" from nose to tail. The Fuse came to 2-1/4" square section with wing chord of 4" and 1" for aileron and elevator width.
rnmosaic is offline Find More Posts by rnmosaic
Old Apr 12, 2012, 01:46 PM
Joined Sep 2011
rnmosaic - Looking good! I could only tell the 2/3 scale from looking at the receiver. So how much thrust do you get out of that 50mm EDF? Are you thinking of a flat wing? Yeah, "ZoomJet" is a better name for around the kids.
Old Apr 12, 2012, 02:43 PM
rnmosaic is offline
rnmosaic's Avatar
Joined Feb 2011
Hi Ed,
As per specs this 50 mm EDF unit gives out 310 grams of thrust - and my AUW is almost 290 grams there. This is one of the reasons why the Zoomjet flies too mellow... very slow.
I am in fact working on a flat plate wing to reduce weight and also trying to make a sleek canopy on the front end to help with reducing drag as well..
Already punched two holes on left and right side of fuse to help EDF to suck in more air if needed... So it is all being tested now...
Hopefully with additional "unwanted" weight removed, I believe it will fly decent enough for a "MINI" edf jet ...
I will post some pictures as soon as it flies well and perhaps a video as well..
Mosaic.
Old Apr 13, 2012, 01:09 AM
DTFB Aerowerks is offline
Find More Posts by DTFB Aerowerks
DTFB Aerowerks's Avatar
United States, CA, Roseville
Joined Nov 2011
Experimental Airline Fuselage Hack
Don't forget that you can customize Ed's basic fuselage tube assembly as the core of your own design...
Experimental Air Fuselage Hack (0 min 8 sec)
DTFB Aerowerks is offline Find More Posts by DTFB Aerowerks
Last edited by DTFB Aerowerks; Apr 13, 2012 at 01:22 AM. Reason: corrected video link
Old Apr 13, 2012, 02:35 AM
Mazzepa1 is offline
Find More Posts by Mazzepa1
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
Grazie
I just want to thank ExAir for taking the time to post this most excellent tutorial.
Mazzepa1 is offline Find More Posts by Mazzepa1
Old Apr 13, 2012, 07:43 AM
Joined Sep 2011
That's what I'm taking about! Hacking is highly encouraged. Do you have some planes built this way?
Old Apr 13, 2012, 07:44 AM
Joined Sep 2011
Very happy to do it. I hope to see some of your designs here soon!
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 73 Mar 27, 2016 02:15 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 03:24 PM
