http://www.rcgroups.com/forums/showthread.php?t=1683638 http://www.rcgroups.com/forums/showthread.php?t=1730451 |
i got some video of a short flight of the skinyboom glider i will try to get a better video tomorrow
56" Foam Board FPV airplane
Here's a look at my new 56" Foam Board FPV airplane. I have not flown it yet but I will tomorrow if the weather permits flying.
Blog link: http://www.rcgroups.com/forums/showt...3#post22929233
Just curious if you are aware that stabilizer airfoils are normally upside down? The wing generates lift, while the stab is inverted to counter that lift to stabilize the airplane.
"An upside down wing surface with a down lift vector, the horizontal stab counteracts the normal pitch down usually found when the Lift vector is aft of the CG." http://rbogash.com/Safety/stabilizers.html |
You can have a look at ExperimentalAirlines channel for some of the earlier videos: http://www.youtube.com/user/Experime...s?feature=mhee There's also this RCG thread: http://www.rcgroups.com/forums/showthread.php?t=1564769 |
I don't know how this one is going to work. It will probably will want to nose down quite a bit. I guess I should have built it with the horizontal stabilizer on the bottom of the tail tube up side down or just gone with a simple flat tail. I may have to build a normal horizontal stabilizer or fly this one with a lot of up trim on the elevator. Hmmm, what to do. |
Give her a go with the knowledge that it may nose down on launch. I'd put a touch of up elevator in it before you launched it. Once you fly it, if it wants to nose down too much, cut you a thin wedge of foam (or you could even use a piece of balsa aileron stock) and glue to the top of your H stab. Cover over it with your blue tape and no one is the wiser.
That'll save you from having to cut a bunch of stuff apart.....
United States, FL, Palm Beach
Joined Jan 2011
Really enjoyed the DT foam wing building videos. I built my first flying plank wing (25 deg sweep, no taper) but we were unable to get it to fly the first time out. I haven't given up! The fun has been in the building process. I think I enjoy that more than flying anyway.
| Thread Tools | |
| Build Log SEW-SLO 30" Foamboard Wing | Atx_Heli | Foamies (Scratchbuilt) | 47 | Sep 18, 2012 10:14 AM |
| Build Log SEW-SLO 30" Foamboard Wing | Atx_Heli | Flying Wings | 0 | May 19, 2011 09:47 PM |
| Question So I have a sheet of $Tree foamboard... what to build? | Bomb Dropper | Foamies (Scratchbuilt) | 15 | Mar 23, 2011 02:49 PM |
| Discussion EDF/Motor for University Design Project | uwpropulsionguy | Electric Ducted Fan Jet Talk | 0 | Mar 06, 2011 03:24 PM |
