This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Nov 03, 2012, 09:46 PM
Jaryd107 is offline
Find More Posts by Jaryd107
Joined Apr 2010
Hey Ed, are you going to do a video of the synapse wing? Im sure i could figure it out but if you were planning on making a video it would definietly make things easier. I loved the design thanks.
Jaryd107 is offline Find More Posts by Jaryd107
Old Nov 04, 2012, 12:00 AM
Gordosoar is offline
Find More Posts by Gordosoar
Sabre holic
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
As promised.
This is the Armin Mig 15 I'm throwing together.
It's not pretty but it's just something I'm messing around with.
The thing that's coming out of this is a new way to do the tail section.
Instead of the single layer of board I've been using for the tail surfaces, I'm now bending a piece over to form a double layer. It is much stronger this way.
And for the swept HS I was able to incorporate a carbon rod to join the two halves. I really should redo the fuse as the 6 sides are not even and it's going to make getting the wings and the tail difficult to get lined up.
After I got the fuse wrapped around the EDF I realized I needed to add a little strip to make it go all the way round. So it's lopsided.
If it flys I will make a new fuse, but as I said, it's just for the fun of it.
Here's some shots of it in no order.
[ATTACH]Name: image.jpg
Description: [/ATTACH]
Well it looks like it will only let me upload one photo at a time.
So I'll have to post them ea one at a time.
Sorry Ed.
Gordosoar is offline Find More Posts by Gordosoar
Old Nov 04, 2012, 12:05 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
That goes for me too.
Another shot of the mig.Name: image.jpg
Description:
Old Nov 04, 2012, 12:08 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
This is how I put the two halves of the HS together.Name: image.jpg
Description:
Old Nov 04, 2012, 02:01 AM
Asymair95 is offline
Find More Posts by Asymair95
MD
Joined Aug 2010
New project
Just wanted to share some pics of my new low wing sport model I'm building. Not quite done yet, but hope to have a maiden next week sometime. I'm going to use a 1450kv Turnigy with 9x6 prop run on two 2200 3s packs in parallel. Should scoot right along nice.
Asymair95 is offline Find More Posts by Asymair95
Old Nov 04, 2012, 03:35 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Looking good!
Guys can someone give me some pointers about building a V-tail, how to make it strong and yet simple?
msev is offline Find More Posts by msev
Old Nov 04, 2012, 07:02 AM
ExperimentalAir is offline
Find More Posts by ExperimentalAir
Ed @ Experimental Airlines
ExperimentalAir's Avatar
United States, AZ, Phoenix
Joined Sep 2011
Originally Posted by Gordosoar View Post
You have done it again Ed. Another great design ...
And fun is the meaning of life.
Thank you once again Ed.
Thanks Gordo, I'm happy to be on the team, so to speak. I appreciate you stoking the thread as you have.
ExperimentalAir is offline Find More Posts by ExperimentalAir
Old Nov 04, 2012, 07:07 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Very nice job. I like the way you did the fuse.
Two 2200s wow, that thing will be flying for a long time.
How are you going to do the cockpit ?
Old Nov 04, 2012, 07:10 AM
Joined Sep 2011
Originally Posted by IAFoamie View Post
Hello
Very nice design Ed. Is it me or is it heavy at 2000 grams? 4 lb 4 ozs. Lots of great stuff and only 3 sheets of DT foam.
IAFoamie
2000g would be my estimated maximum, never exceed weight. I'm deriving that from AUW and wattage of several planes I've made with the same wing area but deducting a bit for the swept wings.
So far I'm going to say 1600g is probably about as heavy I would want to hand-launch this plane, but that's just ball-parking it.
1300g with FPV gear and 14 minute flight on 4000mAh seems to fit my niche for medium-range FPV looking around type flights.
Old Nov 04, 2012, 07:17 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
It's my pleasure Mr. Team leader.
I'm 71 and retired, what else do I have to do.
Can't wait for the build video on the wind thing.
Old Nov 04, 2012, 07:34 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Originally Posted by msev View Post
Looking good!
I did a V tail that had a triangle fuse which made it easy to attach the V tail.
If you're making a square fuse, I would make a slit in the upper corners and slip the V tails into the slit all the way down to the bottom of the fuse.
You can put a piece of foam on the bottom of the fuse to adjust the angle of the tails. You have to make the tails longer to make up for the parts that go inside the fuse. If you still need help, I'll take a photo of mine and post it for you.
Good luck.
Old Nov 04, 2012, 07:39 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
For a good V-tail, the angle should be 110-120 degree, so the triangle fuselage is a perfect idea. Thanks, I will have to remember this.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 04, 2012, 07:59 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Here ya go.
Description:
Maybe not the best angle on the tails, but it flew great.
And the triangle fuse is incredibly strong.
If I did another one I would make it 2" on the sides.
Enjoy.
Old Nov 04, 2012, 08:00 AM
Sabre holic
Gordosoar's Avatar
Joined Nov 2006
Another shot.Name: image.jpg
Description:
Old Nov 04, 2012, 08:08 AM
Joined Aug 2009
That is awesome Gordosoar, Love the servos placement.
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 73 Mar 27, 2016 02:15 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 03:24 PM
