Espritmodel.com Heli Air
This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Apr 04, 2012, 05:20 PM
United States, TX, Houston
Joined Dec 2011
I did a similar repair to the nose of my Axon cutting off the damage and gluing on the replacement using a coupling. Turned out rock solid; no issues.
RevJVegas is offline Find More Posts by RevJVegas
Old Apr 04, 2012, 05:23 PM
addicted to the sound ehhhhhhh
Joined Dec 2011
Now that i have put it together i am worried that it will be to long and there fore the wing wont be big enough
englanito is offline Find More Posts by englanito
Old Apr 04, 2012, 09:19 PM
Ed @ Experimental Airlines
ExperimentalAir's Avatar
United States, AZ, Phoenix
Joined Sep 2011
Well but how much does it weigh and how big is your wing?
ExperimentalAir is offline Find More Posts by ExperimentalAir
Old Apr 05, 2012, 12:28 AM
Joined Dec 2011
The wing is the one piece 30" foam board and the weight I guess is to be determined
Old Apr 05, 2012, 07:28 AM
Joined Sep 2011
I think I get what you have going on. I think you would want to double up the wingspan if you're going to add any more weight than the original Noob Tube. Way to reuse parts though.
Old Apr 05, 2012, 11:54 PM
Assault the sky
United States, CO, Denver
Joined Aug 2004
Hi Ed, you asked me to bring my cargo plane over to this thread, so here I am :-)
The fuselage was actually based on Mikey's-RC YC-14 design, but only because I hadn't discovered yours yet. Your designs are more elegant
I started with a KFm2 airfoil in a 48" wingspan. It flew well, but in a nose-high attitude. Since it is a cargo plane and will carry potentially heavy objects, I started building a 60" wingspan Armin wing to replace it (with black foamboard!) I gotta say, it flies a LOT better with the Armin wing. The wing has a single aluminum arrow shaft for a spar. They break apart but are always together because of the Y harness for the ESC's. Bomb bay is "french door style" using a servo stretcher to get more throw, so that when closed, the servo arm is straight up, so any weight resting on the doors produces almost zero load on the servo. Carries two 3S 2200's, with BL2212/10 motors (1400kv) turning 8x4 props. I've also FPV-ified it, so it also has 2 cameras (1 for recording), video tx, and an extra 500mAh 3S pack. It has enough room inside to house a 1280MHz cloverleaf antenna. I plan on also adding a GoPro to it soon -- I have no doubts it won't care about the extra weight. The smaller skewplanar antenna on top is connected to the FrSky receiver. It also has an altimeter. So far I've gone up to 1400 feet but I plan to go higher. It's had a couple of rough landings which is why it's dirty... it had wheels at one time but I removed them because it would roll too far on landing. The 2 motors are coupled with the rudder which worked ok for taxiing, but I just like to throw it. Pictures below the movies.
Onboard video with KFm2 airfoil:
http://www.youtube.com/watch?v=A0RLd1wm2y4
Wingboard view with Armin wing:
http://www.youtube.com/watch?v=HzKJX8NPYIY
Bomb bay view with Armin wing, dropping rocks and flying high:
http://www.youtube.com/watch?v=RFYM3gGfe6U
secretspy711 is offline Find More Posts by secretspy711
Old Apr 06, 2012, 09:33 AM
Joined Sep 2011
That is a fully tricked-out foamie, Hollywood style, very versatile, and well-documented. Wingtip shots are so nice. Good ideas in there. Thanks for showing us.
Old Apr 07, 2012, 05:42 PM
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Removing paper from foam fold.
I got some of the fan fold foam from lowes and was wondering how to get the onion skin like paper off. I used a piece od duct tape on some and it helps take it off but that could get expensive. Also I've just sat and picked it off piece by piece. Is there a way to get it off in larger pieces?
Tom
carr52 is offline Find More Posts by carr52
Old Apr 07, 2012, 10:25 PM
Paradise R/C Flyers in NY
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
maiden flight of the cargo dropper
flight time on 2-2200mah lipos
about 17 mins wind was 10-20 mph
thanks Ed
cargo dropper 4-7-12 (1 min 51 sec)
bhcnomo is offline Find More Posts by bhcnomo
Old Apr 07, 2012, 10:32 PM
bhcnomo's Avatar
Joined May 2010
maiden flight of the FUGLYJET
flight time on 2-1300mah lipos
about 10 mins wind was 10-20 mph
thanks Ed
I check the video and flight time is more like 6 mins
fuglyjet 4-7-12 (2 min 20 sec)
Old Apr 07, 2012, 10:50 PM
Canada, AB, Olds
Joined Apr 2011
@bhcnomo: Fabulous "two-fer" today... congratulations!
Rob Mackenzie is offline Find More Posts by Rob Mackenzie
Old Apr 08, 2012, 09:16 PM
Assault the sky
Joined Aug 2004
First flight with a GoPro on the Armin/Mikey's cargo plane:
GoPro Camera on Cargo Plane (4 min 6 sec)
Old Apr 09, 2012, 11:14 AM
bhcnomo's Avatar
Joined May 2010
here some more video of the cargo droper
cargo dropper 4-8-12 (2 min 13 sec)
Old Apr 09, 2012, 11:34 AM
Joined Sep 2011
bhcnomo - Fantastic! Those look like a couple of great models. Parachutes coming soon?
Old Apr 09, 2012, 12:02 PM
Fallin with Style (slopeing)
Donny Harwood1's Avatar
United States, CA, Covina
Joined Aug 2011
Al the videos are really nice i as soon as i get a chance im going to build my first plane. what was the motor you had in the noob tube.
Donny Harwood1 is offline Find More Posts by Donny Harwood1
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 47 Sep 18, 2012 10:14 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 03:24 PM
