This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Sep 27, 2012, 03:55 PM
Fan of experimetalairlines
Australia, NSW, Sydney
Joined Jan 2012
Originally Posted by syzygyQ View Post
HK showed stock on the motor, ESC, lipos, and props for the FSU Axon today, so I pulled the trigger! Woo Hoo! And my local Dollar Tree has stacks of FSU certified foamboard @ $1.25 a sheet. Nice.
What did you use to cut the foam on your Axon build? Did you use an electric foam cutter? Or did you use a blade? What foam cutter? What blade?
I've got a 306B with a built in foam cutter power mode -- do you use an iCharger to drive your foam cutter? Please tell me about your foam cutter...
Thanks!
I just use a Stanley knife to cut the foam, I think Ed does the same in his videos.
rcnewbieoz is offline Find More Posts by rcnewbieoz
Old Sep 27, 2012, 04:05 PM
UAS Engineer
United States, WA, Battle Ground
Joined May 2012
buy a box of carbon razor blades. Loads cheaper than exacto blades and they cut very,very well.
CarbonFlite is offline Find More Posts by CarbonFlite
Old Sep 27, 2012, 04:59 PM
United States, CA, Torrance
Joined Feb 2012
This may be covered somewhere in the last 107 pages so please forgive me if it has...
What servos is everyone using? I am looking for a cheap HK servo that I can order a bunch of for future projects, but am also looking at a cheap US alternative that I can possibly get by early next week for a few days off I was planning on spending doing some building and flying.
Edit:
While I am at it I am also looking for a good motor/esc/prop combo (HK) to go with some 2200mah 3s lipos for the various planes on here. I will probably start with a Noob Tube. I have 1 set of electronics that should work but want to see what the cheapest set of gear is that will have decent performance that I dont need to worry about destroying being too agressive with...
Thanks again
glazzies is offline Find More Posts by glazzies
Old Sep 27, 2012, 05:20 PM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Everyone has their favorite servos, I use Hitec HS 55's, very common servo, and decent quality for the price.
Here's a great 220 watt motor from Heads Up RC, good people, they ship fast and shipping is CHEAP!
http://www.headsuprc.com/servlet/the...2C-28mm/Detail
Wingman26 is offline Find More Posts by Wingman26
Old Sep 27, 2012, 05:56 PM
Joined Feb 2012
Thanks, but those are a little higher in price than what I was thinking. The HS 55's are what I use for balsa and higher price planes but I am looking for like $2-3 servos and $10-15 motor, etc.
Like this:
http://www.hobbyking.com/hobbyking/s...dProduct=21479
And these:
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
Old Sep 27, 2012, 05:58 PM
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by glazzies View Post
Get the metal gear ones for a few bucks more. You will be happy about that.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Sep 27, 2012, 06:05 PM
Joined Jan 2012
Like this:
And these:
I use the hxt900 servos, very good for the price.
I use this motor, plenty of power. http://www.hobbyking.com/hobbyking/s...dProduct=12919
Old Sep 27, 2012, 06:42 PM
United States, AZ, Chino Valley
Joined Feb 2012
Servos
I use the TS-9025 from RC Timer. They survived my learning curves 'forced' landings and inadvertant trajectories through terra-firma. Delivery has been excellent and they have the lowest shipping costs I've found.
justj is online now Find More Posts by justj
Old Sep 27, 2012, 07:22 PM
goodkebo's Avatar
United States, ME, Bar Harbor
Joined Jun 2011
Originally Posted by Mykro View Post
Hi...
Could you post some closeup pics of your plane?? I'm a big fan of the Twinstar II and only fly FPV with a Twinstar II.. My next FPV ship will be your Twinstar clone..
You may have found it already but check out my you tube channel for more info on this plane. I will take some stills next time I fly. I am glad you like it and of course thanks to Ed for putting his techniques out there for all of us.
First flight with details of plane:
http://www.youtube.com/watch?feature...&v=JD_wtRrKLaQ
Construction pics:
http://www.youtube.com/watch?feature...&v=z-cAFL4Ll8w
goodkebo is offline Find More Posts by goodkebo
Old Sep 27, 2012, 07:25 PM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Generally speaking, a KV rating somewhere around 1,000 is a better choice than that 2200 kv motor, props work more efficiently at a more moderate rpm.
A good example of what I'm talking about is the 1350 kv motor in a previous post by glazzies.
Old Sep 27, 2012, 08:45 PM
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
I need a TWIN!
Goodkebo, Please sign me up, I need a twin like yours! Could you please post some pics or a vid that shows how you fastened the tubes on your twin together. That looks like a great design.
7AC is offline Find More Posts by 7AC
Old Sep 28, 2012, 11:53 AM
United States, TX, Spur
Joined Sep 2011
Edit:
Thanks again
Try the Metal Gear 9g servos from here:
http://www.graysonhobby.com/catalog/...vo-p-1405.html
Thurmond
T3PRanch is offline Find More Posts by T3PRanch
Old Sep 28, 2012, 12:50 PM
ARMIN JUNKY
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
Thurmond
Or eBay @ $4.95 ea any amount, free shipping. From China.
Gordosoar is offline Find More Posts by Gordosoar
Old Sep 28, 2012, 01:21 PM
Joined Feb 2012
Thanks for all the suggestions. I am going to try and see how well it flies on a very cheap set up from HobbyKing. Does anyone forsee issues with this set up:
Quantity Stock Product description Price Weight
OK D2822-141450 - D2822/14 Brushless Outrunner 1450kv $7.86 65
BK HK-SS20A - Hobbyking SS Series 18-20A ESC $6.77 30
OK 074000054 - APC Style Propeller 7x5 (2 pc) $1.25 35
OK HK15178 - HK15178 Analog Servo 10g / 1.4kg / 0.09s $7.80 76
OK R610 - OrangeRx R610 Spektrum DSM2 6Ch 2.4Ghz R.. $5.99 39
OK OR16-102x10 - Metal Push Rods M2xL300 (10pcs/set) $1.79 65
BK 016-00503x10 - Linkage Stopper D2.1mm (10sets) $1.05 26
TOTAL: $32.51 336g
With shipping it is around $40 for everything I should need besides the foam board some tape and glue. I want to see how truly cheap I can be with one of these builds. I know I could skip the linkage stopper and use coat hanger or something but I figure the extra $2-$3 is worth the eases of set up and tweaking. Besides it is enough lingages and push rods for multiple planes.
Old Sep 28, 2012, 04:33 PM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Looks like a good start.
If you don't already have a metric allen wrench set that's made in China, get one, US made allen wrenches don't always fit Chinese allen head fasteners, they use a different standard than we do.
I was baffled for quite some time why my high quality metric allen wrenches that were made in USA wouldn't fit the smaller size Chinese fasteners, from what I understand they actually have a different metric standard than we do, weird! Bought a cheap set of Chinese made allen wrenches and they fit fine!
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 47 Sep 18, 2012 10:14 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 03:24 PM
